Topic: Using one circuit to switch another - (basic!) (Read 2410 times) previous topic - next topic
mrboni
Hi. Here's a noob question for you
I have one circuit with a power source (batteries) powering an led, controlled by a switch.
I want this same switch (single pole) to also set an arduino pin HIGH when it is pressed.
Can I use a transistor? From what I've been reading here - http://www.ermicro.com/blog/?p=423 I should be able to use something like a 2n3904 transistor to switch the arduino pin high when there is a current in the other circuit, but I cant work it out.
Am I going about this the right way?  And do both circuits need to be powered from the same power source for this to work?
Thanks
cmiyc
An Arduino pin set as an INPUT is a high impedance input.  So you do not need to "switch" it on.  What is the high voltage of the switch that turns on the LED?  If it is 5V you can just connect the Arduino INPUT pin to the same point as the high-side of your switch.
Voltages are based on references, so all components which are connected to each other much share the same reference.  In this case, it means the GROUND of each "circuit" should be connected together.
GROUND is another way of saying "reference plane."
graynomad
#2
May 17, 2011, 04:14 pm Last Edit: May 17, 2011, 04:17 pm by Graynomad Reason: 1
You have to share GNDs between the two systems. If the current circuit has a voltage approx 4.5-5v (say 3 AA cells) you could feed the signal that powers the LED directly into an Arduino pin.
If it's a higher voltage (or a lot lower) a transistor would work, using a diagram from that link
you would run a wire from where it says "non-inductive load" to the Arduino input, and "Microcontroller IO port" is your LED circuit. The signal will be inverted so if you read a LOW the button is pressed.
No, just share GND.
______
Rob
mrboni
Thanks, I'll have a play and get back to you
mrboni
The voltage is 5.9v  Will this be too much for the arduino pin?
graynomad
The voltage is 5.9v
Then another (simpler) option is to step it down with a voltage divider.
______
Rob
mrboni
