Loading...
Pages: 1 2 [3]   Go Down
Author Topic: Beginner's Robotic Arm  (Read 3703 times)
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
what im receiving are the extended ascii codes, why is this?
I don't follow you there.
What is "the controller"?
Is it a true RS232 device?
If so, how are you connecting it to the Arduino?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Philippines
Offline Offline
Newbie
View Profile
im using servo angles to determin its position and not microseconds. as i send data from my pic16F628A connected from txport rb3 to arduino rx digital pin 0, and turning the serial monitor i receive unknown characters/symbols (i browsed through the ascii table and saw the decimal values for the extended ascii).
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Are you sure you haven't simply got a line inversion?
Logged
Philippines
Offline Offline
Newbie
View Profile
im not exactly sure. how would i remove line inversion? i tapped(very quick) the tx line to the ground and saw numbers upon it, then the symbols appear again.
Logged
Philippines
Offline Offline
Newbie
View Profile
this is what im receiving in my rx port.. i connected a npn transistor to the tx port of my pic.
why is it that im receiving this?
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
I have no idea why you are receiving that, but it looks like either a speed mismatch, or a line inversion.
You could write a simple sketch to find out what the idle state of the line is.
Or look at it with an oscilloscope.
« Last Edit: July 19, 2011, 02:21:29 am by AWOL » Logged
Philippines
Offline Offline
Newbie
View Profile
what kind of sketch would be that??? i tried using just a simple Serial.read(); Serial.println(); sketch, but the same happend...
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
One that does a simple "digitalRead" on the appropriate input pin, and prints the result repeatedly.
Logged
Philippines
Offline Offline
Newbie
View Profile
like a serial to LED sketch? i dont get it...
Logged
Philippines
Offline Offline
Newbie
View Profile
thanks for the help AWOL!
Logged
Philippines
Offline Offline
Newbie
View Profile
hello once again!
i managed to run everything up..but i have one problem, my DC Motor keeps on moving even if its assigned case value isnt called. why is this so???
thanks!
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
Quote
I don't know - where is your code?
Logged
Philippines
Offline Offline
Newbie
View Profile
i found the problem...i placed the break points wrong..hehehehe  smiley-mr-green smiley-mr-green
thanks again AWOL!
Logged
Pages: 1 2 [3]   Go Up
Print
Jump to:
