Loading...
Pages: 1 2 [3]   Go Down
Author Topic: VarSpeedServo - a modified Servo library with speed control  (Read 7255 times)
Offline Offline
Newbie
View Profile
I just installed the library and referenced it. Upon build I get the following compile error. I use the latest Arduino 1.0 compiler running on Windows 2008 server with Arduino MEGA2560. Any thoughts?
Code:
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:56:23: error: WProgram.h: No such file or directory
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp: In function 'void handle_interrupts(timer16_Sequence_t, volatile uint16_t*, volatile uint16_t*)':
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:91: error: 'LOW' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:91: error: 'digitalWrite' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:122: error: 'HIGH' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:122: error: 'digitalWrite' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:126: error: 'clockCyclesPerMicrosecond' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp: At global scope:
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:266: error: 'boolean' does not name a type
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp: In constructor 'VarSpeedServo::VarSpeedServo()':
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:283: error: 'clockCyclesPerMicrosecond' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp: In member function 'uint8_t VarSpeedServo::attach(int, int, int)':
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:297: error: 'OUTPUT' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:297: error: 'pinMode' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:304: error: 'isTimerActive' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp: In member function 'void VarSpeedServo::detach()':
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:315: error: 'isTimerActive' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp: In member function 'void VarSpeedServo::write(int)':
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:326: error: 'map' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp: In member function 'void VarSpeedServo::writeMicroseconds(int)':
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:334: error: 'byte' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:334: error: expected `;' before 'channel'
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:335: error: 'channel' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:343: error: 'clockCyclesPerMicrosecond' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp: In member function 'void VarSpeedServo::slowmove(int, uint8_t)':
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:377: error: 'map' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:380: error: 'byte' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:380: error: expected `;' before 'channel'
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:381: error: 'channel' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:388: error: 'clockCyclesPerMicrosecond' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp: In member function 'int VarSpeedServo::read()':
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:407: error: 'map' was not declared in this scope
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp: In member function 'int VarSpeedServo::readMicroseconds()':
C:\Program Files (x86)\arduino-1.0\libraries\VarSpeedServo\VarSpeedServo.cpp:414: error: 'clockCyclesPerMicrosecond' was not declared in this scope
gives me the same error. Using 1.0.1 and installed it in right directory
*edit: replaced WProgram.h in the varspeedservo.cpp to Arduino.h
« Last Edit: November 24, 2012, 01:09:49 pm by hangtime21 » Logged
Offline Offline
Newbie
View Profile
I had the same problem with a Uno rev.3. Same solution. In VarSpeedServo.cpp, replace  #include <WProgram.h>  with  #include <Arduino.h> .
Logged
my own world
Offline Offline
Newbie
We are all geeks!
View Profile
I've used the varspeedservo library in Arduino 1.0. I just changed WProgram.h to Arduino.h in one of the library files.
Thank you... I forgot about this little trick to get the libraries going with the 1.0+ IDE
I was beating my head for an hour,wondering what I am doing wrong,  before I read your post.
Logged
Signatures are stupid!
Offline Offline
Newbie
View Profile
I am builduing a quadcopter with my arduino uno and using a bluetooth setup.  I just need help with this speed control.
Logged
my own world
Offline Offline
Newbie
We are all geeks!
View Profile
I seem to notice getting full range out of the servo seems tricky..
Maybe it is my hobby people servos but unless I put:
servo1.attach(5,555,180); this is the only way I can get 180 degrees.
but the speeds work fine.
I am trying to make a pan and tilt camera for on top of a rover.
Logged
Pages: 1 2 [3]   Go Up
Print
Jump to:
