Topic: Fast communication to PC with low Arduino footprint (Read 13550 times) previous topic - next topic
robtillaart
Did an additional run @2Mb with the same sketch  above
// 2M is a exact divider of 16Mhz
100K chars took 594 msec @ 200000 baud = 168350 bytes/second (used realterm.exe   win7 /64;   )
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
ardeshirm
Dear folks,
is there any way to override connection baud rate via usb programming port in windows or Mac?
i set the baud rate in Arduino Due to Serial.begin(128000) and also in PC to 128000 and everything is ok!
But for higher baud rates i cant get sensible output via hyper terminal or putty.
something like the attachment below
robtillaart
Best results are if the baud rate is a divider of the clock frequency of the chip.
For an UNO this is 16MHZ so 500K and 250K will work better than 256K
No experience with Due but I expect similar "preferences"
Putty should have no problems with 250K and 500K under windows 7.
There are other free terminals like realterm that also do a good job.
Rob Tillaart
robtillaart
Rob Tillaart
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
