Loading...
Pages: 1 [2] 3 4 5   Go Down
Author Topic: Making a needle glow (1000°C) by Battery  (Read 1268 times)
0
Offline Offline
Full Member
Arduino rocks
View Profile
Ok lets put same data together:
Power supply I'd suggest 2 9V-Blocks, parrallel, each 280mAh.
Total: 0.56Ah => 5.04Wh
My capacitor has an impedance of 0.08Ohm,
capacitance of 1000uF = 0.001F
and will be charged with 9V (10Vmaximum rating)
So Ohm's law:
U = R * I suggests I can draw: 9V/0.08Ohm = 112.5A
with: C * U = Q
0.009 A*s or Coulomb
I will get a discharge with the duration of:
0.009A*s/112.5A = 0.00000072 seconds
*found an error here, now correct:
Energy of a capacitor:
E = 0.5 * U² * C
0.0405J
So in theory I just need to connect 24692 capacitors in parallel :-)
(and thats without loss in cables etc.)
Would be great if someone could look over these calculatons and tell me if I'm on the right track!
Cheers!
P.s. the batterys would have the energy of 5.04Wh * 3600 = 18144 Ws = 18144J
=> ~18 charges
« Last Edit: June 17, 2010, 10:06:08 am by jazzar » Logged
Wigan, UK
Offline Offline
God Member
View Profile
WWW
As someone who burnt a hole in a pocket using nothing but two AA cells and a set of keys, you might want to try shorting different batteries.
It's probably quite dangerous, but you could try putting a pin across the terminals of a 9v battery and seeing what happens.
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
The pin will get hot... but not red glowing (note here that I didn't try this but consider unlikely due to the nature of batterys - also as described above) and then again I want to precisely control when and where the needle begins glowing, speaking of which, my pocket would definately not be on the list :-)
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Is 1000°C really a requirement, or are you really just looking for 'glowing red hot'?
If red hot is the goal, then wouldn't a thinner material be a possibility? Seems to me that a small filament should take much less power to get glowing.
Logged
0
Offline Offline
Faraday Member
20 LEDs are enough
View Profile
WWW
Depends on for how long it is required to glow. If you use an old foto flash circuit to charge a sufficiently big capacitor you can even evaporate it.
I did something like this. 400uF at 300V will store 24J. This is enough to evaporate some part of your needle.
The interesting question though is: what exactly is your usecase?
Udo
Logged
Check out my experiments http://blog.blinkenlight.net
United States (Texas)
Offline Offline
God Member
Arduino socks
View Profile
why do you need the needle anyway? perhaps there is a better way of doing whatever you hope to accomplish
Logged
Kortrijk, Belgium
Offline Offline
Full Member
Young geek
View Profile
WWW
Another cool effect: charge a big cap, then short-circuit it by putting some steel wool between the two legs... Awesome AND reuseable!
Logged
Sorry God members, I'm an atheist.
0
Offline Offline
Full Member
Arduino rocks
View Profile
Hm I'm basically trying to expand my horizon :-)
finding out what is possible... getting to know the limits of different applications, at the moment I'm playing around with different extremes.
In  the end I might build a mini-exhibit featuring a miniature jacobs ladder (high V low A) glowing needle (high A low V) a laser... stuff..
So yes it has to be a needle , if you want people to be interested in your project, using recognisable elements is important.
Can anyone enlighten me on how to convert Joules to glowing needle degrees? :-)
And another question: From several high current appliations I've seen people always use some kind of charging resistor. To prevent overheating I guesss, but is there any formula I can calculate such a thing with?
P.s. 1000°C isn't necessary but a nice red-orange glow would do. Also this is not inteded for continual use just one "flare" (I will call it: JANIO: Jazzars Awesome Needle Instant Oxidizer^^)
« Last Edit: June 17, 2010, 02:33:16 pm by jazzar » Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
I think you need to know the specific heat capacity of the substance you're trying to heat.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Vermont, USA
Offline Offline
Full Member
ElectroMech
View Profile
WWW
Quote
Here is the equation you need:
Q = m*C*(T2-T1)
note: (T2-T1) is generally written as deltaT
Q = Heat energy(Joules)
m = mass(grams or Kg depending on which val used for 'C')
C = specific heat capacity(Joules/(gram*degreeCelsius) or Kg...
So you want to find 'Q'. You need to know the 'C' of your needle. I would just look for specific heat of steel. And you need to know its mass. As for the change in temp... I don't know what temperature makes things glow so you will have to guess. I think its completely possible, but figuring out how to discharge the capacitor(s) in an effective way might be challenging. Be sure to post some pictures of this when all said and done.
Logged
Connecticut, US
Offline Offline
Edison Member
Whatduino
View Profile
WWW
Well, I think it's possible to get a filament to glow given a small single-cell source.  I've seen these:
And apparently this isn't a joke:
Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
Hmm specific heat capacity of steel is 0.46 J/g*K that means I need 0.46 Joules of energy to heat one gram steel by one Kalvin
So from 25°C to 1000° that makes (average needle about 7.5g):
(0.46 J/g*K) * (7.5g) * (975K) = 3363.75J
seems a bit high...
« Last Edit: June 17, 2010, 03:14:15 pm by jazzar » Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
@ halley ...wow just.. wow...
@ P_Wood Thanks :-)
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
What sort of needle is that heavy? A sailmaker's?
Logged
Vermont, USA
Offline Offline
Full Member
ElectroMech
View Profile
WWW
Quote
seems a bit high...
Seems about right. Though, depending on the amount of time it takes, heat may radiate from the needle into the air before it ever gets to glow.
Question: What is the resistance of this needle? smiley-razz
Quote
lol ;D
Logged
Pages: 1 [2] 3 4 5   Go Up
Print
Jump to:
