Pages: 1 ... 19 20 [21] 22 23 ... 32   Go Down
Author Topic: ATMEL Mega1284P evaluation board avalible  (Read 37966 times)
Smithfield, Rhode Island
Bob, I'm not sure what you're doing in the code. I think the pins files should be more generic, like targeted to a specific processor. Its then up to the developer to use the pins accpording to what they do on the board.
Dallas
Online Online
Shannon Member
The argument can be made to assign pins to serve a specific purpose.
For example, pin numbers and port B bit numbers are one and the same in Alessandro Saporetti's ATtiny45 core.  This deviates from the way pin numbers are typically assigned (sequentially top-left to top-right).  At first, the pin assignment is confusing.  But, it allows the user to go from the Atmel datasheet to their sketch without having to translate from port + bit to Arduino pin.  In my experience, it has made using his core a breeze; I truly appreciate the deviant pin assignment.
I believe CrossRoads is trying to do something similar; create a pin assignment that simplifies using his board.
The pins_xxx.cxx files map physical pins to ports besed on the chip design. In this case, the 1284P DIP is the same is the 644P DIP, so the pins_duino644.cxx is exactly what he needs. I am trying to recall if I needed to make any changes for my 1284P based board.  If I did, it was to add this:
#elif defined(__AVR_ATmega644__) || defined(__AVR_ATmega644P__) || defined(__AVR_ATmega1284P__)
//* pin defs for duino644 and sanquino board
#include "pins_duino644.cxx"
to the pins_arduino.c file that shipped with the cores from avr-developers. But I think it was already there.
So if Bob's board uses non-arduino-standard pins for things like the SPI pins and so on, then he would want to make changes to the arduino headers that map those, but not in the pins_xxx.cxx files. I'll look and see what I did, if anything, to make that happen. I really need to keep better notes :-(
Boston area, metrowest
(edit - fixed code tags)
I have arduino_extras set up already.
pins_duino644.cxx would seem to be the right file, yet PB0 is accessed as Digitalpin8 and not
D4.
D0 is accessed on PA0 and not PD0, where UART is.
So I think if I rearrange the Px0-7 as I started above, then my software mapping of pins to Dx names as used in my schematic should work, and a shield connected to D0, D1 etc, will see software commanded D0/D1 electrical action show up in the right place.
I can try adding 1284 to this line on arduino-extras/pin_arduino.c and see what happens
but pins_duin.cxx doesn't seem to reflect the usage I want.
const uint8_t PROGMEM digital_pin_to_timer_PGM[] =
NOT_ON_TIMER, /* 0  - PB0 */
NOT_ON_TIMER, /* 1  - PB1 */
NOT_ON_TIMER, /* 2  - PB2 */
TIMER0A,       /* 3  - PB3 */
TIMER0B, /* 4  - PB4 */
NOT_ON_TIMER, /* 5  - PB5 */
NOT_ON_TIMER, /* 6  - PB6 */
NOT_ON_TIMER, /* 7  - PB7 */
NOT_ON_TIMER, /* 8  - PD0 */
NOT_ON_TIMER, /* 9  - PD1 */
NOT_ON_TIMER, /* 10 - PD2 */
NOT_ON_TIMER, /* 11 - PD3 */
TIMER1B,     /* 12 - PD4 */
TIMER1A,     /* 13 - PD5 */
TIMER2B,     /* 14 - PD6 */
TIMER2A,     /* 15 - PD7 */
NOT_ON_TIMER, /* 16 - PC0 */
NOT_ON_TIMER,   /* 17 - PC1 */
NOT_ON_TIMER,   /* 18 - PC2 */
NOT_ON_TIMER,   /* 19 - PC3 */
NOT_ON_TIMER,   /* 20 - PC4 */
NOT_ON_TIMER,   /* 21 - PC5 */
NOT_ON_TIMER,   /* 22 - PC6 */
NOT_ON_TIMER,   /* 23 - PC7 */
NOT_ON_TIMER,   /* 24 - PA0 */
NOT_ON_TIMER,   /* 25 - PA1 */
NOT_ON_TIMER,   /* 26 - PA2 */
NOT_ON_TIMER,   /* 27 - PA3 */
NOT_ON_TIMER,   /* 28 - PA4 */
NOT_ON_TIMER,   /* 29 - PA5 */
NOT_ON_TIMER,   /* 30 - PA6 */
NOT_ON_TIMER   /* 31 - PA7 */
« Last Edit: July 24, 2011, 11:28:20 pm by CrossRoads » Logged
Okay, I'm probably mistaken then. Let me review your posts again and see if I have anything to suggest.
