Topic: Gmail; Usb; More? Questions (Read 1 time) previous topic - next topic
Soapy29
Hi. I've been looking at some stuff latly, and I'd like to know how to check Gmail and know a certain sender and subject, via USB. You don't have to spoon it to me, just a little nudge in the right direction would be good.
Example: I email my self with a subject line of 2169. It will only look for the sender "myemail" and the subject "2169", and then will exicute a sertain task. That's what I'm trying to do via usb.
zoomkat
USB hints that your computer will run an application as a go between in the operation. Have you developed this application?
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
robtillaart
From your other thread,
Quote
So do I used Python? I mean, I've never used Python and I'd like this to get off the ground. How do I learn it?
Check - www.python.org -
In the left column there is documentation and a free compiler to download.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Soapy29
Do you think I should just invest in an Ethernet shield?
tastewar
You should decide whether you want the device to be tethered to a computer, or if it's important that it be able to function on its own.
jgalak
This.
You basically have two options:
1) Write some sort of computer application (in whatever language you want - Python, Processing, C, Java, Perl, etc.) that grabs a webpage (Gmail in this case), scans it for certain data (your heade info) and sends data out via a USB/serial port to the Arduino.  The Arduino then does whatever you need with it.
Pros: Analyzing a web page is likely easier with a "real" PC-based application than with the much more limited Arduino.  For that matter, there may be some sort of Google-provided API that may make talking to Gmail even easier.
Cons: You need a PC (with this app installed) to always be connected to the Arduino for your project to work.
2) Connect the Arduino to the internet (via an EtherShield, or WiFi shield, etc.), and then have the Arduino grab the webpage and process it.
Pros:  The project is computer independent, you can plug it into any network (or hook up to any WiFi hotspot, etc.) and it'll work.
Cons: Likely much harder to code, though there may be libraries out there for the Arduino to make it easier.
Personally, if I were in your shoes, I'd start with option 1 (using whatever language I'm already familiar with), get everything else working, than consider switching to option 2.  YMMV.
