Topic: ATMEL Mega1284P evaluation board avalible (Read 131914 times) previous topic - next topic
CrossRoads
Lefty, am collecting lots of bits & pieces for it, thats for sure!
Auto installing, I don't know, maybe just a ReadMeFirst.txt file 8)
retrolefty
So did the Bobuino have a change in crystal freq?
# extras added for arduino boards
atmega1284p.name=Arduino-Bobuino 1284p
atmega1284p.upload.protocol=stk500
atmega1284p.upload.maximum_size=129024
atmega1284p.upload.speed=38400
atmega1284p.bootloader.low_fuses=0xFF
atmega1284p.bootloader.high_fuses=0xDC
atmega1284p.bootloader.extended_fuses=0xFD
atmega1284p.bootloader.path=atmega
atmega1284p.bootloader.file=ATmegaBOOT_168_atmega1284p.hex
atmega1284p.bootloader.unlock_bits=0x3F
atmega1284p.bootloader.lock_bits=0x0F
atmega1284p.build.mcu=atmega1284p
atmega1284p.build.f_cpu=18432000L
atmega1284p.build.core=arduino
CrossRoads
Got boards.txt corrected to call out the correct frequency. Didn't help with pin mapping.
CrossRoads
Putting an error in pins_duino1284.cxx did indeed cause an error, so the file would seem to be seen.
You know, Think I just noticed something that might  help.
In pins_duino1284.cxx, there are 6 arrays.
I didn't change the first 3, just the second 3.
I just noticed that the pin assignments seem to follow the first 3 arrays, and not the last 3.
Am gonna play with those next:
#define PA 1
#define PB 2
#define PC 3
#define PD 4
// these arrays map port names (e.g. port B) to the
// appropriate addresses for various functions (e.g. reading
// and writing)
const uint16_t PROGMEM port_to_mode_PGM[] =
NOT_A_PORT,
now to mess with the order of these, since the Digital  Pin assignment are going:
PortA: 0-7
PortB: 8-15
PortC: 16-23
PortD: 24-31
                     &DDRA,
&DDRB,
&DDRC,
&DDRD
const uint16_t PROGMEM port_to_output_PGM[] =
NOT_A_PORT,
&PORTA,
&PORTB,
&PORTC,
&PORTD
const uint16_t PROGMEM port_to_input_PGM[] =
NOT_A_PORT,
&PINA,
&PINB,
&PINC,
&PIND
const uint8_t PROGMEM digital_pin_to_port_PGM[] =
PD, /* 0  PD0 */
PD, /* 1  PD1 */
PD, /* 2  PD2  */
PD, /* 3  PD3  */
PB, /* 4  PB0  */
PB, /* 5  PB1  */
PB, /* 6  PB2  */
PB, /* 7  PB3  */
PD, /* 8  PD5  */
PD, /* 9  PD6  */
PB, /* 10 PB4  */
PB, /* 11 PB5  */
PB, /* 12 PB6  */
PB, /* 13 PB7  */
PA, /* 14 PA0  */
PA, /* 15 PA1  */
PA, /* 16 PA2  */
PA, /* 17 PA3  */
PA, /* 18 PA4  */
PA, /* 19 PA5  */
PA, /* 20 PA6  */
PA, /* 21 PA7  */
    PC, /* 22 PC0  */
PC, /* 23 PC1  */
PC, /* 24 PC2  */
PC, /* 25 PC3  */
PC, /* 26 PC4  */
PC, /* 27 PC5  */
PC, /* 28 PC6  */
PC, /* 29 PC7  */
PD, /* 30 PD4  */
PD  /* 31 PD7  */
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[] =
_BV(0), /*D0: 0, port D */
_BV(1), /*D1: 1, port D */
_BV(2), /*D2: 2, port D */
_BV(3), /*D3: 3, port D */
_BV(0), /*D4: 0, port B */
_BV(1), /*D5: 1, port B */
_BV(2), /*D6: 2, port B */
_BV(3), /*D7: 3, port B */
_BV(5), /*D8: 5, port D */
_BV(6), /*D9: 6, port D */
_BV(4), /*D10: 4, port B */
_BV(5), /*D11: 5, port B */
_BV(6), /*D12: 6, port B */
_BV(7), /*D13: 7, port B */
_BV(0), /*D14: 0, port A */
_BV(1), /*D15: 1, port A */
_BV(2), /*D16, 2, port A */
_BV(3), /*D17: 3, port A */
_BV(4), /*D18: 4, port A */
_BV(5), /*D19: 5, port A */
_BV(6), /*D20: 6, port A */
_BV(7), /*D21: 7, port A */
_BV(0), /*D22: 0, port C */
_BV(1), /*D23: 1, port C */
_BV(2), /*D24, 2, port C */
_BV(3), /*D25: 3, port C */
_BV(4), /*D26: 4, port C */
_BV(5), /*D27: 5, port C */
_BV(6), /*D28: 6, port C */
_BV(7), /*D29: 7, port C */
_BV(4), /*D30: 4, port D */
_BV(7)  /*D31: 7, port D */
const uint8_t PROGMEM digital_pin_to_timer_PGM[] =
NOT_ON_TIMER, /* 0  - PD0 */
NOT_ON_TIMER, /* 1  - PD1 */
NOT_ON_TIMER, /* 2  - PD2 */
NOT_ON_TIMER,    /* 3  - PD3 */
NOT_ON_TIMER, /* 4  - PB0 */
NOT_ON_TIMER, /* 5  - PB1 */
NOT_ON_TIMER, /* 6  - PB2 */
TIMER0A, /* 7  - PB3 */ // PWM
TIMER1A, /* 8  - PD5 */ // PWM
TIMER2B, /* 9  - PD6 */ // PWM
TIMER0B, /* 10 - PB4 */ // PWM
NOT_ON_TIMER, /* 11 - PB5 */
NOT_ON_TIMER,     /* 12 - PB6 */
NOT_ON_TIMER,     /* 13 - PB7 */
NOT_ON_TIMER,     /* 14 - PA0 */
NOT_ON_TIMER,     /* 15 - PA1 */
NOT_ON_TIMER, /* 16 - PA2 */
NOT_ON_TIMER, /* 17 - PA3 */
NOT_ON_TIMER, /* 18 - PA4 */
NOT_ON_TIMER, /* 19 - PA5 */
NOT_ON_TIMER, /* 20 - PA6 */
NOT_ON_TIMER, /* 21 - PA7 */
NOT_ON_TIMER, /* 22 - PC0 */
NOT_ON_TIMER, /* 23 - PC1 */
NOT_ON_TIMER, /* 24 - PC2 */
NOT_ON_TIMER, /* 25 - PC3 */
NOT_ON_TIMER, /* 26 - PC4 */
NOT_ON_TIMER, /* 27 - PC5 */
NOT_ON_TIMER, /* 28 - PC6 */
NOT_ON_TIMER, /* 29 - PC7 */
TIMER1B, /* 30 - PD4 */ // PWM
TIMER2A /* 31 - PD7 */ // PWM
CrossRoads
Success!!
To make it work, I stripped out the pins_arduino.c file in the arduino-0022 folders area and changed it to the listing below.
I renamed the pins_arduino.c in the arduino-extras folders area to a name that didn't start with pins.
If there is a way to make the #ifdef's work for other processors, I'd like some direction on making that work.
For now, I am only compiling correctly for "my" 1284 and have to revert to naming files to use '328 Duemilanoves.
8) 8) 8)!
On to more testing!
heavily modified to only support an atmega1284 as used in the"Bobuino"
pins_arduino.c - pin definitions for the Arduino board
  Part of Arduino / Wiring Lite
  Copyright (c) 2005 David A. Mellis
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General
  Public License along with this library; if not, write to the
  Free Software Foundation, Inc., 59 Temple Place, Suite 330,
  Boston, MA  02111-1307  USA
  $Id$
#ifndef _AVR_IO_H_
#include <avr/io.h>
#endif
//#include "wiring_private.h"
#ifndef Wiring_h
#include "wiring.h"
#endif
#ifndef Pins_Arduino_h
#include "pins_arduino.h"
#endif
// On the Bobuino board, digital pins are also used
// for the analog output (software PWM).  Analog input
// pins are a separate set.
// ATMEL ATMEGA1284P / BOBUINO
//  INT0 (D 4)  PB0  1|        |40  PA0 (AI 0 / D14)
//  INT1 (D 5)  PB1  2|        |39  PA1 (AI 1 / D15)
//  INT2 (D 6)  PB2  3|        |38  PA2 (AI 2 / D16)
//   PWM (D 7)  PB3  4|        |37  PA3 (AI 3 / D17)
//   PWM (D 10) PB4  5|        |36  PA4 (AI 4 / D18)
//  MOSI (D 11) PB5  6|        |35  PA5 (AI 5 / D19)
//  MISO (D 12) PB6  7|        |34  PA6 (AI 6 / D21)
//   SCK (D 13) PB7  8|        |33  PA7 (AI 7 / D22)
//              RST  9|        |32  AREF
//              VCC 10|        |31  GND
//              GND 11|        |30  AVCC
//            XTAL2 12|        |29  PC7 (D 29)
//            XTAL1 13|        |28  PC6 (D 28)
//  RX0 (D 0)   PD0 14|        |27  PC5 (D 27) TDI
//  TX0 (D 1)   PD1 15|        |26  PC4 (D 26) TDO
//  RX1 (D 2)   PD2 16|        |25  PC3 (D 25) TMS
//  TX1 (D 3)   PD3 17|        |24  PC2 (D 24) TCK
//  PWM (D 30)  PD4 18|        |23  PC1 (D 23) SDA
//  PWM (D 8 )  PD5 19|        |22  PC0 (D 22) SCL
//  PWM (D 9)   PD6 20|        |21  PD7 (D 31) PWM
#define PA 1
#define PB 2
#define PC 3
#define PD 4
// and writing)
NOT_A_PORT,
