Topic: HELP ME!!! Desperation! (Read 1 time) previous topic - next topic
bowensj
Hello arduino users! I am trying to get two servos to activate and respond to a knock sensor but CANNOT DO IT! I have scoured the web for code possibilities or anything of the sort but, clearly, have been unsuccessful. I am able to get both servos moving as I would like, but NEED them to only activate for a short time (3 seconds or so) by means of a knock sensor.
Any help in this matter would be greatly appreciated... this is for a group design project and we are all stumped!
THANKS!
bilbo
Do you have any code written?  If you can move a servo, just use this knock sensor code: http://www.arduino.cc/en/Tutorial/Knock but instead of changing the led state, move the servo.
Alice asked the Chesire Cat, who was sitting in a tree, "What road do I take?"
The cat asked, "Where do you want to go?"
"I don't know," Ali
bowensj
OK- we have found that code and have been using it as a guide, yet we are confused about replacing the ledPin code with our servo code. Do you have any pointers?
Thank you!
bilbo
Yes. Replace the line that toggles the led with the line to move the servo.
"I don't know," Ali
bowensj
Ok- thank you again! We tried toggling our servo code:
#include <Servo.h>
Servo first; // create servo object
Servo second; // create servo object
int firstservopin = 8;                               // digital output to which signal wire(yellow) of first servo is connected
int secondservopin= 7;                      //  digital output to which signal wire(yellow) of second servo is connected
  first.attach(firstservopin); // attach the servo to digital output 8
  second.attach(secondservopin); // attach the servo to digital output 7
  first.write(90); // center the servo
   second.write(90); // center the servo
  first.write(0);                        // move first servo to pos 0
  second.write(0);                 // move second servo to pos 0
  first.write(120);               // move first servo to pos 120
  second.write(120);         // move second servo to pos 120
With the example led knock sensor code, but we still have been unsuccessful after many attempts and are very frustrated! Everything is connected the way it should be, we still are unable to get the servos to respond to the knock sensor
Thank you
Stumplegrumps
Have you gotten the knock sensor to work by itself? It's usually a good idea to get each component working before you start merging them.
If you're able, test your knock sensor to find your ideal threshold. This can be done by using a Serial.print(sensorReading); and watching the serial monitor in the Arduino IDE
Once you've established the threshold, it's time to merge all of the components. I would imagine it would look something like this:
Code: [Select]
#include <Servo.h>
//Servo
#define firstservopin 8
#define secondservopin 7
//Knock Sensor
#define knockSensor A0
const int threshold = 100; //Sensitivity of the Knock Sensor
int sensorReading;
 sensorReading = analogRead(knockSensor);
 if (sensorReading >= threshold) {
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
