Loading...
Pages: [1] 2   Go Down
Author Topic: Dynamically get the model of Arduino  (Read 1138 times)
Argentina
Offline Offline
Newbie
View Profile
Hi! I'm working in a application to communicate with my Arduino from Python (using USB interface). It's working on the Arduino UNO. Now I want to make it work on a Mega, and I'm facing a problem: the Mega has many more things that the Uno. If a Python program is written for a Mega, but connected to an Uno, it should report an error!. Or work until the Python program try to use something that the connected Arduino doesn't have (I mean, let it work if the program try to use digital pin 1 to 13, but raise an Exception if try to use digital pin 20).
One possible solution: is there any way to check if the hardware has a given port? I would like to do something like:
Code:
if(digitalPortExists(99)) {
  // OK. It's safe to use digital port 99
  // Send ERROR message to PC.
Another way would be to send, from the Arduino, what kind of Arduino the program is running on. With this information, I would be able to do the check in Python. And I think this would be better, since knowing the Arduino model, I would be able to check digital and analog pins, what pins have support for PWM, how many interrupts, etc. Something like:
Code:
char* model = getArduinoMode();
Serial.write(model);
The project I'm working on is at https://github.com/hgdeoro/py-arduino-proxy. The project is a "low level" communication library, but I've crated a simple UI to better illustrate the possibilities:
Thanks in advance!
Horacio
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
When python is talking to your Arduino you have defined an protocol between these two. You should add a getType request in the protocol and your application  on the Arduino can return its type as follows:
Code:
#include "avr_cpunames.h"
char * getType()
  return _AVR_CPU_NAME_;
  Serial.println(getType());
void loop() {}
check - C:\Program Files (x86)\arduino-0022\libraries\ArduinoTestSuite -
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
That won't necessarily work - the DIP package ATMega328P does not include some of the pins that the SMD package does, so the Arduino Nano has a few extra pins than the Arduino UNO or Duemilanove, while returning the same value for _AVR_CPU_NAME_.  Of course, you could just sacrifice these pins and live with it =).
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
@Aeternalus
Probably your right, an alternative is to define a string yourself, drawback is that you might need to change it if your code is uploaded to a slightly different platform.
Code:
#define _TYPE_ "ATMega328P MHZ16 ANA6 DIG13 PWM4 HWS1 I2C1 SPI1"
char * getType()
  return _TYPE_;
void loop() {}
Or even more work
Code:
struct ArduinoType
  char name[20];
  uint8_t analogPins;
  uint8_t digitalPins;
  uint8_t pwmPins;
  uint8_t voltage;      // whole part only
  uint16_t RAM;         // KB
  uint16_t EEPROM;   // KB
  uint8_t SerialPorts;
  uint8_t clockSpeed;
} myArduino = { _AVR_CPU_NAME_, 6, 13, 4, 5, ... }
Logged
Rob Tillaart
Argentina
Offline Offline
Newbie
View Profile
Thank you for your replies! I like the _AVR_CPU_NAME_ option (less work!), but I'm looking for a way to avoid sacrifice any port. I'll test the struct option.
Thanks again!
Horacio
Logged
Argentina
Offline Offline
Newbie
View Profile
For digital pins, I've found how to validate if a given pin is valid (pinMode() function in arduino-0022/hardware/arduino/cores/arduino/wiring_digital.c):
Code:
uint8_t port = digitalPinToPort(pin);
if (port == NOT_A_PIN) return;
digitalPinToPort() and NOT_A_PIN are defined in pins_arduino.c, I think I should be safe to use it.
Logged
Argentina
Offline Offline
Newbie
View Profile
I've tested digitalPinToPort() and it isn't working...
Code:
    int pin = atoi(received_parameters[1]);
    if (port == NOT_A_PIN) {
        send_invalid_parameter_response(1);
        return;
I've sent "99" as pin value, and no error was reported :-(
Code:
./bin/ipython_session.py /dev/ttyACM0
Launching IPython shell...
Available variables:
 - proxy: the ArduinoProxy instance.
 - options, args: parsed argument options.
To import ArduinoProxy class:
>>> from arduino_proxy import ArduinoProxy
Enter 'quit()' to exit.
In [1]: proxy.ping()
Out[1]: 'PING_OK'
In [2]: proxy.digitalRead(12)
Out[2]: 1
In [3]: proxy.digitalRead(99)
Out[3]: 1
Logged
Argentina
Offline Offline
Newbie
View Profile
Returning _AVR_CPU_NAME_ to Python was very easy to implement. Will use that at least for doing some controls. Thanks again!
Code:
In [1]: proxy.getAvrCpuType()
Out[1]: 'ATmega328P'
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
digitalPinToPort(pin) is a macro reading from array/memory, any number greater than the arraysize is meaningless as it reads from somewhere.
