hey peeps,
im undergoing a project installation that requires the movement of two servos (180deg servo) , by a single infrared sensor (sharp analog infrared sensor).
In essence, two servos are attached to two different mechanical systems that both produce two different moving outcomes (done by each servo having different angle movements outcomes when the sensor is triggered). Instead of using two sensors, i was wondering if it is possible for the arduino to read a single analog infrared sensor then trigger each servo (with its own angle) at different promixities?
Through experimentation have made one servo move to its particular angle when activated by the sensor.
This is the code (for 1 servo, for 2nd servo the angles have been calibrated)
____________
#include <Servo.h>
////servo layer 1-2////
Servo myservo;
int potPin = 0; //analog pin used to connect the sensor
int ledPin = 9; //select pin for the servo
int val = 0; //variable to read the value from the analog pin
myservo.attach(9); //set up the servo as usual
pinMode(ledPin, OUTPUT); //variable to store the value coming from the sensor
Serial.begin(9600); //for watching the speeds in the serial monitor
val = analogRead(potPin); // read the value from the sensor
val = map(val,0,1023,0,179);
if (val>79) myservo.writeMicroseconds(1000);
else if (val<80) myservo.writeMicroseconds(1500);
//set servo to mid-point
Serial.println(val);
delay(1);
_______________
And furthermore, an attempt to implement the second servo
_______________
#include <Servo.h>
Servo myservo1; //first servo
Servo myservo2; //layer 2-3 servo
int potPin = 0; //analog pin ued to connect the sensor
myservo1.attach(9); //set up the servo as usual first servo
myservo2.attach(
; //layer 2-3 servo
val = map(val,0,200,0,179);
if (val>79) myservo1.writeMicroseconds(900); //set servo to mid-point
else if (val<80) myservo1.writeMicroseconds(2000);
delay(1);
if (val>79) myservo2.writeMicroseconds(1000); //set servo to mid-point
else if (val<80) myservo2.writeMicroseconds(1500);
delay(1);
_______________
I have concerns that i may be heading in a totally wrong direction with regards to the coding (writeMicroseconds command), however
any suggestions would be appreciated, but please keep it in mind what it asked in the installation
Peace,
Atomicdog