    &DDRA,
&DDRB,
&DDRC,
&DDRD
NOT_A_PORT,
&PORTA,
&PORTB,
&PORTC,
&PORTD
NOT_A_PORT,
&PINA,
&PINB,
&PINC,
&PIND
PD, /* 0  PD0 */
PD, /* 1  PD1 */
PD, /* 2  PD2  */
PD, /* 3  PD3  */
PB, /* 4  PB0  */
PB, /* 5  PB1  */
PB, /* 6  PB2  */
PB, /* 7  PB3  */
PD, /* 8  PD5  */
PD, /* 9  PD6  */
PB, /* 10 PB4  */
PB, /* 11 PB5  */
PB, /* 12 PB6  */
PB, /* 13 PB7  */
PA, /* 14 PA0  */
PA, /* 15 PA1  */
PA, /* 16 PA2  */
PA, /* 17 PA3  */
PA, /* 18 PA4  */
PA, /* 19 PA5  */
PA, /* 20 PA6  */
PA, /* 21 PA7  */
    PC, /* 22 PC0  */
PC, /* 23 PC1  */
PC, /* 24 PC2  */
PC, /* 25 PC3  */
PC, /* 26 PC4  */
PC, /* 27 PC5  */
PC, /* 28 PC6  */
PC, /* 29 PC7  */
PD, /* 30 PD4  */
PD  /* 31 PD7  */
skyjumper
CrossRoads
Thanks! Just made up DB9 to 3-pin female header cable, writing a sketch now to check out the serial port.
CrossRoads
Serial port testing works!
Graynomad
Don't you just love breathing life into a new board? When it works of course :)
It's looking real good Bob.
______
Rob
CrossRoads
Yeah, when it works! I am 100% confident in the hardware, getting the software to play nice is the tricky part.
Since I unique-a-fied my pins_arduino.c file for just this board, I have some fooling around to do now to use my '328 boards.
Anyway, back to an RTC sketch.
Tomorrow,  I guess, contacts are getting pretty dry ...
skyjumper
Well, if it does not work, well then you have not breathed life into it ;-)
So everyone, Bob has worked his butt off on this board. The least we can all do is buy one from him!
CrossRoads
mnmis
Here is the pins_arduino.c that I have been using that works with many processors.
CrossRoads
Thanks mnmis.
This section (actually the 2 above it, but the end results are obvious in this one) show the resulting pin mapping from PA-1 ... PD-7 to the D0-D31 that show up on the actual IO.  My board uses them somewhat differently.
I will modify this to reflect mine & check it out. I had the hardest time getting this info pulled in by the IDE, finally resorting to removing everything but my 1284 needs.
If I had understood how this worked  when I was assigning pin usage on the board, I may have assigned pin usage differently.
As it was, I tried to match pin usages to reflect the Duemilanove pin usage on shield headers for maximum compatibility.
NOT_ON_TIMER, /* 0  - PB0 */
NOT_ON_TIMER, /* 1  - PB1 */
NOT_ON_TIMER, /* 2  - PB2 */
TIMER0A,      /* 3  - PB3 */
TIMER0B,                 /* 4  - PB4 */
NOT_ON_TIMER, /* 5  - PB5 */
NOT_ON_TIMER, /* 6  - PB6 */
NOT_ON_TIMER, /* 7  - PB7 */
NOT_ON_TIMER, /* 8  - PD0 */
NOT_ON_TIMER, /* 9  - PD1 */
NOT_ON_TIMER, /* 10 - PD2 */
NOT_ON_TIMER, /* 11 - PD3 */
TIMER1B,      /* 12 - PD4 */
TIMER1A,      /* 13 - PD5 */
TIMER2B,      /* 14 - PD6 */
TIMER2A,      /* 15 - PD7 */
NOT_ON_TIMER, /* 16 - PC0 */
NOT_ON_TIMER,   /* 17 - PC1 */
NOT_ON_TIMER,   /* 18 - PC2 */
NOT_ON_TIMER,   /* 19 - PC3 */
NOT_ON_TIMER,   /* 20 - PC4 */
NOT_ON_TIMER,   /* 21 - PC5 */
NOT_ON_TIMER,   /* 22 - PC6 */
NOT_ON_TIMER,   /* 23 - PC7 */
NOT_ON_TIMER,   /* 24 - PA0 */
NOT_ON_TIMER,   /* 25 - PA1 */
NOT_ON_TIMER,   /* 26 - PA2 */
NOT_ON_TIMER,   /* 27 - PA3 */
NOT_ON_TIMER,   /* 28 - PA4 */
NOT_ON_TIMER,   /* 29 - PA5 */
NOT_ON_TIMER,   /* 30 - PA6 */
NOT_ON_TIMER   /* 31 - PA7 */
mnmis
CrossRoads,
Keeping pin compatibly across the different processors isn't too high on my priority.
I just keep track of the pin differences and update the code when necessary.
Mnmis