[/quote]
Okay so you want to remap the Arduino "digital pins" to different ports. Now i see, sorry I was a bit brain dead earlier. I worked on this a bit some time ago, I'll dig in and see if I can get it going.
Do you have a mapping of what you want?
Ok,  I think I got it, this should agree with the schematic post of the 1284 I posted earlier:
added to pins_arduino.c:
#elif defined(__AVR_ATmega1284__)
//* pin defs for bobuino & 1284 board
#include "pins_duino1284.cxx"
created new pins_duino1284.cxx
24 July - Modified for 1284 - RWP
  pins_arduino.c - pin definitions for the Arduino board
  Part of Arduino / Wiring Lite
  Copyright (c) 2005 David A. Mellis
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General
  Public License along with this library; if not, write to the
  Free Software Foundation, Inc., 59 Temple Place, Suite 330,
  Boston, MA  02111-1307  USA
  $Id: pins_arduino.c 254 2007-04-20 23:17:38Z mellis $
#ifndef _AVR_IO_H_
#include <avr/io.h>
#endif
//#include "wiring_private.h"
#ifndef Wiring_h
#include "wiring.h"
#endif
#ifndef Pins_Arduino_h
#include "pins_arduino.h"
#endif
// On the Sanguino/Bobuino board, digital pins are also used
// for the analog output (software PWM).  Analog input
// pins are a separate set.
// ATMEL ATMEGA1284P / BOBUINO
//  INT0 (D 4)  PB0  1|        |40  PA0 (AI 0 / D14)
//  INT1 (D 5)  PB1  2|        |39  PA1 (AI 1 / D15)
//  INT2 (D 6)  PB2  3|        |38  PA2 (AI 2 / D16)
//   PWM (D 7)  PB3  4|        |37  PA3 (AI 3 / D17)
//   PWM (D 10) PB4  5|        |36  PA4 (AI 4 / D18)
//  MOSI (D 11) PB5  6|        |35  PA5 (AI 5 / D19)
//  MISO (D 12) PB6  7|        |34  PA6 (AI 6 / D21)
//   SCK (D 13) PB7  8|        |33  PA7 (AI 7 / D22)
//              RST  9|        |32  AREF
//              VCC 10|        |31  GND
//              GND 11|        |30  AVCC
//            XTAL2 12|        |29  PC7 (D 29)
//            XTAL1 13|        |28  PC6 (D 28)
//  RX0 (D 0)   PD0 14|        |27  PC5 (D 27) TDI
//  TX0 (D 1)   PD1 15|        |26  PC4 (D 26) TDO
//  RX1 (D 2)   PD2 16|        |25  PC3 (D 25) TMS
//  TX1 (D 3)   PD3 17|        |24  PC2 (D 24) TCK
//  PWM (D 30)  PD4 18|        |23  PC1 (D 23) SDA
//  PWM (D 8 )  PD5 19|        |22  PC0 (D 22) SCL
//  PWM (D 9)   PD6 20|        |21  PD7 (D 31) PWM
#define PA 1
#define PB 2
#define PC 3
#define PD 4
// these arrays map port names (e.g. port B) to the
// appropriate addresses for various functions (e.g. reading
// and writing)
const uint16_t PROGMEM port_to_mode_PGM[] =
NOT_A_PORT,
    &DDRA,
&DDRB,
&DDRC,
&DDRD,
const uint16_t PROGMEM port_to_output_PGM[] =
NOT_A_PORT,
&PORTA,
&PORTB,
&PORTC,
&PORTD,
const uint16_t PROGMEM port_to_input_PGM[] =
NOT_A_PORT,
&PINA,
&PINB,
&PINC,
&PIND,
const uint8_t PROGMEM digital_pin_to_port_PGM[] =
PD, /* 0  PD0 */
PD, /* 1  PD1 */
PD, /* 2  PD2  */
PD, /* 3  PD3  */
PB, /* 4  PB0  */
PB, /* 5  PB1  */
PB, /* 6  PB2  */
PB, /* 7  PB3  */
PD, /* 8  PD5  */
PD, /* 9  PD6  */
PB, /* 10 PB4  */
PB, /* 11 PB5  */
PB, /* 12 PB6  */
