Loading...
Pages: [1]   Go Down
Author Topic: Ocean Row Boat - radar target enhancer alarm advice  (Read 369 times)
Offline Offline
Newbie
View Profile
Hello,
I'm new to the forum and ask your expertise and suggestions.
I have a special device, a radar target enhancer that detects radar signals from other ships.  When it detects a signal, it drops a line voltage from 5vDC to 0vDC.  I want a circuit/Arduino system that will detect the drop in voltage and then signal an LED and buzzer.  I'd like to be able to program the unit so that once it detects the signal/drops the voltage, that I don't have to hear/see the 'alarm' for a minute or so (or perhaps can vary the delay).
I'm not sure which Arduino component(s) I need, as well as the programming.  Can anyone help?  My coming expedition is high-profile and could be a great way for someone/small company to gain excellent exposure.
Thank you in advance for your help and suggestions,
W. Vidmar
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
An Arduino sounds a bit like overkill to me - this sounds to me like a 555 would handle it more cheaply.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Red Sea, Saudi Arabia
Offline Offline
God Member
..On The Red Sea
View Profile
WWW
If all you need is the "Alarm/Display and then disable for a while" function, then AWOL's suggestion is excellent.
IF you need Other Stuff like "how often" and "When" to be saved, that's more Arduino territory...
Logged
Regards, Terry King  ..On the Red Sea at KAUST.edu.sa
terry@yourduino.com  LEARN! DO! (Arduino Boards, Sensors, Parts @ http://yourduino.com)
Offline Offline
Newbie
View Profile
Thanks guys,
Originally I hadn't thought about when and where, but it would be helpful information.
I do have several sources of NMEA and GPS positioning data.  Which Arduino (or compatible) box would be appropriate for this project?
Logged
Offline Offline
God Member
..On The Red Sea
View Profile
WWW
For GPS support on Arduino look at:
http://www.arduino.cc/playground/Main/InterfacingWithHardware#location
A nice small implementation may be here:
http://arduiniana.org/libraries/tinygps/
Any of the Arduinos would work for this...  If you needed to make it very much smaller and relatively low power, look at the nano:
http://arduino-direct.com/sunshop/index.php?l=product_detail&p=84
DISCLAIMER: I mentioned stuff from my own Shop...
Logged
Pages: [1]   Go Up
Print
Jump to:
