Loading...
Pages: [1]   Go Down
Author Topic: Scroll LCD bottom line  (Read 919 times)
Offline Offline
Newbie
View Profile
Need to scroll only bottom line of standard H44780 4 bit mode 16 x 2 LCD. Top line to stay fixed. I've been all over this forum, many confusing answers. Does an appended LiquidCrystal library exist to do this function? I would like to reopen this subject for more ideas or a solution.
Thanks
Logged
Western New York, USA
Offline Offline
Faraday Member
View Profile
The HD44780 LCD controller cannot inherently shift one line without the other and I don't know of any libraries that do this in software.  The best way to accomplish this is to shift both lines and then rewrite the line(s) that you didn't want to change.  If you haven't noticed, the correct terminology is shift not scroll.  That's how it is described in the LCD controller data sheet.
Don
Logged
Offline Offline
Newbie
View Profile
From my reading, it sure seems true what you said.  I thought by now a library might have developed. Thanks for a concise 1 sentence idea of a shift procedure.
Also Don
Logged
Offline Offline
Faraday Member
View Profile
Quote
Would I lie to you?
Quote
That's not as easy as it may seem due to the wide variety of displays that are run from the same (ancient) controller.  For some insight into the problem check out the LCD Addressing link at http://web.alfredstate.edu/weimandn.
Don
« Last Edit: May 17, 2011, 08:36:28 pm by floresta » Logged
Central MN, USA
Online Online
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
Check this out. I've not published my codes yet, still a few more things to add before I roll out the new library version:
http://arduino.cc/forum/index.php/topic,60830.0.html
You can scroll back and forth with text area and scrolling list items.
Logged
Pages: [1]   Go Up
Print
Jump to:
