Global Moderator
Boston area, metrowest
Offline
Brattain Member
Available for Design & Build services
« Reply #315 on: July 24, 2011, 11:44:14 pm » |
Lefty, am collecting lots of bits & pieces for it, thats for sure! Auto installing, I don't know, maybe just a ReadMeFirst.txt file
Logged
Left Coast, CA (USA)
Offline
Brattain Member
Measurement changes behavior
« Reply #316 on: July 24, 2011, 11:57:28 pm » |
Lefty, am collecting lots of bits & pieces for it, thats for sure! Auto installing, I don't know, maybe just a ReadMeFirst.txt file  So did the Bobuino have a change in crystal freq? # extras added for arduino boards
############################################################## atmega1284p.name=Arduino-Bobuino 1284p
atmega1284p.upload.protocol=stk500 atmega1284p.upload.maximum_size=129024 atmega1284p.upload.speed=38400
atmega1284p.bootloader.low_fuses=0xFF atmega1284p.bootloader.high_fuses=0xDC atmega1284p.bootloader.extended_fuses=0xFD atmega1284p.bootloader.path=atmega atmega1284p.bootloader.file=ATmegaBOOT_168_atmega1284p.hex atmega1284p.bootloader.unlock_bits=0x3F atmega1284p.bootloader.lock_bits=0x0F
atmega1284p.build.mcu=atmega1284p atmega1284p.build.f_cpu=18432000L atmega1284p.build.core=arduino
Logged
Global Moderator
Offline
Brattain Member
« Reply #317 on: July 25, 2011, 06:38:19 pm » |
Got boards.txt corrected to call out the correct frequency. Didn't help with pin mapping.
Logged
Global Moderator
Offline
Brattain Member
« Reply #318 on: July 25, 2011, 07:03:33 pm » |
Putting an error in pins_duino1284.cxx did indeed cause an error, so the file would seem to be seen. You know, Think I just noticed something that might help. In pins_duino1284.cxx, there are 6 arrays. I didn't change the first 3, just the second 3. I just noticed that the pin assignments seem to follow the first 3 arrays, and not the last 3. Am gonna play with those next: #define PA 1 #define PB 2 #define PC 3 #define PD 4
// these arrays map port names (e.g. port B) to the // appropriate addresses for various functions (e.g. reading // and writing) const uint16_t PROGMEM port_to_mode_PGM[] = { NOT_A_PORT,
now to mess with the order of these, since the Digital Pin assignment are going: PortA: 0-7 PortB: 8-15 PortC: 16-23 PortD: 24-31 &DDRA, &DDRB, &DDRC, &DDRD };
const uint16_t PROGMEM port_to_output_PGM[] = { NOT_A_PORT, &PORTA, &PORTB, &PORTC, &PORTD };
const uint16_t PROGMEM port_to_input_PGM[] = { NOT_A_PORT, &PINA, &PINB, &PINC, &PIND };
const uint8_t PROGMEM digital_pin_to_port_PGM[] = { PD, /* 0 PD0 */ PD, /* 1 PD1 */ PD, /* 2 PD2 */ PD, /* 3 PD3 */ PB, /* 4 PB0 */ PB, /* 5 PB1 */ PB, /* 6 PB2 */ PB, /* 7 PB3 */
PD, /* 8 PD5 */ PD, /* 9 PD6 */ PB, /* 10 PB4 */ PB, /* 11 PB5 */ PB, /* 12 PB6 */ PB, /* 13 PB7 */ PA, /* 14 PA0 */ PA, /* 15 PA1 */
PA, /* 16 PA2 */ PA, /* 17 PA3 */ PA, /* 18 PA4 */ PA, /* 19 PA5 */ PA, /* 20 PA6 */ PA, /* 21 PA7 */ PC, /* 22 PC0 */ PC, /* 23 PC1 */
PC, /* 24 PC2 */ PC, /* 25 PC3 */ PC, /* 26 PC4 */ PC, /* 27 PC5 */ PC, /* 28 PC6 */ PC, /* 29 PC7 */ PD, /* 30 PD4 */ PD /* 31 PD7 */ };
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[] = { _BV(0), /*D0: 0, port D */ _BV(1), /*D1: 1, port D */ _BV(2), /*D2: 2, port D */ _BV(3), /*D3: 3, port D */ _BV(0), /*D4: 0, port B */ _BV(1), /*D5: 1, port B */ _BV(2), /*D6: 2, port B */ _BV(3), /*D7: 3, port B */
_BV(5), /*D8: 5, port D */ _BV(6), /*D9: 6, port D */ _BV(4), /*D10: 4, port B */ _BV(5), /*D11: 5, port B */ _BV(6), /*D12: 6, port B */ _BV(7), /*D13: 7, port B */ _BV(0), /*D14: 0, port A */ _BV(1), /*D15: 1, port A */
_BV(2), /*D16, 2, port A */ _BV(3), /*D17: 3, port A */ _BV(4), /*D18: 4, port A */ _BV(5), /*D19: 5, port A */ _BV(6), /*D20: 6, port A */ _BV(7), /*D21: 7, port A */ _BV(0), /*D22: 0, port C */ _BV(1), /*D23: 1, port C */
_BV(2), /*D24, 2, port C */ _BV(3), /*D25: 3, port C */ _BV(4), /*D26: 4, port C */ _BV(5), /*D27: 5, port C */ _BV(6), /*D28: 6, port C */ _BV(7), /*D29: 7, port C */ _BV(4), /*D30: 4, port D */ _BV(7) /*D31: 7, port D */ };
const uint8_t PROGMEM digital_pin_to_timer_PGM[] = { NOT_ON_TIMER, /* 0 - PD0 */ NOT_ON_TIMER, /* 1 - PD1 */ NOT_ON_TIMER, /* 2 - PD2 */ NOT_ON_TIMER, /* 3 - PD3 */ NOT_ON_TIMER, /* 4 - PB0 */ NOT_ON_TIMER, /* 5 - PB1 */ NOT_ON_TIMER, /* 6 - PB2 */ TIMER0A, /* 7 - PB3 */ // PWM
TIMER1A, /* 8 - PD5 */ // PWM TIMER2B, /* 9 - PD6 */ // PWM TIMER0B, /* 10 - PB4 */ // PWM NOT_ON_TIMER, /* 11 - PB5 */ NOT_ON_TIMER, /* 12 - PB6 */ NOT_ON_TIMER, /* 13 - PB7 */ NOT_ON_TIMER, /* 14 - PA0 */ NOT_ON_TIMER, /* 15 - PA1 */
NOT_ON_TIMER, /* 16 - PA2 */ NOT_ON_TIMER, /* 17 - PA3 */ NOT_ON_TIMER, /* 18 - PA4 */ NOT_ON_TIMER, /* 19 - PA5 */ NOT_ON_TIMER, /* 20 - PA6 */ NOT_ON_TIMER, /* 21 - PA7 */ NOT_ON_TIMER, /* 22 - PC0 */ NOT_ON_TIMER, /* 23 - PC1 */
NOT_ON_TIMER, /* 24 - PC2 */ NOT_ON_TIMER, /* 25 - PC3 */ NOT_ON_TIMER, /* 26 - PC4 */ NOT_ON_TIMER, /* 27 - PC5 */ NOT_ON_TIMER, /* 28 - PC6 */ NOT_ON_TIMER, /* 29 - PC7 */ TIMER1B, /* 30 - PD4 */ // PWM TIMER2A /* 31 - PD7 */ // PWM };
Logged
Global Moderator
Offline
Brattain Member
« Reply #319 on: July 25, 2011, 08:54:02 pm » |
Success!! To make it work, I stripped out the pins_arduino.c file in the arduino-0022 folders area and changed it to the listing below. I renamed the pins_arduino.c in the arduino-extras folders area to a name that didn't start with pins. If there is a way to make the #ifdef's work for other processors, I'd like some direction on making that work. For now, I am only compiling correctly for "my" 1284 and have to revert to naming files to use '328 Duemilanoves.  ! On to more testing! /* heavily modified to only support an atmega1284 as used in the"Bobuino"
pins_arduino.c - pin definitions for the Arduino board Part of Arduino / Wiring Lite
Copyright (c) 2005 David A. Mellis
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public License along with this library; if not, write to the Free Software Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
$Id$ */
#ifndef _AVR_IO_H_ #include <avr/io.h> #endif //#include "wiring_private.h" #ifndef Wiring_h #include "wiring.h" #endif #ifndef Pins_Arduino_h #include "pins_arduino.h" #endif
// On the Bobuino board, digital pins are also used // for the analog output (software PWM). Analog input // pins are a separate set.
// ATMEL ATMEGA1284P / BOBUINO // // +---\/---+ // INT0 (D 4) PB0 1| |40 PA0 (AI 0 / D14) // INT1 (D 5) PB1 2| |39 PA1 (AI 1 / D15) // INT2 (D 6) PB2 3| |38 PA2 (AI 2 / D16) // PWM (D 7) PB3 4| |37 PA3 (AI 3 / D17) // PWM (D 10) PB4 5| |36 PA4 (AI 4 / D18) // MOSI (D 11) PB5 6| |35 PA5 (AI 5 / D19) // MISO (D 12) PB6 7| |34 PA6 (AI 6 / D21) // SCK (D 13) PB7 8| |33 PA7 (AI 7 / D22) // RST 9| |32 AREF // VCC 10| |31 GND // GND 11| |30 AVCC // XTAL2 12| |29 PC7 (D 29) // XTAL1 13| |28 PC6 (D 28) // RX0 (D 0) PD0 14| |27 PC5 (D 27) TDI // TX0 (D 1) PD1 15| |26 PC4 (D 26) TDO // RX1 (D 2) PD2 16| |25 PC3 (D 25) TMS // TX1 (D 3) PD3 17| |24 PC2 (D 24) TCK // PWM (D 30) PD4 18| |23 PC1 (D 23) SDA // PWM (D 8 ) PD5 19| |22 PC0 (D 22) SCL // PWM (D 9) PD6 20| |21 PD7 (D 31) PWM // +--------+ //
// these arrays map port names (e.g. port B) to the // appropriate addresses for various functions (e.g. reading // and writing) const uint16_t PROGMEM port_to_mode_PGM[] = { NOT_A_PORT, &DDRA, &DDRB, &DDRC, &DDRD };
Logged
Smithfield, Rhode Island
Offline
God Member
« Reply #320 on: July 25, 2011, 09:04:38 pm » |
Great job, congrats!
Logged
Global Moderator
Offline
Brattain Member
« Reply #321 on: July 25, 2011, 09:31:40 pm » |
Thanks! Just made up DB9 to 3-pin female header cable, writing a sketch now to check out the serial port.
Logged
Global Moderator
Offline
Brattain Member
« Reply #322 on: July 25, 2011, 10:42:00 pm » |
Serial port testing works!
Logged
nr Bundaberg, Australia
Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
« Reply #323 on: July 25, 2011, 11:36:51 pm » |
Don't you just love breathing life into a new board? When it works of course  It's looking real good Bob. ______ Rob
Logged
Global Moderator
Offline
Brattain Member
« Reply #324 on: July 25, 2011, 11:58:21 pm » |
Yeah, when it works! I am 100% confident in the hardware, getting the software to play nice is the tricky part. Since I unique-a-fied my pins_arduino.c file for just this board, I have some fooling around to do now to use my '328 boards.
Anyway, back to an RTC sketch. Tomorrow, I guess, contacts are getting pretty dry ...
Logged
Offline
God Member
« Reply #325 on: July 26, 2011, 12:07:40 am » |
Don't you just love breathing life into a new board? When it works of course  Well, if it does not work, well then you have not breathed life into it ;-) So everyone, Bob has worked his butt off on this board. The least we can all do is buy one from him!
Logged
Global Moderator
Offline
Brattain Member
« Reply #326 on: July 26, 2011, 12:14:14 am » |
 Thanks for the plug!
Logged
Minnesota
Offline
Newbie
« Reply #327 on: July 26, 2011, 07:15:57 am » |
Here is the pins_arduino.c that I have been using that works with many processors.
Logged
Global Moderator
Offline
Brattain Member
« Reply #328 on: July 26, 2011, 08:27:06 am » |
Thanks mnmis. This section (actually the 2 above it, but the end results are obvious in this one) show the resulting pin mapping from PA-1 ... PD-7 to the D0-D31 that show up on the actual IO. My board uses them somewhat differently. I will modify this to reflect mine & check it out. I had the hardest time getting this info pulled in by the IDE, finally resorting to removing everything but my 1284 needs. If I had understood how this worked when I was assigning pin usage on the board, I may have assigned pin usage differently. As it was, I tried to match pin usages to reflect the Duemilanove pin usage on shield headers for maximum compatibility. const uint8_t PROGMEM digital_pin_to_timer_PGM[] = { NOT_ON_TIMER, /* 0 - PB0 */ NOT_ON_TIMER, /* 1 - PB1 */ NOT_ON_TIMER, /* 2 - PB2 */ TIMER0A, /* 3 - PB3 */ TIMER0B, /* 4 - PB4 */ NOT_ON_TIMER, /* 5 - PB5 */ NOT_ON_TIMER, /* 6 - PB6 */ NOT_ON_TIMER, /* 7 - PB7 */ NOT_ON_TIMER, /* 8 - PD0 */ NOT_ON_TIMER, /* 9 - PD1 */ NOT_ON_TIMER, /* 10 - PD2 */ NOT_ON_TIMER, /* 11 - PD3 */ TIMER1B, /* 12 - PD4 */ TIMER1A, /* 13 - PD5 */ TIMER2B, /* 14 - PD6 */ TIMER2A, /* 15 - PD7 */ NOT_ON_TIMER, /* 16 - PC0 */ NOT_ON_TIMER, /* 17 - PC1 */ NOT_ON_TIMER, /* 18 - PC2 */ NOT_ON_TIMER, /* 19 - PC3 */ NOT_ON_TIMER, /* 20 - PC4 */ NOT_ON_TIMER, /* 21 - PC5 */ NOT_ON_TIMER, /* 22 - PC6 */ NOT_ON_TIMER, /* 23 - PC7 */ NOT_ON_TIMER, /* 24 - PA0 */ NOT_ON_TIMER, /* 25 - PA1 */ NOT_ON_TIMER, /* 26 - PA2 */ NOT_ON_TIMER, /* 27 - PA3 */ NOT_ON_TIMER, /* 28 - PA4 */ NOT_ON_TIMER, /* 29 - PA5 */ NOT_ON_TIMER, /* 30 - PA6 */ NOT_ON_TIMER /* 31 - PA7 */
Logged
Minnesota
Offline
Newbie
« Reply #329 on: July 26, 2011, 09:49:23 am » |
CrossRoads,
Keeping pin compatibly across the different processors isn't too high on my priority.
I just keep track of the pin differences and update the code when necessary.
Mnmis
Logged
