0
Offline
Full Member
Arduino rocks
« on: June 17, 2010, 12:21:40 am » |
So...
is there a way to use a small amount of batterys to get a needle glowing red?
As I understand to heat something up one needs a lot of power which batterys don't supply, so is there a way to efficiently convert small amounts of power in large amounts of heat? Or any circuit to to store energy and then release it in a burst to heat up a small metal object very quick?
The point of this is to making something that looks awesome and dangerous :-)
(rule #32 enjoy the little things)
Logged
UK
Offline
Faraday Member
Gorm deficient
« Reply #1 on: June 17, 2010, 01:36:56 am » |
Not sure about the 1k degrees, but a single car battery will make a screwdriver glow cherry red if suitably mistreated.
Logged
Per Arduino ad Astra
United States (Texas)
Offline
God Member
Arduino socks
« Reply #2 on: June 17, 2010, 02:14:37 am » |
what about carbon/graphite rods instead of a needle? mechanical pencil lead makes for a pretty good heating element assuming you find a way to mount it.
« Last Edit: June 17, 2010, 02:14:47 am by weirdo557 »
Logged
Lancashire, UK
Offline
Edison Member
« Reply #3 on: June 17, 2010, 02:20:34 am » |
so is there a way to efficiently convert small amounts of power in large amounts of heat? Its a travesty of the laws of physics, but if you figure out how to do it, you'd be a multi-billionaire in a couple of months.......  A car battery would almost certainly do what you want, provided you can get a solid enough electrical connection between the needle and the battery, but its a little on the large and heavy side.
« Last Edit: June 17, 2010, 02:25:40 am by stephen_t »
Logged
Manchester (England England)
Offline
Brattain Member
Solder is electric glue
« Reply #4 on: June 17, 2010, 02:28:25 am » |
so is there a way to efficiently convert small amounts of power in large amounts of heat It is the conservation of energy physics law that it contravenes. While you can get more voltage at the expense of current or more current at the expense of voltage power is the product of voltage and current, this is measured in watts which is exactly the same units that heat is measured in.
Logged
0
Offline
Full Member
Arduino rocks
« Reply #6 on: June 17, 2010, 02:54:37 am » |
Hmmm no a car battery is definitively too big for a nice place on the window shelf...
Damn those laws of nature :-p
A single 1.5V battery is said to have 2200mAh that would be 2.2Ah which if I'm not mistaken is (theorethically speaking) 1.5V at 2.2A for 1 hour. Or 4.4A 30min. 8.8A for fifteen.. or 132A for one minute --> 198W hehe. (I know no battery can handle this)
Shouldn't it be possible to charge a *reasonably sized* capacitor bank long enaugh to store such power and then release it within ~5 seconds or so? Accumulated energy over time :-)
Logged
0
Offline
Full Member
Arduino rocks
« Reply #7 on: June 17, 2010, 02:58:45 am » |
Thanks for the links but I don't think I will get a car battery^^
P.s. So there is no inefficent way to produce heat? I thought there were materials which rather radiate heat than anything else...
« Last Edit: June 17, 2010, 03:03:51 am by jazzar »
Logged
SF Bay Area (USA)
Offline
Faraday Member
Strongly opinionated, but not official!
« Reply #8 on: June 17, 2010, 03:06:25 am » |
There's a quote: "A car battery can drive a current of 1000+ Amps for long enough to melt a screwdriver."
But no, you can not get large amounts of power out of tiny batteries.
Note that a modern high-discharge NiCd can make a piece of wire glow red hot, for a relatively short time, even for relatively tiny battery sizes (1/3 AA.) This improvement in batteries is largely responsible for the existence of "electric" RC airplanes and cars; put 100mAH (note: a unit of total energy/power) in the battery, and you can take it out at a rate fast enough to lift its own weight, for a minute or two...
Logged
Vermont, USA
Offline
Full Member
ElectroMech
« Reply #9 on: June 17, 2010, 03:15:39 am » |
is there a way to use a small amount of batterys to get a needle glowing red? Have you considered using your batteries to charge up a big(~10,000uF) capacitor and then discharge it through said needle? That would result in an awesome-looking dangerous thing. It is the conservation of energy physics law that it contravenes. While you cannot create energy, which is what you are implying, you CAN change the amount of power (energy released/time). You can increase current and thus power with the sacrifice of total time said batteries last for. Batteries discharge a limited amount of current while capacitors don't. If you shorted a small battery with a needle, it probably wouldn't get very warm(ambient air absorbing the heat[energy] as quick as the battery releases it). Whereas a capacitor charged by that battery could potentially evaporate that needle.
Logged
Vermont, USA
Offline
Full Member
ElectroMech
« Reply #10 on: June 17, 2010, 03:52:57 am » |
A single AA-battery can contain 16,000 Joules of energy. A very generous calculation for the amount of energy required to melt a steel needle weighing 1 gram would be around 1,000 Joules. So my previous statement... Have you considered using your batteries to charge up a big(~10,000uF) ...isn't true. It would take a 1Farad capacitor charged to 1.5 volts to yield 1,125 Joules.
Logged
Offline
Brattain Member
« Reply #11 on: June 17, 2010, 04:37:10 am » |
Batteries discharge a limited amount of current while capacitors don't. Not strictly true. The current output of a power source is limited by the internal impedance. This tends to be much lower in capacitors than batteries. But a capacitor still has an internal impedance that will limit the current it can supply. However more of a limit than this for capacitors is the current rating, if you discharge (or charge) a capacitor too fast you will physically distort the plates and cause a rupture. So what you are trading off with charging a capacitor is time against impedance.
« Last Edit: June 17, 2010, 04:37:45 am by Grumpy_Mike »
Logged
Vermont, USA
Offline
Full Member
ElectroMech
« Reply #12 on: June 17, 2010, 04:55:46 am » |
Not strictly true. I'll be certain not to exaggerate again in the future. On a side note: I just realized that I wasn't the first one to suggest a capacitor.. :-/
Logged
Offline
Brattain Member
« Reply #13 on: June 17, 2010, 05:25:02 am » |
I'll be certain not to exaggerate again in the future. I've told you a million times not to exaggerate.
Logged
0
Offline
Edison Member
Arduino rocks
« Reply #14 on: June 17, 2010, 08:38:10 am » |
s there a way to use a small amount of batterys to get a needle glowing red? Like the filament of a small bulb used in a flashlight?
Logged
