Topic: Bash to send command to Arduino (Read 11672 times) previous topic - next topic
virtualmix
Dear all,
I am trying to send a command from a bash shell to my Arduino Uno.
I have the following code running on the Arduino:
int LedPin = 13;
int val = 0;
  pinMode(LedPin, OUTPUT);
// Read Value from serial and set a led high or low
void loop () {
  val = Serial.read();
  if (val == '0') {
    digitalWrite(LedPin,LOW);
  if (val == '1') {
    digitalWrite(LedPin,HIGH);
From bash, I can set the led high or low using screen and then press 0 or 1:
virtualmix@bluedragon:~$ screen /dev/ttyACM0
I would like to set the led high or low using echo:
echo 1 > /dev/ttyACM0
But it doesn't work.
Am I doing it wrong? Is there any known issues using the echo command, or anything I have missed out?
Any help appreciated :-)
Thank you!
PaulS
I would guess that screen opens the serial port once, and keeps it open, and that echo opens the port, sends the data, and closes the port.
Opening and closing the serial port causes the Arduino to reset. The echo command sends the data before the Arduino is ready to read it, so it gets lost. The immediate reset causes the action, even if the data was received to not be executed.
There are ways to modify the Arduino to prevent a reset on the opening of the serial port.
robtillaart
Your arduino code does not check if there is a character on the serial port, check - http://www.arduino.cc/en/Serial/Available
#DEFINE LEDPIN 13
char val;
  pinMode(LEDPIN , OUTPUT);
void loop ()
  if (Serial.available() > 0)
    if (val == '0')
      digitalWrite(LEDPIN ,LOW);
    if (val == '1')
      digitalWrite(LEDPIN ,HIGH);
Rob Tillaart
hugo007
Hello since you are using linux why not try gtkterm if you have graphic envirement ofcorse to test it.
If not you should this example to configure the port
stty -F /dev/ttyS0 ispeed 9600 ospeed 9600 -ignpar cs8
-cstopb -echo
In my case 9600 baud, no parity, one stop bit.
Then  wrote the data you need to send into a file (using hexedit) and
send the file's contents:
cat commando0.dat > /dev/ttyS0
Also check if you port is ttyS0!!
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Raspberry PI Model B
virtualmix
Thank you so much to all of you for your reply.
Hugo007 was right, the problem is due to the serial port being closed after each connexion and the Arduino restarting every time because of its auto reset feature.
Anyway, I have tried a few different solutions and investigate this issue a bit further but it does not seem to have an elegant solution.
So far, the best solution I have found, but not tested, is to plug a 120 Ohm resistor between 5V and reset pin.
I couldn't find any "software solution" that successfully disabled the auto reset feature.
Also, I played a bit with gtkterm and it seemed similar to "screen" in some ways but does not satisfy my need to send command directly from a bash script.
Thanks again for your support and if there is anything new, I am still open to discuss this issue.
-Virtualmix-
rbtying
There is a hardware solution - turn hardware flow control off with stty, and it won't toggle the DTR pin, thus avoiding reset.
virtualmix
#6
May 21, 2011, 07:48 pm Last Edit: May 21, 2011, 07:52 pm by virtualmix Reason: 1
@Aeturnalus: Thank you for your reply.
Do you know the exact command?
So far I tried several stty command without success...
I have spend about 4 hours to try do this and I am now about to give up my project...
rbtying
Try this:
stty -F /dev/ttyUSB0 -hupcl
Seems to work on my computer.
virtualmix
Thanks Aeturnalus.
I tried this command in many different ways but it doesn't disable auto reset feature on my Arduino.
virtualmix@computer:~$ stty -F /dev/ttyACM0 -hupcl
virtualmix@computer:~$ echo 1 >/dev/ttyACM0
The board keep reseting :-/
rbtying
Strange - it seemed to work for me.  Have you tried running it as root?
virtualmix
virtualmix@computer:~$ sudo su
[sudo] password for virtualmix:
root@computer:/home/virtualmix# stty -F /dev/ttyACM0 -hupcl
root@computer:/home/virtualmix# echo 1 >/dev/ttyACM0
The board still reset...
So I tried to change the permissions:
root@computer:/home/virtualmix# chmod 777 /dev/ttyACM0
But it did not work, my Arduino still reset.
rbtying
The stty command disables hangup - that is, it keeps the serial connection open.  Have you tried seeing what happens if you do this:
~$ sudo stty -F /dev/ttyACM0 -hupcl
~$ echo 1 > /dev/ttyACM0
Does it reset twice, or just once?  On my board, the first echo command resets, but the second one doesn't.
virtualmix
Thanks for for help.
I did what you suggested but the board still reset.
virtualmix
Sorry I didn't read your previous post properly: The board reset twice.
THLL
(I know this is a old post)
For anyone wondering the solution is to put a 10uf cap between reset and gnd. This stops the board from resetting
