Pages: 1 ... 27 28 [29] 30 31 32   Go Down
Author Topic: ATMEL Mega1284P evaluation board avalible  (Read 37958 times)
I read whole thread, so much info to consume. Anyway I see you have used the core files from avr-developers which is based on version 20, but I think you can also use the latest core from github, which seems to be named as Arduino 1, because Arduino devs merged the updates from avr-developers core. I try that one when I receive the stencils  smiley-mad (not bobuino but a 1284p chip based board).
Boston area, metrowest
Please post how that works out, I am up for improvement if possible.
I made small modifications on version arduino-1.0-beta4 and it works well on my Atmega1284.
Board definition is;
atmega1284.name=Bobuino W/ ATmega1284P
atmega1284.upload.protocol=arduino
atmega1284.upload.maximum_size=131072
atmega1284.upload.speed=57600
atmega1284.bootloader.low_fuses=0xFF
atmega1284.bootloader.high_fuses=0xDC
atmega1284.bootloader.extended_fuses=0xFD
atmega1284.bootloader.path=sanguino
atmega1284.bootloader.file=ATmegaBOOT_168_atmega1284p.hex
atmega1284.bootloader.unlock_bits=0x3F
atmega1284.bootloader.lock_bits=0x0F
atmega1284.build.mcu=atmega1284p
atmega1284.build.f_cpu=16000000L
atmega1284.build.core=arduino
atmega1284.build.variant=Bobuino
pins_arduino.h file in folder "C:\arduino-1.0-beta4\hardware\arduino\variants\Bobuino"
  pins_arduino.h - pin definitions for the Arduino board
  Part of Arduino / Wiring Lite
  Copyright (c) 2005 David A. Mellis
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General
  Public License along with this library; if not, write to the
  Free Software Foundation, Inc., 59 Temple Place, Suite 330,
  Boston, MA  02111-1307  USA
  $Id: pins_arduino.c 254 2007-04-20 23:17:38Z mellis $
#ifndef Pins_Arduino_h
#define Pins_Arduino_h
#include <avr/pgmspace.h>
#define NUM_DIGITAL_PINS            32
#define NUM_ANALOG_INPUTS           8
#define analogInputToDigitalPin(p)  ((p <   8) ? (p) + 24 : -1)
#define analogInputPinToBit(p)      ((P >= 24) ? (p) - 24 : -1)
#define digitalPinHasPWM(p)         ((p) == 3 || (p) == 4 || (p) == 12 || (p) == 13 || (p) == 14 || (p) == 15)
const static uint8_t SS   = 4;
const static uint8_t MOSI = 5;
const static uint8_t MISO = 6;
const static uint8_t SCK  = 7;
const static uint8_t SDA  = 17;
const static uint8_t SCL  = 16;
const static uint8_t LED  = 13;
const static uint8_t A0   = 24;
const static uint8_t A1   = 25;
const static uint8_t A2   = 26;
const static uint8_t A3   = 27;
const static uint8_t A4   = 28;
const static uint8_t A5   = 29;
const static uint8_t A6   = 30;
const static uint8_t A7   = 31;
//  Bit        7        6        5        4       3         2       1        0
// PCMSK3 = PCINT31, PCINT30, PCINT29, PCINT28, PCINT27, PCINT26, PCINT25, PCINT24
// Dg.Pin     15        14       13      12        11       10      9        8 PCICRBit = 1
// PCMSK2 = PCINT23, PCINT22, PCINT21, PCINT20, PCINT19, PCINT18, PCINT17, PCINT16
// Dg.Pin     23        22       21      20        19       18      17       16 PCICRBit = 2
// PCMSK1 = PCINT15, PCINT14, PCINT13, PCINT12, PCINT11, PCINT10, PCINT9,  PCINT8
// Dg.Pin     7         6         5       4        3         2      1         0 PCICRBit = 0
// PCMSK0 = PCINT7,  PCINT6,  PCINT5,  PCINT4,  PCINT3,  PCINT2,  PCINT1,  PCINT0
// Dg.Pin     31       30        29      28       27       26       25       24 PCICRBit = 3
