Loading...
Pages: [1]   Go Down
Author Topic: Bash to send command to Arduino  (Read 1337 times)
Australia
Offline Offline
Newbie
View Profile
Dear all,
I am trying to send a command from a bash shell to my Arduino Uno.
I have the following code running on the Arduino:
Code:
int LedPin = 13;
int val = 0;
  pinMode(LedPin, OUTPUT);
// Read Value from serial and set a led high or low
void loop () {
  val = Serial.read();
  if (val == '0') {
    digitalWrite(LedPin,LOW);
  if (val == '1') {
    digitalWrite(LedPin,HIGH);
From bash, I can set the led high or low using screen and then press 0 or 1:
Code:
virtualmix@bluedragon:~$ screen /dev/ttyACM0
I would like to set the led high or low using echo:
Code:
echo 1 > /dev/ttyACM0
But it doesn't work.
Am I doing it wrong? Is there any known issues using the echo command, or anything I have missed out?
Any help appreciated :-)
Thank you!
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
I would guess that screen opens the serial port once, and keeps it open, and that echo opens the port, sends the data, and closes the port.
Opening and closing the serial port causes the Arduino to reset. The echo command sends the data before the Arduino is ready to read it, so it gets lost. The immediate reset causes the action, even if the data was received to not be executed.
There are ways to modify the Arduino to prevent a reset on the opening of the serial port.
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Your arduino code does not check if there is a character on the serial port, check - http://www.arduino.cc/en/Serial/Available
Code:
#DEFINE LEDPIN 13
char val;
  pinMode(LEDPIN , OUTPUT);
void loop ()
  if (Serial.available() > 0)
    if (val == '0')
      digitalWrite(LEDPIN ,LOW);
    if (val == '1')
      digitalWrite(LEDPIN ,HIGH);
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Portugal
Online Online
God Member
Tomorrow I will know a BIT more than yesterday
View Profile
Hello since you are using linux why not try gtkterm if you have graphic envirement ofcorse to test it.
If not you should this example to configure the port
stty -F /dev/ttyS0 ispeed 9600 ospeed 9600 -ignpar cs8
-cstopb -echo
In my case 9600 baud, no parity, one stop bit.
Then  wrote the data you need to send into a file (using hexedit) and
send the file's contents:
cat commando0.dat > /dev/ttyS0
Also check if you port is ttyS0!!
Logged
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Raspberry PI Model B
Australia
Offline Offline
Newbie
View Profile
Thank you so much to all of you for your reply.
Hugo007 was right, the problem is due to the serial port being closed after each connexion and the Arduino restarting every time because of its auto reset feature.
Anyway, I have tried a few different solutions and investigate this issue a bit further but it does not seem to have an elegant solution.
So far, the best solution I have found, but not tested, is to plug a 120 Ohm resistor between 5V and reset pin.
I couldn't find any "software solution" that successfully disabled the auto reset feature.
Also, I played a bit with gtkterm and it seemed similar to "screen" in some ways but does not satisfy my need to send command directly from a bash script.
Thanks again for your support and if there is anything new, I am still open to discuss this issue.
-Virtualmix-
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
There is a hardware solution - turn hardware flow control off with stty, and it won't toggle the DTR pin, thus avoiding reset.
Logged
Australia
Offline Offline
Newbie
View Profile
@Aeturnalus: Thank you for your reply.
Do you know the exact command?
So far I tried several stty command without success...
I have spend about 4 hours to try do this and I am now about to give up my project...
« Last Edit: May 21, 2011, 12:52:31 pm by virtualmix » Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
Try this:
stty -F /dev/ttyUSB0 -hupcl
Seems to work on my computer.
Logged
Australia
Offline Offline
Newbie
View Profile
Thanks Aeturnalus.
I tried this command in many different ways but it doesn't disable auto reset feature on my Arduino.
Code:
virtualmix@computer:~$ stty -F /dev/ttyACM0 -hupcl
virtualmix@computer:~$ echo 1 >/dev/ttyACM0
The board keep reseting :-/
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
Strange - it seemed to work for me.  Have you tried running it as root?
Logged
Australia
Offline Offline
Newbie
View Profile
Code:
virtualmix@computer:~$ sudo su
[sudo] password for virtualmix:
root@computer:/home/virtualmix# stty -F /dev/ttyACM0 -hupcl
root@computer:/home/virtualmix# echo 1 >/dev/ttyACM0
The board still reset...
So I tried to change the permissions:
Code:
root@computer:/home/virtualmix# chmod 777 /dev/ttyACM0
But it did not work, my Arduino still reset.
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
The stty command disables hangup - that is, it keeps the serial connection open.  Have you tried seeing what happens if you do this:
Code:
~$ sudo stty -F /dev/ttyACM0 -hupcl
~$ echo 1 > /dev/ttyACM0
Does it reset twice, or just once?  On my board, the first echo command resets, but the second one doesn't.
Logged
Australia
Offline Offline
Newbie
View Profile
Thanks for for help.
I did what you suggested but the board still reset.
Logged
Australia
Offline Offline
Newbie
View Profile
Sorry I didn't read your previous post properly: The board reset twice.
Logged
Pages: [1]   Go Up
Print
Jump to:
