Topic: Help with Atmolight arduino code? (Read 2295 times) previous topic - next topic
JudeAustin
Hello.
I currently have one RGB LED strip on a ULN2803 darlington and I would like to use Atmolight.
First off, is this possible?
I have the atmoarduino code, but it needs to be changed to just run RGB on PWM pins 9-10-11.
Can anyone help me out with this?
With it all setup and the atmoarduino code stock, when I upload it to the arduino all it gives me is blue light, and in AtmoWin, when I adjust faders and stuff the TX light on the arduino flashes.
I've tried changing so much but I just can't figure it out.
It would be much appreciated!
Grumpy_Mike
Post the code (use the # icon when posting) and explain what you want it to do and what it actually does also post a schematic of what you have wired up.
JudeAustin
I want the RGB values to go to PWM pins 9-10-11 on my arduino.
I have a single RGB LED strip that I would like to use with just the center or sum channel on vlcs atmolight.
I don't have a ShiftBrite shield and was wondering if I could edit this code to make it work with out one, I have my RGB LED strip connected to a ULN2803 Darlington array, then pins 9-10-11 on my arduino.
Here is the original code for Arduino Atmo:
Code: [Select]
#define clockpin 13 // CI
#define enablepin 10 // EI
#define latchpin 9 // LI
#define datapin 11 // DI
//number of modules in the chain
#define NumLEDs 6
int LEDChannels[NumLEDs][3] = {0};
int SB_CommandMode;
int SB_RedCommand;
int SB_GreenCommand;
int SB_BlueCommand;
  Serial.begin(38400);
   pinMode(datapin, OUTPUT);
   pinMode(latchpin, OUTPUT);
   pinMode(enablepin, OUTPUT);
   pinMode(clockpin, OUTPUT);
   SPCR = (1<<SPE)|(1<<MSTR)|(0<<SPR1)|(0<<SPR0);
   digitalWrite(latchpin, LOW);
   digitalWrite(enablepin, LOW);
//sample code from macetech
void SB_SendPacket() {
   if (SB_CommandMode == B01) {
     SB_RedCommand = 127;
     SB_GreenCommand = 127;
     SB_BlueCommand = 127;
    SPDR = SB_CommandMode << 6 | SB_BlueCommand>>4;
    while(!(SPSR & (1<<SPIF)));
    SPDR = SB_BlueCommand<<4 | SB_RedCommand>>6;
    SPDR = SB_RedCommand << 2 | SB_GreenCommand>>8;
    SPDR = SB_GreenCommand;
void WriteLEDArray() {
    SB_CommandMode = B00; // Write to PWM control registers
    for (int h = 0;h<NumLEDs;h++) {
  SB_RedCommand = LEDChannels[h][0];
  SB_GreenCommand = LEDChannels[h][1];
  SB_BlueCommand = LEDChannels[h][2];
  SB_SendPacket();
    delayMicroseconds(15);
    digitalWrite(latchpin,HIGH); // latch data into registers
    digitalWrite(latchpin,LOW);
    SB_CommandMode = B01; // Write to current control registers
    for (int z = 0; z < NumLEDs; z++) SB_SendPacket();
int incomingatmo[255];
int buffer=0;
int channels;
int i=0;
int BluePin=11;
int GreenPin=9;
int RedPin=10;
int laststatus=0;
int lastbyte=0;
int average=0;
int j=0;
int channel=0;
int x=0;
//order is reversed, first byte is last module in the chain
//0=sum
//1=left
//2=right
//3=top
//4=bottom
byte channelorder[6]={2,2,3,3,1,1};
// old gammatable for atmega's own pwm 0-255
//byte gammatable[]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,1,1,1,2,2,2,2,2,2,2,3,3,3,3,3,3,4,4,4,4,5,5,5,5,5,6,6,6,7,7,7,7,8,8,8,9,9,9,10,10,10,11,11,12,12,12,13,13,14,14,14,15,15,16,16,17,17,18,18,19,19,20,20,21,22,22,23,23,24,25,25,26,26,27,28,28,29,30,31,31,32,33,33,34,35,36,36,37,38,39,39,40,41,42,43,44,45,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,66,68,69,70,71,72,73,75,76,77,78,79,81,82,83,85,86,87,88,90,91,93,94,95,97,98,99,101,102,104,105,107,108,110,111,113,114,116,117,119,121,122,124,125,127,129,130,132,134,135,137,139,141,142,144,146,148,150,151,153,155,157,159,161,162,164,166,168,170,172,174,176,178,180,182,184,186,189,191,193,195,197,199,201,203,206,208,210,212,215,217,219,221,224,226,228,231,233,235,238,240,243,245,247,250,252,255};
int gammatable[]={0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,2,2,2,2,2,3,3,3,4,4,4,5,5,6,6,6,7,7,8,8,9,10,10,11,12,12,13,14,14,15,16,17,18,19,19,20,21,22,23,24,26,27,28,29,30,31,33,34,35,36,38,39,41,42,44,45,47,48,50,52,53,55,57,58,60,62,64,66,68,70,72,74,76,78,80,82,85,87,89,92,94,96,99,101,104,106,109,112,114,117,120,123,125,128,131,134,137,140,143,146,149,153,156,159,162,166,169,172,176,179,183,187,190,194,198,201,205,209,213,217,221,225,229,233,237,241,246,250,254,258,263,267,272,276,281,286,290,295,300,305,310,314,319,324,329,335,340,345,350,355,361,366,372,377,383,388,394,400,405,411,417,423,429,435,441,447,453,459,465,472,478,484,491,497,504,510,517,524,530,537,544,551,558,565,572,579,586,593,601,608,615,623,630,638,645,653,661,668,676,684,692,700,708,716,724,732,740,749,757,765,774,782,791,800,808,817,826,835,844,853,862,871,880,889,898,908,917,926,936,945,955,965,974,984,994,1004,1014,1023};
const int numReadings = 1;
int bluereadings[numReadings];
int blueindex = 0;
int bluetotal = 0;
int redreadings[numReadings];
int redindex = 0;
int redtotal = 0;
int greenreadings[numReadings];
int greenindex = 0;
int greentotal = 0;
void outputpwm(int curchannel)
  int blue=gammatable[incomingatmo[(channelorder[curchannel]*3)+3]];
  int red=gammatable[incomingatmo[(channelorder[curchannel]*3)+1]];
  int green=gammatable[incomingatmo[(channelorder[curchannel]*3)+2]];
   bluetotal= bluetotal - bluereadings[blueindex];
  redtotal= redtotal - redreadings[redindex];
  greentotal= greentotal - greenreadings[greenindex];
   bluereadings[blueindex] =  blue;
   redreadings[redindex] =  red;
   greenreadings[greenindex] =  green;
   bluetotal= bluetotal + bluereadings[blueindex];
   redtotal= redtotal + redreadings[redindex];
   greentotal= greentotal + greenreadings[greenindex];
   // advance to the next position in the array:
   blueindex = blueindex + 1;
   redindex = redindex + 1;
   greenindex = greenindex + 1;
   if (blueindex >= numReadings)
     blueindex = 0;
    if (redindex >= numReadings)
       redindex = 0;
    if (greenindex >= numReadings)
      greenindex = 0;
   // calculate the average:
    average = redtotal / numReadings;
     LEDChannels[curchannel][0]=average;
   average = greentotal / numReadings;
  LEDChannels[curchannel][1]=average;
   average = bluetotal / numReadings;
   LEDChannels[curchannel][2]=average;
  if(Serial.available()>0)
    buffer = Serial.read();
   if(buffer==0xff)
     while(Serial.available()==0)
     buffer=Serial.read();
     if(buffer==0x00)
       if(buffer==0x00)
           for(i=0;i<16;i++)
              incomingatmo[i]=Serial.read();
            for(channel=0;channel<NumLEDs;channel++)
                outputpwm(channel);
             WriteLEDArray();
    WriteLEDArray();
     delay(5);
ibourdon
#3
Aug 24, 2011, 07:10 pm Last Edit: Aug 24, 2011, 09:04 pm by ibourdon Reason: 1
Since your not using the Shiftbrights your don't need the code for it.
Connect the input pins on the ULN2803 to the digital pins on your Arduino.
Then connect the negative lead of your LEDs to the output.
Finally connect the positive lead of your LEDs to its supply voltage (0.5-30 volts).
To turn your load on set the digital pin HIGH.
To turn your load off pull the pin to LOW or set it to INPUT.
You can still use PWM to control the darlington pairs on the ULN2803.
Each pair can be controlled digitally or through PWM just like any other MOSFET or transistor.
Oops, just realized this is an OLD A** dead post. Sorry for bringing back a zombie..