#define digitalPinToPCICR(p)    (((p) >= 0 && (p) <= 31) ? (&PCICR) : ((uint8_t *)0))
#define digitalPinToPCICRbit(p) (((p) <= 7) ? 0 : (((p) <= 15) ? 1 : (((p) <= 23) ? 2 : 3)))
#define digitalPinToPCMSK(p)    (((p) <= 7) ? (&PCMSK1):(((p) <= 15) ? (&PCMSK3):(((p) <= 23) ? (&PCMSK2):(((p) <= 31) ? (&PCMSK0):((uint8_t *)0)))))
#define digitalPinToPCMSKbit(p) (((p) <= 7) ? (p) : (((p) <= 15) ? ((p) - 8) : (((p) <= 23) ? ((p) - 16) : ((p) - 24))))
#ifdef ARDUINO_MAIN
// ATMEL ATMEGA1284
//          (D 0) PB0  1|        |40  PA0 (AI 0 / D24)
//          (D 1) PB1  2|        |39  PA1 (AI 1 / D25)
//INT2      (D 2) PB2  3|        |38  PA2 (AI 2 / D26)
//      PWM (D 3) PB3  4|        |37  PA3 (AI 3 / D27)
//      PWM (D 4) PB4  5|        |36  PA4 (AI 4 / D28)
//     MOSI (D 5) PB5  6|        |35  PA5 (AI 5 / D29)
//PWM  MISO (D 6) PB6  7|        |34  PA6 (AI 6 / D30)
//PWM   SCK (D 7) PB7  8|        |33  PA7 (AI 7 / D31)
//                RST  9|        |32  AREF
//                VCC 10|        |31  GND
//                GND 11|        |30  AVCC
//              XTAL2 12|        |29  PC7 (D 23)
//              XTAL1 13|        |28  PC6 (D 22)
//     RX0 (D 8)  PD0 14|        |27  PC5 (D 21) TDI
//     TX0 (D 9)  PD1 15|        |26  PC4 (D 20) TDO
//INT0 RX1 (D 10) PD2 16|        |25  PC3 (D 19) TMS
//INT1 TX1 (D 11) PD3 17|        |24  PC2 (D 18) TCK
//     PWM (D 12) PD4 18|        |23  PC1 (D 17) SDA
//     PWM (D 13) PD5 19|        |22  PC0 (D 16) SCL
//     PWM (D 14) PD6 20|        |21  PD7 (D 15) PWM
// these arrays map port names (e.g. port B) to the
// appropriate addresses for various functions (e.g. reading
// and writing)
const uint16_t PROGMEM port_to_mode_PGM[] = {
NOT_A_PORT,
(uint16_t) &DDRA,
(uint16_t) &DDRB,
(uint16_t) &DDRC,
(uint16_t) &DDRD,
const uint16_t PROGMEM port_to_output_PGM[] = {
NOT_A_PORT,
(uint16_t) &PORTA,
(uint16_t) &PORTB,
(uint16_t) &PORTC,
(uint16_t) &PORTD,
const uint16_t PROGMEM port_to_input_PGM[] = {
NOT_A_PORT,
(uint16_t) &PINA,
(uint16_t) &PINB,
(uint16_t) &PINC,
(uint16_t) &PIND,
const uint8_t PROGMEM digital_pin_to_port_PGM[] = {
// PORTLIST
PB, // PB 0 **  0 ** D  0
PB, // PB 1 **  1 ** D  1
PB, // PB 2 **  2 ** D  2
PB, // PB 3 **  3 ** D  3 PWM
PB, // PB 4 **  4 ** D  4 PWM SS
PB, // PB 5 **  5 ** D  5 MOSI
PB, // PB 6 **  6 ** D  6 MISO
PB, // PB 7 **  7 ** D  7 SCK
PD, // PD 0 **  8 ** D  8 RX0
PD, // PD 1 **  9 ** D  9 TX0
PD, // PD 2 ** 10 ** D 10 RX1
PD, // PD 3 ** 11 ** D 11 TX1
PD, // PD 4 ** 12 ** D 12 PWM
PD, // PD 5 ** 13 ** D 13 PWM
PD, // PD 6 ** 14 ** D 14 PWM
PD, // PD 7 ** 15 ** D 15 PWM
PC, // PC 0 ** 16 ** D 16 SCL
PC, // PC 1 ** 17 ** D 17 SDA
PC, // PC 2 ** 18 ** D 18 TCK
PC, // PC 3 ** 19 ** D 19 TMS
PC, // PC 4 ** 20 ** D 20 TDO
PC, // PC 5 ** 21 ** D 21 TDI
PC, // PC 6 ** 22 ** D 22
PC, // PC 7 ** 23 ** D 23
PA, // PA 0 ** 24 ** D 24 AI 0
PA, // PA 1 ** 25 ** D 25 AI 1
PA, // PA 2 ** 26 ** D 26 AI 2
PA, // PA 3 ** 27 ** D 27 AI 3
PA, // PA 4 ** 28 ** D 28 AI 4
PA, // PA 5 ** 29 ** D 29 AI 5
PA, // PA 6 ** 30 ** D 30 AI 6
PA  // PA 7 ** 31 ** D 31 AI 7
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[] =
_BV(0), /*  0, PB0 */
_BV(1), /*  1, PB1 */
_BV(2), /*  2, PB2 */
_BV(3), /*  3, PB3 */
_BV(4), /*  4, PB4 */
_BV(5), /*  5, PB5 */
_BV(6), /*  6, PB6 */
_BV(7), /*  7, PB7 */
_BV(0), /*  8, PD0 */
_BV(1), /*  9, PD1 */
_BV(2), /* 10, PD2 */
_BV(3), /* 11, PD3 */
_BV(4), /* 12, PD4 */
_BV(5), /* 13, PD5 */
_BV(6), /* 14, PD6 */
_BV(7), /* 15, PD7 */
_BV(0), /* 16, PC0 */
_BV(1), /* 17, PC1 */
_BV(2), /* 18, PC2 */
_BV(3), /* 19, PC3 */
_BV(4), /* 20, PC4 */
_BV(5), /* 21, PC5 */
_BV(6), /* 22, PC6 */
_BV(7), /* 23, PC7 */
_BV(0), /* 24, PA0 */
_BV(1), /* 25, PA1 */
_BV(2), /* 26, PA2 */
_BV(3), /* 27, PA3 */
_BV(4), /* 28, PA4 */
_BV(5), /* 29, PA5 */
_BV(6), /* 30, PA6 */
_BV(7)  /* 31, PA7 */
const uint8_t PROGMEM digital_pin_to_timer_PGM[] =
NOT_ON_TIMER, /* 0  - PB0 */
NOT_ON_TIMER, /* 1  - PB1 */
NOT_ON_TIMER, /* 2  - PB2 */
TIMER0A, /* 3  - PB3 */
TIMER0B, /* 4  - PB4 */
NOT_ON_TIMER, /* 5  - PB5 */
TIMER3A, /* 6  - PB6 */
TIMER3B, /* 7  - PB7 */
NOT_ON_TIMER, /* 8  - PD0 */
NOT_ON_TIMER, /* 9  - PD1 */
NOT_ON_TIMER, /* 10 - PD2 */
NOT_ON_TIMER, /* 11 - PD3 */
TIMER1B, /* 12 - PD4 */
TIMER1A, /* 13 - PD5 */
TIMER2B, /* 14 - PD6 */
TIMER2A, /* 15 - PD7 */
NOT_ON_TIMER, /* 16 - PC0 */
NOT_ON_TIMER, /* 17 - PC1 */
NOT_ON_TIMER, /* 18 - PC2 */
NOT_ON_TIMER, /* 19 - PC3 */
NOT_ON_TIMER, /* 20 - PC4 */
NOT_ON_TIMER, /* 21 - PC5 */
NOT_ON_TIMER, /* 22 - PC6 */
NOT_ON_TIMER, /* 23 - PC7 */
NOT_ON_TIMER, /* 24 - PA0 */
NOT_ON_TIMER, /* 25 - PA1 */
NOT_ON_TIMER, /* 26 - PA2 */
NOT_ON_TIMER, /* 27 - PA3 */
NOT_ON_TIMER, /* 28 - PA4 */
NOT_ON_TIMER, /* 29 - PA5 */
NOT_ON_TIMER, /* 30 - PA6 */
NOT_ON_TIMER /* 31 - PA7 */
#endif
#endif
And I added the two lines for Atmega1284 to wiring_analog.c
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
if (pin >= 54) pin -= 54; // allow for channel or pin numbers
#elif defined(__AVR_ATmega1284P__)
if (pin >= 24) pin -= 24; // allow for channel or pin numbers
#else
if (pin >= 14) pin -= 14; // allow for channel or pin numbers
#endif
And two lines to wiring_private.h
#define EXTERNAL_NUM_INTERRUPTS 8
#define EXTERNAL_NUM_INTERRUPTS 3
#else
#define EXTERNAL_NUM_INTERRUPTS 2
#endif
Ok, I could see using that - I'd have to make adjustments to make it match my usage:
// ATMEL ATMEGA1284P / BOBUINO
//  INT0 (D 4)  PB0  1|        |40  PA0 (AI 0 / D14)
//  INT1 (D 5)  PB1  2|        |39  PA1 (AI 1 / D15)
//  INT2 (D 6)  PB2  3|        |38  PA2 (AI 2 / D16)
//   PWM (D 7)  PB3  4|        |37  PA3 (AI 3 / D17)
//   PWM (D 10) PB4  5|        |36  PA4 (AI 4 / D18)
//  MOSI (D 11) PB5  6|        |35  PA5 (AI 5 / D19)
//  MISO (D 12) PB6  7|        |34  PA6 (AI 6 / D20)
//   SCK (D 13) PB7  8|        |33  PA7 (AI 7 / D21)
//              RST  9|        |32  AREF
//              VCC 10|        |31  GND
//              GND 11|        |30  AVCC
//            XTAL2 12|        |29  PC7 (D 29)
//            XTAL1 13|        |28  PC6 (D 28)
//  RX0 (D 0)   PD0 14|        |27  PC5 (D 27) TDI
//  TX0 (D 1)   PD1 15|        |26  PC4 (D 26) TDO
//  RX1 (D 2)   PD2 16|        |25  PC3 (D 25) TMS
//  TX1 (D 3)   PD3 17|        |24  PC2 (D 24) TCK
//  PWM (D 30)  PD4 18|        |23  PC1 (D 23) SDA
//  PWM (D 8 )  PD5 19|        |22  PC0 (D 22) SCL
//  PWM (D 9)   PD6 20|        |21  PD7 (D 31) PWM
@Nadir
Thank you very much, you even included Timer 3
Edit: Could you upload ATmegaBOOT_168_atmega1284p.hex somewhere? thanks
« Last Edit: September 11, 2011, 05:28:24 am by anon10500 » Logged
The link is http://code.google.com/p/brewtroller/downloads/detail?name=Sanguino1284P.zip&can=2&q= which I have downloaded.
Sure,
http://www.crossroadsfencing.com/BobuinoRev17/ATmegaBOOT_1284P_16MHz.hex
Right-click, save target as, renameto .hex
Rapa Nui
Pukao hats cleaning services
Hi, any experience with the newest sdfat (multiple cards support) and two sdcards connected?
Thx.
No, I don't have a board with 2 sockets. Yet.
The first build only supports 1, the 2nd had incorrect uSD socket pinouts.
Have Rev 2 designed, but no cards purchased. Will handlle one of SD or uSD on either side of the board.
Suppose I could try an Adafruit shield for a 2nd one as a test.
« Last Edit: September 12, 2011, 03:04:42 pm by CrossRoads » Logged
Meh bootloader does not work:
avrdude: stk500_getsync(): not in sync: resp=0x00
Actually my device is 8MHz so I installed WinAVR and compiled bootloader code (from brewtroller) but no avail...
Programmer is FTDI breakout.
EDIT: Turns out common ground is needed for board and ftdi breakout. Also I attached 8Mhz bootloader which works at baudrate 38400.
« Last Edit: September 16, 2011, 10:24:18 am by anon10500 » Logged
Denmark
New on the Arduino platform...
Call me blind, but i cannot find the PCB layout for this exact board:
It's wonderfull, and i would like to toy a little with the layout ;-)
// Per.
Ok, you are blind!
Layout is not posted, that was a paid job I did, I had permission to post the picture.
You can send a PM to skyjumper to ask him for the layout.
Hello all,
After reading through the 29 pages of this thread, and about another 50+ pages of other threads, I am still at a loss to understand how to bootload my '1284 based dev board.
I would really appreciate it if someone could please share a working bootloaders for the '1284 that works at 16MHz and 20MHz (I understand different bootloaders are needed)?
Thanks in advance,
Regards,
Madhu.
I don't know about 20 MHz, but arduino bootloaders will work at 16 MHz.
Check out the core files here for 1284's.
www.avr-developers.com
skyjumper made this bootloader for me.
(right-click, save-target-as, rename to .hex if need to).
Then get yourself an AVR ISP such as this to load the bootloader into it.
http://www.mdfly.com/index.php?main_page=product_info&cPath=5&products_id=415
add these 2 lines to programmers.txt to use it in the IDE. Tools:Burn Bootloader: w/ MDFLY
usbasp.name=MDFLY
usbasp.protocol=usbasp
and add a section like this in boards.txt
atmega1284p.name=Arduino-Bobuino 1284p      <<< this will show up in the IDE boards list
atmega1284p.upload.protocol=stk500
atmega1284p.upload.maximum_size=129024
atmega1284p.upload.speed=38400
atmega1284p.bootloader.low_fuses=0xFF
atmega1284p.bootloader.high_fuses=0xDC
atmega1284p.bootloader.extended_fuses=0xFD
atmega1284p.bootloader.path=Bobuino              <<< change to your path
atmega1284p.bootloader.file=ATmegaBOOT_1284P_16MHz.hex
atmega1284p.bootloader.unlock_bits=0x3F
atmega1284p.bootloader.lock_bits=0x0F
atmega1284p.build.mcu=atmega1284p
atmega1284p.build.f_cpu=16000000L
atmega1284p.build.core=arduino
Can you follow all that?
Hi Crossroads,
Thanks a million for all this. I was able to make changes to reflect my programmer in the IDE (AVR910).
I also replaced the pins_arduino.C with the one you have created and that it works fine.
Thank you so much yet again,
Madhu.
« Last Edit: October 14, 2011, 03:21:02 pm by Madhu » Logged
Seattle, WA
Hey, is the source for this bootloader available?
Pages: 1 ... 27 28 [29] 30 31 32   Go Up
