Loading...
Pages: 1 [2] 3   Go Down
Author Topic: Beginner's Robotic Arm  (Read 3635 times)
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
what i am to send at your code in order for me to trigger a specific servo.. im not going to be sending servo positions, il only be sending a specific character then my receiver arduino would process it.
I would think you could use a series of "if" or "case" statements to evaluate the character received by the arduino, and send a value to the appropriate servo based on the received character.
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Philippines
Offline Offline
Newbie
View Profile
ok! will try that..thanks!!
Logged
Philippines
Offline Offline
Newbie
View Profile
@zoomkat
im not getting anything out of the serial monitor, also my servos wont run. thanks!
P.S.
im using a PIC16F628A as my transmitter programmed using flowcode v4 and arduino decimilla 168 as my receiver. over 5812A UHF transceiver.http://www.e-gizmo.com/KIT/images/UHF/5812A%20Tech%20Manual.pdf
« Last Edit: July 13, 2011, 11:24:25 am by pao_wikhan » Logged
Philippines
Offline Offline
Newbie
View Profile
Quote
can someone help me recode my code???im not getting any results, even for just one servo port via serial comm. i dont get it, why i can let an LED be high but moving a servo, i cant..help pls! tnx!
Some servo test code I use for testing two servos:
Code:
// zoomkat 11-22-10 serial servo (2) test
// for writeMicroseconds, use a value like 1500
// for IDE 0019 and later
// Powering a servo from the arduino usually DOES NOT WORK.
// two servo setup with two servo commands
// send eight character string like 15001500 or 14501550
#include <Servo.h>
String readString, servo1, servo2;
Servo myservo1;  // create servo object to control a servo
Servo myservo2;
  myservo1.attach(6);  //the pin for the servo control
  myservo2.attach(7);
  Serial.println("servo-test-21"); // so I can keep track of what is loaded
  while (Serial.available()) {
    delay(1);
    if (Serial.available() >0) {
      char c = Serial.read();  //gets one byte from serial buffer
      readString += c; //makes the string readString
  if (readString.length() >0) {
      Serial.println(readString); //see what was received
      // expect a string like 07002100 containing the two servo positions
      servo1 = readString.substring(0, 4); //get the first four characters
      servo2 = readString.substring(4, 8); //get the next four characters
      Serial.println(servo1);  //print to serial monitor to see results
      Serial.println(servo2);
      int n1; //declare as number
      int n2;
      char carray1[6]; //magic needed to convert string to a number
      servo1.toCharArray(carray1, sizeof(carray1));
      n1 = atoi(carray1);
      char carray2[6];
      servo2.toCharArray(carray2, sizeof(carray2));
      n2 = atoi(carray2);
      myservo1.writeMicroseconds(n1); //set servo position
      myservo2.writeMicroseconds(n2);
    readString="";
i get your code now...im using 3 servos so  i have to change this char carray1[6]; to char carray1[9]; ???am i right????
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
Not sure I follow your logic there - can you post your code?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
No, you don' get the code. Note that a seperate array is used for each servo. This is just one very basic way of controlling several servos with the servo positions being sent in a single string. There are code improvements once you decide how you are to control the arm.
Logged
Philippines
Offline Offline
Newbie
View Profile
why is the array 6???that is whow i dont get it..but i did manage to add a third servo by copying the pervious code for the third..why is carray[6]? the comment just stated that it is where the magic happens..
as i send $130130020 on the serial monitor the servos move to that specific degree..
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Quote
Because an "int" can't store more than five decimal digits.
Logged
Philippines
Offline Offline
Newbie
View Profile
why cant i use my hyper terminal to this???is this just for arduino serial monitor???
when i type in 90, it sends out
9
0
but in serial monitor i use $090, it sends
090
why is this?
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Because the serial monitor sends all the characters you type in only when you hit the send key, but hyperterm sends them as you press the individual keys.
(What is wrong with your question-mark key? Is it sticking down?)
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
Because you will need to store four bytes and a null terminator in the array for a total of 5 spaces required (as I understand it). I made the array capable of holding six places just to ensure sufficient array space while tinkering with the code. You should be able to use 5 instead of 6 as you should not have to send more than four characters for use with the servo library.
Logged
Philippines
Offline Offline
Newbie
View Profile
Quote
ohh. now i get it, i didnt get that it was like that. for every substring with 4 integers you allocated 6 spaces, but what is received is only 5 this was a safe precaution to the code. thanks! i'll put it back to 6 and not 9. thanks zoomkat!
Logged
Philippines
Offline Offline
Newbie
View Profile
hi zoomkat,
i was able to control and see the results from the serial monitor. but when i connect the UART of the chip to the controller, it simply shows weird outputs. why is that?
Logged
Global Moderator
UK
Online Online
Brattain Member
View Profile
Quote
Because the controller is a RS232 device with different levels and an inversion?
Logged
Philippines
Offline Offline
Newbie
View Profile
i get it now...what im receiving are the extended ascii codes, why is this?
Logged
Pages: 1 [2] 3   Go Up
Print
Jump to:
