Topic: Infra red receiver at 1.2khz (Read 915 times) previous topic - next topic
ivanseidel
Hi all!
I need to detect a IR wave at 1.2khz of frequency.
I used analog sensors to detect it, but, it just worked for 40cm of distance.
Then, i tried with a 38khz phototransistor, and it only detected the ir signal once, after some ms the signal became 0 and nothing happend, even turning off the 1.2khz emitter.
How can i sense the 1.2khz frequency with a distance bigger than 2m?
Tanks!
Ivan
Arduino DueTimer | https://github.com/ivanseidel/DueTimer
Arduino Thread | https://github.com/ivanseidel/ArduinoThread
johnwasser
The 38 KHz receiver module has a bandpass filter to get rid of signals with a frequency far from 38 kHz, like your 1.2 kHz signal.  You probably need a raw IR phototransistor and your own 1.2 kHz analog filter, rectifier, low-pass filter, and comparator.  You can probably do all that with a few op-amps.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Grumpy_Mike
Quote
Don't forget the amplifier after the filter but before the rectifier. It is this that gives you and increase in distance.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
