Topic: PNP transistors... how to use them? (Read 7888 times) previous topic - next topic
eddiea6987
motors is 9-18v thats about all its said in the little radioshack bag. transistor is TIP42G
I could print the Arduino logo on a box of cereal and sell it as "Arduin-O's"
eddiea6987
the magic smoke reminds me of that show Lost.
mmcp42
did you do anything about
a)
b)
c)
or
d)
there are only 10 types of people
them that understands binary
and them that doesn't
eddiea6987
LOL i do have all those in place sir , i posted that for times sake i just did not draw them in , but the smoke is at bay! and connecting the resistor to 12v in fact shuts it off
mmcp42
in that case it's working
now all you need to do is get the PMW signal up and running and Bob can marry your mother's sister
(hey and less of this sir stuff!)
cheers
Mike
eddiea6987
haha thanks for the insight!
like you said , Cheers!
(i didnt get the Bob reference)
mmcp42
you heard the expression "Bob's your uncle"?
means it's ok!
eddiea6987
never heard that in my 24  years hahaha but now i understand why he would marry my mothers sister.
Grumpy_Mike
the emitter of the PNP and the collector to positive 12v and the base to an arduino pwm pin
You can't do that because the only way to turn the transistor off is to put 12V on the base, the arduino can only supply 5V so there is no way to turn the transistor off. Hence it is on all the time.
You need an NPN transistor to generate a 0 to 12V signal to use to turn the PNP on and off.
mmcp42
fair cop
I was assuming (silly me) that the motor was running from 5 volts as well!)
mmcp42
something like this?...
but you'd use 12v (can't find a suitable Fritz symbol :( )
my transistors go E B C for both
yours are different
Grumpy_Mike
mmcp42
I guess R2 is to ensure T2 really does get turned off?
Grumpy_Mike
Well yes R2 is the thing that keep the transistor off in the absence of an on signal. In the old days there was always a pull down resistor like this on NPN transistors as well. This was because with germanium transistors the base threshold was only 0.25V and this could be triggered by pickup.
gerg
means it's ok!
I had never heard that before either. Turns out, unless you live in or under rule of Britain, its not likely to have been heard.
This is a well timed thread as I was just started to read up on transistors.
Thanks.
http://maniacalbits.blogspot.com
