Loading...
Pages: [1] 2   Go Down
Author Topic: Making a button switch codes?  (Read 628 times)
Offline Offline
Newbie
View Profile
I was wondering if there is a way to make a button switch from one code to the other.  I'm trying to make a lamp that switches from a potentiometer controlling an RGB LED to a rainbow mode that repeats itself when I press the button.  Any Ideas that may get me jump started on doing this would be great.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Sure. You know how to connect the switch, right? You know how to read when the switch is pressed, right?
Create a variable to count the number of presses. When the number is even, do one thing. When it is odd, do the other thing.
Logged
Offline Offline
Newbie
View Profile
[/quote]
How do I do that?
Logged
Grand Blanc, MI, USA
Offline Offline
Edison Member
"We're a proud service of the Lost Electricity Reclamation Agency"
View Profile
WWW
How do I do that?
I might check out some of the tutorials like this one and this one.
Logged
Get the infamous "One Million Ohms" board at tINDIE.com: http://tinyurl.com/BuyMohms
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
Code:
if (myVariable & 1){
  // do the odd thing
  //do the even thing
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
I made this sketch I don't know if its right but i get an error expected '{' at the end of input and highlights "void h2rgb(float H, int &R, int &G, int &B)"
  • int buttonPin = 2;
    int buttonState = 0;
    int potpin = 3;
    int rpin = 9;
    int gpin = 10;
    int bpin = 11;
    float h;
    int h_int;
    int r=0, g=0, b=0;
    int val = 0;
    void h2rgb(float h, int &R, int &G, int &B);
    // Length of time we spend showing each color
    const int DISPLAY_TIME = 100; // In milliseconds
      pinMode(rpin, OUTPUT);
      pinMode(gpin, OUTPUT);
      pinMode(bpin, OUTPUT);
      pinMode(buttonPin, INPUT);
      buttonState = digitalRead(buttonPin);
      if (buttonState ==HIGH) {
      // Cycle color from red through to green
      // (In this loop we move from 100% red, 0% green to 0% red, 100% green)
      for (g = 0; g <= 255; g+=5) {
            r = 255-g;
            analogWrite(gpin, g);
            analogWrite(rpin, r);
            delay(DISPLAY_TIME);
      // Cycle color from green through to blue
      // (In this loop we move from 100% green, 0% blue to 0% green, 100% blue)
      for (b = 0; b <= 255; b+=5) {
            g = 255-b;
            analogWrite(bpin, b);
      // Cycle cycle from blue through to red
      // (In this loop we move from 100% blue, 0% red to 0% blue, 100% red)
      for (r = 0; r <= 255; r+=5) {
            b = 255-r;
    else {
       val=analogRead(potpin);    // Read the pin and display the value
      //Serial.println(val);
      h = ((float)val)/1024;
      h_int = (int) 360*h;
      h2rgb(h,r,g,b);
      Serial.print("Potentiometer value: ");
      Serial.print(val);
      Serial.print(" = Hue of ");
      Serial.print(h_int);
      Serial.print("degrees. In RGB this is: ");
      Serial.print(r);
      Serial.print(" ");
      Serial.print(g);
      Serial.print(" ");
      Serial.println(b);
    void h2rgb(float H, int &R, int &G, int &B) {
      int var_i;
      float S=1, V=1, var_1, var_2, var_3, var_h, var_r, var_g, var_b;
      if ( S == 0 )                       //HSV values = 0 ÷ 1
        R = V * 255;
        G = V * 255;
        B = V * 255;
        var_h = H * 6;
        if ( var_h == 6 ) var_h = 0;      //H must be < 1
        var_i = int( var_h ) ;            //Or ... var_i = floor( var_h )
        var_1 = V * ( 1 - S );
        var_2 = V * ( 1 - S * ( var_h - var_i ) );
        var_3 = V * ( 1 - S * ( 1 - ( var_h - var_i ) ) );
        if      ( var_i == 0 ) {
          var_r = V     ;
          var_g = var_3 ;
          var_b = var_1 ;
        else if ( var_i == 1 ) {
          var_r = var_2 ;
          var_g = V     ;
          var_b = var_1 ;
        else if ( var_i == 2 ) {
          var_r = var_1 ;
          var_g = V     ;
          var_b = var_3 ;
        else if ( var_i == 3 ) {
          var_r = var_1 ;
          var_g = var_2 ;
          var_b = V     ;
        else if ( var_i == 4 ) {
          var_r = var_3 ;
          var_g = var_1 ;
          var_b = V     ;
        else                   {
          var_r = V     ;
          var_g = var_1 ;
          var_b = var_2 ;
        R = (1-var_r) * 255;                  //RGB results = 0 ÷ 255
        G = (1-var_g) * 255;
        B = (1-var_b) * 255;
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
You have:
Code:
void h2rgb(float H, int &R, int &G, int &B);
It should be:
Code:
Logged
Offline Offline
Newbie
View Profile
alright I got this but all it says is error compiling    undefined reference to h2rgb(float, int&, int&, int&)'
int buttonPin = 2;
int potpin = 3;
int rpin = 9;
int gpin = 10;
int bpin = 11;
float h;
int h_int;
int r=0, g=0, b=0;
int val = 0;
        r = 255-g;
        g = 255-b;
        b = 255-r;
else {
  h2rgb(h,r,g,b);
  Serial.print(val);
  Serial.print(r);
  Serial.print(" ");
  Serial.print(g);
  Serial.print(" ");
  Serial.println(b);
  int var_i;
    r = V * 255;
    g = V * 255;
    b = V * 255;
    var_h = h * 6;
    if      ( var_i == 0 ) {
      var_r = V     ;
      var_g = var_3 ;
      var_b = var_1 ;
      var_r = var_2 ;
      var_g = V     ;
      var_b = var_1 ;
      var_r = var_1 ;
      var_g = V     ;
      var_b = var_3 ;
      var_r = var_1 ;
      var_g = var_2 ;
      var_b = V     ;
      var_r = var_3 ;
      var_g = var_1 ;
      var_b = V     ;
    else                   {
      var_r = V     ;
      var_g = var_1 ;
      var_b = var_2 ;
    r = (1-var_r) * 255;                  //RGB results = 0 ÷ 255
    g = (1-var_g) * 255;
    b = (1-var_b) * 255;
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
You need to write h2rgb - it doesn't exist in your code.
Logged
Offline Offline
Newbie
View Profile
how do I write h2rgb
and where do I put it I cant figure it out
« Last Edit: May 18, 2011, 06:38:45 pm by Agent_47 » Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
What does h2rgb do?
Logged
Offline Offline
Newbie
View Profile
lol i don"t even know, but when I deleted it, the code works. thanks for pointing that out.
Logged
Offline Offline
Newbie
View Profile
I made this sketch it loads fine but I'm not getting a response at all from the chip. What did I do wrong in it.
int buttonPin = 2;
int potpin = 3;
int rpin = 9;
int gpin = 10;
int bpin = 11;
float h;
int h_int;
int r=0, g=0, b=0;
int val;
int val2;
int buttonState;
int lightMode = 0;
 val = digitalRead(buttonPin);      // read input value and store it in val
  delay(10);                         // 10 milliseconds is a good amount of time
  val2 = digitalRead(buttonPin);     // read the input again to check for bounces
  if (val == val2) {                 // make sure we got 2 consistant readings!
    if (val != buttonState) {          // the button state has changed!
      if (val == LOW) {                // check if the button is pressed
        if (lightMode == 0) {          // is the light off?
          lightMode = 1;
    digitalWrite(rpin, HIGH);
    digitalWrite(gpin, HIGH);
    digitalWrite(bpin, HIGH);
        r = 255-g;
        g = 255-b;
        b = 255-r;
}else {
  lightMode = 0;
    digitalWrite(rpin, LOW);
    digitalWrite(gpin, LOW);
    digitalWrite(bpin, LOW);
  Serial.print(val);
  Serial.print(r);
  Serial.print(" ");
  Serial.print(g);
  Serial.print(" ");
  Serial.println(b);
  int var_i;
    r = V * 255;
    g = V * 255;
    b = V * 255;
    var_h = h * 6;
    if      ( var_i == 0 ) {
      var_r = V     ;
      var_g = var_3 ;
      var_b = var_1 ;
      var_r = var_2 ;
      var_g = V     ;
      var_b = var_1 ;
      var_r = var_1 ;
      var_g = V     ;
      var_b = var_3 ;
      var_r = var_1 ;
      var_g = var_2 ;
      var_b = V     ;
      var_r = var_3 ;
      var_g = var_1 ;
      var_b = V     ;
    else                   {
      var_r = V     ;
      var_g = var_1 ;
      var_b = var_2 ;
buttonState = val;
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
OK, time to learn how to post code so that you don't hospitalise other forum members with sprained scrolling fingers.
When you post some code, open a code box using the # icon on the editor's toolbar, then copy your code into the space between the tags. (you can do this retrospectively, by clicking on "modify" on each of your posts, highlighting the code, then clicking the # icon. (HINT))
Now, back to the problem - what does the serial monitor show you your sketch is doing?
We can't see the output.
« Last Edit: May 19, 2011, 08:12:32 am by AWOL » Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
You have way too much code for now. You are not enabling the internal pull-up resistors. This implies that you have an external resistor connected with the switch. Is this true? Exactly how is the switch connected?
You need to learn WHEN to use { and } and when not to. You have a bunch of useless { and }.
For a beginner, which you clearly are, it is a LOT easier to see blocks of code if you put each { and } on a line by themselves, and properly indent the code in between:
Code:
if(someCondition)
   if(anotherCondition)
      // indented code
is a lot easier to follow than
Code:
if(someCondition){
if(anotherCondition) {
// indented code
Logged
Pages: [1] 2   Go Up
Print
Jump to:
