Topic: looking for single sided barebones with shield compatible footprint (Read 5266 times) previous topic - next topic
n00b
Love the version 3 single sided Arduino, and also love all the barebones units that are perfect for using in actual final builds, but what im looking for is a single sided barebones with shield compatible footprint so I can used my proto shields and off the shelf ones in final builds without committing a full Arduino.
Like this unit
wortelsoft
#1
May 15, 2011, 04:08 pm Last Edit: May 17, 2011, 09:13 am by wortelsoft Reason: 1
Have look at he minimalduino from salsaman:
http://jmsarduino.blogspot.com/search/label/minimalduino
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1263535122
salsaman
Thanks wortelsoft, yeah that's precisely the goal of "minimalduino"-- a bare bones, mostly single-sided board that is shield-friendly.  Install everything or just the ATmega and its cap and reset resistor, whatever you need.  Also 5V/3.3V switchable if you want it to be.
I just uploaded version 107 with fatter traces, easier for home etching.  It's in a shared Google docs folder with a 600dpi jpeg of an etch-ready pattern; here's a small version:
The jumper across the ATmega is annoying, but it's not tough to solder an insulated jumper across the bottom or a non-insulated jumper under the IC socket on top (but it may make the socket sit funny on the board).
My Arduino blog: http://jmsarduino.blogspot.com
Comprehensive (?) Arduino-compatible board list: http://tinyurl.com/allarduinos
CrossRoads
"may sit funny"
Instead of a full 28 pin socket get some header strips  and install as 2 pieces of 7 each and leave a gap to drop the wire across.
http://www.dipmicro.com/store/HDR40X1FM
wortelsoft
I use those strips all the time for making sockets. Might be a little more expensive (alltought I got them quit cheap), but I don't need a whole bunch of different sockets.
@salsaman: I really like your design, really handy for making cheap arduino's