PB, /* 13 PB7  */
PA, /* 14 PA0  */
PA, /* 15 PA1  */
PA, /* 16 PA2  */
PA, /* 17 PA3  */
PA, /* 18 PA4  */
PA, /* 19 PA5  */
PA, /* 20 PA6  */
PA, /* 21 PA7  */
   PC, /* 22 PC0  */
PC, /* 23 PC1  */
PC, /* 24 PC2  */
PC, /* 25 PC3  */
PC, /* 26 PC4  */
PC, /* 27 PC5  */
PC, /* 28 PC6  */
PC, /* 29 PC7  */
PD, /* 30 PD4  */
PD  /* 31 PD7  */
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[] =
_BV(0), /*D0: 0, port D */
_BV(1), /*D1: 1, port D */
_BV(2), /*D2: 2, port D */
_BV(3), /*D3: 3, port D */
_BV(0), /*D4: 0, port B */
_BV(1), /*D5: 1, port B */
_BV(2), /*D6: 2, port B */
_BV(3), /*D7: 3, port B */
_BV(5), /*D8: 5, port D */
_BV(6), /*D9: 6, port D */
_BV(4), /*D10: 4, port B */
_BV(5), /*D11: 5, port B */
_BV(6), /*D12: 6, port B */
_BV(7), /*D13: 7, port B */
_BV(0), /*D14: 0, port A */
_BV(1), /*D15: 1, port A */
_BV(2), /*D16, 2, port A */
_BV(3), /*D17: 3, port A */
_BV(4), /*D18: 4, port A */
_BV(5), /*D19: 5, port A */
_BV(6), /*D20: 6, port A */
_BV(7), /*D21: 7, port A */
_BV(0), /*D22: 0, port C */
_BV(1), /*D23: 1, port C */
_BV(2), /*D24, 2, port C */
_BV(3), /*D25: 3, port C */
_BV(4), /*D26: 4, port C */
_BV(5), /*D27: 5, port C */
_BV(6), /*D28: 6, port C */
_BV(7), /*D29: 7, port C */
_BV(4), /*D30: 4, port D */
_BV(7)  /*D31: 7, port D */
NOT_ON_TIMER, /* 0  - PD0 */
NOT_ON_TIMER, /* 1  - PD1 */
NOT_ON_TIMER, /* 2  - PD2 */
NOT_ON_TIMER,     /* 3  - PD3 */
NOT_ON_TIMER, /* 4  - PB0 */
NOT_ON_TIMER, /* 5  - PB1 */
NOT_ON_TIMER, /* 6  - PB2 */
TIMER0A, /* 7  - PB3 */ // PWM
TIMER1A, /* 8  - PD5 */ // PWM
TIMER2B, /* 9  - PD6 */ // PWM
TIMER0B /* 10 - PB4 */ // PWM
NOT_ON_TIMER, /* 11 - PB5 */
NOT_ON_TIMER,      /* 12 - PB6 */
NOT_ON_TIMER,     /* 13 - PB7 */
NOT_ON_TIMER,     /* 14 - PA0 */
NOT_ON_TIMER,     /* 15 - PA1 */
NOT_ON_TIMER, /* 16 - PA2 */
NOT_ON_TIMER, /* 17 - PA3 */
NOT_ON_TIMER, /* 18 - PA4 */
NOT_ON_TIMER, /* 19 - PA5 */
NOT_ON_TIMER, /* 20 - PA6 */
NOT_ON_TIMER, /* 21 - PA7 */
NOT_ON_TIMER, /* 22 - PC0 */
NOT_ON_TIMER, /* 23 - PC1 */
NOT_ON_TIMER, /* 24 - PC2 */
NOT_ON_TIMER, /* 25 - PC3 */
NOT_ON_TIMER, /* 26 - PC4 */
NOT_ON_TIMER, /* 27 - PC5 */
NOT_ON_TIMER, /* 28 - PC6 */
NOT_ON_TIMER, /* 29 - PC7 */
TIMER1B, /* 30 - PD4 */ // PWM
TIMER2A /* 31 - PD7 */ // PWM
This is just getting aggravating now. I've got this great file
http://www.crossroadsfencing.com/pins_duino1284.cxx
in this folder
c:\program file\arduino-0022\hardware\arduino-extras\cores\arduino
and nothing I seem to do gets it used, so my pin mappings never change.
pins_arduino.c has this
Where do I get that defined?
Seems like
pins_duino1284.cxx
is getting compiled as I had to fix a couple of errors the first time I used it after creating it (extra commas at the end of lists of ports I think).
Any ideas?
I think the environment causes that to be defined based on the boards.txt file. Try commenting it out and see if that helps...
Dallas
Online Online
Shannon Member
So long as the entries in boards.txt are correct, it's defined for you.
One potential problem is the way a sketch is linked.  The core is packaged into a (GCC not Arduino) library and then the sketch object file is linked to the library.  The linker uses a "weak reference" for symbols found in libraries.  This means that there could be more than one "port_to_mode_PGM" in the library without triggering an error.  The linker seems to use the first symbol found.
On the one hand, the "#elif" should ensure only one set of pin definitions makes it into the library.  On the other hand, the symptom is a perfect fit for the "multiple symbol" problem.
OK, I had added this to the arduinos-extras boards.txt
The -0022 boards.txt has no 1284 references at all.
extras.name=EXTRAS==============================
# extras added for arduino boards
atmega1284p.name=Arduino-Bobuino 1284p
atmega1284p.upload.protocol=stk500
atmega1284p.upload.maximum_size=129024
atmega1284p.upload.speed=38400
atmega1284p.bootloader.low_fuses=0xFF
atmega1284p.bootloader.high_fuses=0xDC
atmega1284p.bootloader.extended_fuses=0xFD
atmega1284p.bootloader.path=atmega
atmega1284p.bootloader.file=ATmegaBOOT_168_atmega1284p.hex
atmega1284p.bootloader.unlock_bits=0x3F
atmega1284p.bootloader.lock_bits=0x0F
atmega1284p.build.mcu=atmega1284p
atmega1284p.build.f_cpu=18432000L
atmega1284p.build.core=arduino
avrdude.conf has this for the 1284 - I will add the P to the end of 1284 in pins_arduino.c and see what happens.
# ATmega1284P
# similar to ATmega164p
part
    id               = "m1284p";
    desc             = "ATMEGA1284P";
    has_jtag         = yes;
    stk500_devcode   = 0x82; # no STK500v1 support, use the ATmega16 one
    avr910_devcode   = 0x74;
    signature        = 0x1e 0x97 0x05;
    pagel            = 0xd7;
    bs2              = 0xa0;
    chip_erase_delay = 9000;
    pgm_enable       = "1 0 1 0  1 1 0 0    0 1 0 1  0 0 1 1",
                       "x x x x  x x x x    x x x x  x x x x";
    chip_erase       = "1 0 1 0  1 1 0 0    1 0 0 x  x x x x",
    timeout = 200;
    stabdelay = 100;
    cmdexedelay = 25;
    synchloops = 32;
    bytedelay = 0;
    pollindex = 3;
    pollvalue = 0x53;
    predelay = 1;
    postdelay = 1;
    pollmethod = 1;
    pp_controlstack     =
        0x0E, 0x1E, 0x0F, 0x1F, 0x2E, 0x3E, 0x2F, 0x3F,
        0x4E, 0x5E, 0x4F, 0x5F, 0x6E, 0x7E, 0x6F, 0x7F,
        0x66, 0x76, 0x67, 0x77, 0x6A, 0x7A, 0x6B, 0x7B,
        0xBE, 0xFD, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02;
    hventerstabdelay    = 100;
    progmodedelay       = 0;
    latchcycles         = 6;
    togglevtg           = 1;
    poweroffdelay       = 15;
    resetdelayms        = 1;
    resetdelayus        = 0;
    hvleavestabdelay    = 15;
    chiperasepulsewidth = 0;
    chiperasepolltimeout = 10;
    programfusepulsewidth = 0;
    programfusepolltimeout = 5;
    programlockpulsewidth = 0;
    programlockpolltimeout = 5;
    idr                 = 0x31;
    spmcr               = 0x57;
    allowfullpagebitstream = no;
    memory "eeprom"
        paged           = no; /* leave this "no" */
        page_size       = 8;  /* for parallel programming */
        size            = 4096;
        min_write_delay = 9000;
        max_write_delay = 9000;
        readback_p1     = 0xff;
        readback_p2     = 0xff;
read            = "  1   0   1   0      0   0   0   0",
                          "  0   0   x   x    a11 a10  a9  a8",
                          " a7  a6  a5  a4     a3  a2  a1  a0",
                          "  o   o   o   o      o   o   o   o";
write           = "  1   1   0   0      0   0   0   0",
                          "  i   i   i   i      i   i   i   i";
loadpage_lo = "  1   1   0   0      0   0   0   1",
 "  0   0   0   0      0   0   0   0",
 "  0   0   0   0      0  a2  a1  a0",
 "  i   i   i   i      i   i   i   i";
writepage = "  1   1   0   0      0   0   1   0",
 " a7  a6  a5  a4     a3   0   0   0",
 "  x   x   x   x      x   x   x   x";
mode = 0x41;
delay = 10;
blocksize = 128;
readsize = 256;
    memory "flash"
        paged           = yes;
        size            = 131072;
        page_size       = 256;
        num_pages       = 512;
        min_write_delay = 4500;
        max_write_delay = 4500;
        readback_p1     = 0xff;
        readback_p2     = 0xff;
        read_lo         = "  0   0   1   0      0   0   0   0",
                          "a15 a14 a13 a12    a11 a10  a9  a8",
                          "  o   o   o   o      o   o   o   o";
        read_hi         = "  0   0   1   0      1   0   0   0",
                          "  o   o   o   o      o   o   o   o";
        loadpage_lo     = "  0   1   0   0      0   0   0   0",
                          "  0   0   x   x      x   x   x   x",
                          "  x  a6  a5  a4     a3  a2  a1  a0",
                          "  i   i   i   i      i   i   i   i";
        loadpage_hi     = "  0   1   0   0      1   0   0   0",
                          "  0   0   x   x      x   x   x   x",
                          "  i   i   i   i      i   i   i   i";
        writepage       = "  0   1   0   0      1   1   0   0",
                          " a7   x   x   x      x   x   x   x",
                          "  x   x   x   x      x   x   x   x";
mode = 0x41;
delay = 10;
blocksize = 256;
readsize = 256;
    memory "lock"
        size            = 1;
        read            = "0 1 0 1  1 0 0 0   0 0 0 0  0 0 0 0",
                          "x x x x  x x x x   x x o o  o o o o";
        write           = "1 0 1 0  1 1 0 0   1 1 1 x  x x x x",
                          "x x x x  x x x x   1 1 i i  i i i i";
    memory "lfuse"
        size            = 1;
        read            = "0 1 0 1  0 0 0 0   0 0 0 0  0 0 0 0",
                          "x x x x  x x x x   o o o o  o o o o";
        write           = "1 0 1 0  1 1 0 0   1 0 1 0  0 0 0 0",
                          "x x x x  x x x x   i i i i  i i i i";
    memory "hfuse"
        size            = 1;
        read            = "0 1 0 1  1 0 0 0   0 0 0 0  1 0 0 0",
        write           = "1 0 1 0  1 1 0 0   1 0 1 0  1 0 0 0",
    memory "efuse"
        size            = 1;
        read            = "0 1 0 1  0 0 0 0  0 0 0 0  1 0 0 0",
        write           = "1 0 1 0  1 1 0 0  1 0 1 0  0 1 0 0",
                          "x x x x  x x x x  1 1 1 1  1 i i i";
    memory "signature"
        size            = 3;
        read            = "0  0  1  1   0  0  0  0   x  x  x  x   x  x  x  x",
                          "x  x  x  x   x  x a1 a0   o  o  o  o   o  o  o  o";
    memory "calibration"
        size            = 1;
        read            = "0 0 1 1  1 0 0 0   0 0 0 x  x x x x",
                          "0 0 0 0  0 0 0 0   o o o o  o o o o";
[/code
No help - pin3 still blinks on A3.
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
byte pinx = 3; // do not use 0, 1
  // initialize the digital pin as an output.
  // Pin 13 has an LED connected on most Arduino boards:
  pinMode(pinx, OUTPUT);
  digitalWrite(pinx, HIGH);   // set the LED on
  delay(200);              // wait for a second
  digitalWrite(pinx, LOW);    // set the LED off
Dallas
Online Online
Shannon Member
In "pins_duino1284.cxx", very near the "digital_pin_to_port_PGM" declaration, add a "#error" line, save, and try to compile your test sketch.  Did the compiler stop at the "#error" line?
Left Coast, CA (USA)
Measurement changes behavior
I just knew that the arduino IDE mods would be a big pot hole in progress of the Bobuino.  smiley-wink
Where is that auto installing Bobuino zip file when you need it.  smiley-grin
Lefty
« Last Edit: July 24, 2011, 11:38:19 pm by retrolefty » Logged
Coding:  Yes.
added here
#error
PD, /* 0  PD0 */
PD, /* 1  PD1 */
PD, /* 2  PD2  */
PD, /* 3  PD3  */
PB, /* 4  PB0  */
PB, /* 5  PB1  */
PB, /* 6  PB2  */
PB, /* 7  PB3  */
Got this when compiled:
In file included from C:\Program Files\Arduino-0022\hardware\arduino-extras\cores\arduino\pins_arduino.c:114:
C:\Program Files\Arduino-0022\hardware\arduino-extras\cores\arduino\/pins_duino1284.cxx:105:2: error: #error
Pages: 1 ... 19 20 [21] 22 23 ... 32   Go Up