Logged
Rob Tillaart
Argentina
Offline Offline
Newbie
View Profile
Ahhh... thank you! To fix that, I've tried to use sizeof() with the array digital_pin_to_port_PGM (the macro uses this array), to verify if the pin points to an array element, but haven't worked.
I get the error when try to compile:
py_arduino_proxy.cpp: In function ‘void setup()’:
py_arduino_proxy.cpp:812: error: invalid application of ‘sizeof’ to incomplete type ‘const uint8_t []’
I think I'll stick to the _AVR_CPU_NAME_ solution...
Thanks again!
Horacio
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
In the "avr_cpunames.h" several types are mapped to a single name, you can improve on that.
What do you think of creating an include file "ArduinoType.h" like this?   // !! the numbers are not checked !!
Maybe ArduinoCapabilities.h is better name? other?
Code:
//    FILE: arduinoType.h
// VERSION: 0.1.00
//    DATE: 2011-05-18
// PURPOSE: Specify Arduino Capabilities
//   URL: http://arduino.cc/forum/index.php/topic,61528.msg445142.html#msg445142
// HISTORY:
// 2011-05-18 initial version
#ifndef ArduinoType_h
#define ArduinoType_h
#include "WProgram.h"
#include "inttypes.h"
struct ArduinoType
  char name[20];
  uint8_t analogPins;
  uint8_t digitalPins;  // excl analog pins that can be used as digital ones
  uint8_t pwmPins;
  uint16_t RAM;         // KB
  uint8_t clockSpeed;   // *10e6
thisArduino =
#if defined (__AVR_AT94K__)
  _AVR_CPU_NAME_ , 1, 2, 3, 5, 8, 2, 1, 8 }; // not checked
#elif defined (__AVR_ATmega328P__)
  _AVR_CPU_NAME_ , 6, 13, 4, 5, 32, 2, 1, 16}; // not checked
#elif defined (__AVR_ATmega644__)
#elif defined (__AVR_ATmega1280__)
#elif defined (__AVR_ATmega2560__)
// optional more
#else
  "UNKNOWN" , 0, 0, 0, 0, 0, 0, 0, 0}; //  checked
#endif
#endif // ArduinoType_h
// END OF FILE
so you can do
Code:
#include "arduinoType.h"
  Serial.println(thisArduino.name);
  Serial.println(thisArduino.analogPins, DEC);
  Serial.println(thisArduino.digitalPins, DEC);
  Serial.println(thisArduino.pwmPins, DEC);
  // etc
« Last Edit: May 18, 2011, 03:36:14 pm by robtillaart » Logged
Rob Tillaart
Argentina
Offline Offline
Newbie
View Profile
I'll try the ArduinoType struct, validate the pins in the 'python' side, and make this validation optional (turned on by default)...
Thanks robtillaart!
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Hi Horacio,
Beware this is still not 100% but for now I think it is quite usable, once filled in it will fill the struct compile time.
Are there fields missing?
Rob
Logged
Rob Tillaart
Argentina
Offline Offline
Newbie
View Profile
I'd like to have one more thing: pwmPins  "list" instead of the "number of". With this "list", I'd be able to validate analogWrite(). I'll try to do that, maybe with a "bitmap" (for size concerns). With a 64bits, 8 bytes array, it should be doable. Or may be less bits, since PWM support is at the "lower" pins... the Arduino Mega, Uno, etc. have PWM support on pins less or equals to 13... with 2 bytes will be fine. Something like:
Code:
// VERSION: 0.1.00
//    DATE: 2011-05-18
// HISTORY:
struct ArduinoType
  char board_name[20];
  uint8_t analogPins;
  uint16_t pwmPinsBitmap;
  uint16_t RAM;         // KB
thisArduino =
  _AVR_CPU_NAME_ , 1, 2, 0x00, 5, 8, 2, 1, 8 }; // not checked
  // PWM pins on Uno: 3, 5, 6, 9, 10, 11
  _AVR_CPU_NAME_ , 6, 13, 0x00 | 1<<3 | 1<<5 | 1<<6 | 1<<9 | 1<<10 | 1<<11, 5, 32, 2, 1, 16}; // not checked
  _AVR_CPU_NAME_ , 6, 13, 0x00, 5, 32, 2, 1, 16}; // not checked
  // PWM pins on Mega: 2 to 13
  _AVR_CPU_NAME_ , 6, 13, 0x00 | 1<<2 | 1<<3 | 1<<4 | 1<<5 | 1<<6 | 1<<7 | 1<<8 | 1<<9 | 1<<10 | 1<<11 | 1<<12 | 1<<13, 5, 32, 2, 1, 16}; // not checked
// optional more
#else
  "UNKNOWN" , 0, 0, 0x00, 0, 0, 0, 0, 0}; //  checked
#endif
// END OF FILE
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Good idea the PWM bitmap! however is 16 bits enough?
Logged
Rob Tillaart
Pages: [1] 2   Go Up
Print
Jump to:
