Topic: Paid programmer help needed (Read 2313 times) previous topic - next topic
evilm3666
Hi
I have a Seeeduino Mega with an ATmega1280. And I am looking to read a sst27sf512 28pin eeprom 1 line at a time. www.futurlec.com/Memory/SST27SF512.shtml
I can send payment by paypal
Please pm if you can help me out
Thanks
PaulS
Quote
How do YOU define a line? The EEPROM reads/writes data one byte at a time.
evilm3666
You are correct PaulS, I do need it to read one byte at a time by toggling the OE on/off.
Graynomad
Do you want to memory-map the chip or just use IO to read it?
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
evilm3666
Just using io to read the chip should be fine.
Graynomad
Then connect 16 outputs to the address pins, 8 inputs to the data, tie CE and OE low, write an address to the address pins and read the data.
If you want to use less power then run CE to a pin as well, leave it high most of the time and toggle it low while you actually  read the data.
______
Rob
guadron3
Hey I was working on a  project and was hoping to program a set of ge g-35 string set christmas lights as shown here: http://www.christmaswow.com/ge-christmas-lights/. However I am having problems with the code since I am relatively new with Arduino. I was wondering if someone could help me program the light to react to different frequencies of sound. I am located in New Jersey and am willing to pay someone for help with the project.
Graynomad
This has nothing to do with the subject of this thread, you should start your own thread if you want people to find it.
______
Rob
Paulware
I created a tlc5490 shield that can control 32 leds...http://atmega.site40.net/default.php?bookmark=#TLC5940 Shield
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
