Topic: 4dsystems serial oled and displaying a bmp image with the arduino (Read 2558 times) previous topic - next topic
0miker0
I was just wondering if anyone here has had luck displaying a bmp or jpeg image on a uOLED-128-G1(SGC) display using the sd card. I've posted my code and description of the problem on the 4dsystems site with no luck. Pretty much all the existing examples out there use outdated code.
Thanks,
Mike
Yot
Could you link to your post there? The idea is to use their program to convert the image and put it on the sd-card. The program will tell you what you need to know to get it to display on the module. Did you read the manual and command sheet?
Regards,
Jeroen.
0miker0
I have a good idea on what the process is on getting an image onto the card. Right now the display works perfectly drawing lines objects and text in different colors so my communication from the arduino to the display is fine. I guess what I am looking for is someone here who is using the most up to date lcd pmmc file and latest Graphics Composer to try and figure out what i'm doing wrong.
Thanks,
Mike
