Topic: I am afraid i have done irreversible damage.... (Read 1 time) previous topic - next topic
qwerty156
So, a year or so back, i just got a new arduino and hooked it up with the following digram,
http://i38.tinypic.com/2yzcyf5.jpg
Back then, my electronics knowledge was limited, the mosfet being a IRF540 with a 100Ohm resistor (with the wrong pinout, lol).
Not surprisingly it did not work because the pin out was incorrect
So, i immediately disconnected the circuit but now the arduino does not work, i cannot upload any code to it.
Is there anyway to fix this?
CrossRoads
Does the Atmega chip get reeeeally warm when power is on? If so, that's usually a good sign it is dead.
If it is socketed, you can buy another and replace it easily.
If you have an duemilanove, you can buy a blank one and Bit-bang a new bootloader into it also.
If SMD, then you're kinda out of luck unless your soldering skills are pretty good.
qwerty156
Yeah i just swapped out th ATMEGA and its working fine! ThanksQ
