Loading...
Pages: 1 [2]   Go Down
Author Topic: Making a button switch codes?  (Read 627 times)
Offline Offline
Newbie
View Profile
OK, time to learn how to post code so that you don't hospitalise other forum members with sprained scrolling fingers.
When you post some code, open a code box using the # icon on the editor's toolbar, then copy your code into the space between the tags. (you can do this retrospectively, by clicking on "modify" on each of your posts, highlighting the code, then clicking the # icon. (HINT))
Sorry about that I was trying to figure that out but couldn't find it. thanks for the tip.
some of my files were deleted and tried to figure out my sketch but got lost so I'm starting fresh. with the original codes I used.
Here is my 3 codes, 1 is for basic button setup, the second is the controlling rgb with potentiometer, and third is just automatic rainbow fade.
I tried last time mixing them together and switching some of the words to match like GREEN_LED_PIN to gpin, or is doing that wrong.
Yes I am new and a complete noob to writing sketches, but I want to learn really bad and I really appreciate the help and patience you all give me.
What do I do exactly to get started here?
Code:
int inPin = 2;         // the number of the input pin
int outPin = 13;       // the number of the output pin
int state = HIGH;      // the current state of the output pin
int reading;           // the current reading from the input pin
int previous = LOW;    // the previous reading from the input pin
// the follow variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0;         // the last time the output pin was toggled
long debounce = 200;   // the debounce time, increase if the output flickers
  pinMode(inPin, INPUT);
  pinMode(outPin, OUTPUT);
  reading = digitalRead(inPin);
  // if the input just went from LOW and HIGH and we've waited long enough
  // to ignore any noise on the circuit, toggle the output pin and remember
  // the time
  if (reading == HIGH && previous == LOW && millis() - time > debounce) {
    if (state == HIGH)
      state = LOW;
      state = HIGH;
    time = millis();
  digitalWrite(outPin, state);
  previous = reading;
second
Code:
int potpin = 2;              // Switch connected to digital pin 2
int rpin = 9;
int gpin = 10;
int bpin = 11;
float h;
int h_int;
int r=0, g=0, b=0;
int val=0;
void h2rgb(float h, int &R, int &G, int &B);
void setup()                    // run once, when the sketch starts
  Serial.begin(9600);           // set up Serial library at 9600 bps
void loop()                     // run over and over again
  val=analogRead(potpin);    // Read the pin and display the value
  //Serial.println(val);
  h = ((float)val)/1024;
  h_int = (int) 360*h;
  h2rgb(h,r,g,b);
  Serial.print("Potentiometer value: ");
  Serial.print(val);
  Serial.print(" = Hue of ");
  Serial.print(h_int);
  Serial.print("degrees. In RGB this is: ");
  Serial.print(r);
  Serial.print(" ");
  Serial.print(g);
  Serial.print(" ");
  Serial.println(b);
  analogWrite(rpin, r);
  analogWrite(gpin, g);
  analogWrite(bpin, b);
void h2rgb(float H, int& R, int& G, int& B) {
  int var_i;
  float S=1, V=1, var_1, var_2, var_3, var_h, var_r, var_g, var_b;
  if ( S == 0 )                       //HSV values = 0 ÷ 1
    R = V * 255;
    G = V * 255;
    B = V * 255;
    var_h = H * 6;
    if ( var_h == 6 ) var_h = 0;      //H must be < 1
    var_i = int( var_h ) ;            //Or ... var_i = floor( var_h )
    var_1 = V * ( 1 - S );
    var_2 = V * ( 1 - S * ( var_h - var_i ) );
    var_3 = V * ( 1 - S * ( 1 - ( var_h - var_i ) ) );
    if      ( var_i == 0 ) {
      var_r = V     ;
      var_g = var_3 ;
      var_b = var_1 ;
    else if ( var_i == 1 ) {
      var_r = var_2 ;
      var_g = V     ;
      var_b = var_1 ;
    else if ( var_i == 2 ) {
      var_r = var_1 ;
      var_g = V     ;
      var_b = var_3 ;
    else if ( var_i == 3 ) {
      var_r = var_1 ;
      var_g = var_2 ;
      var_b = V     ;
    else if ( var_i == 4 ) {
      var_r = var_3 ;
      var_g = var_1 ;
      var_b = V     ;
    else                   {
      var_r = V     ;
      var_g = var_1 ;
      var_b = var_2 ;
    R = (1-var_r) * 255;                  //RGB results = 0 ÷ 255
    G = (1-var_g) * 255;
    B = (1-var_b) * 255;
Third
Code:
// LED leads connected to PWM pins
const int RED_LED_PIN = 9;
const int GREEN_LED_PIN = 10;
const int BLUE_LED_PIN = 11;
// Used to store the current intensity level of the individual LEDs
int redIntensity = 0;
int greenIntensity = 0;
int blueIntensity = 0;
// Length of time we spend showing each color
const int DISPLAY_TIME = 100; // In milliseconds
  // No setup required.
  // Cycle color from red through to green
  // (In this loop we move from 100% red, 0% green to 0% red, 100% green)
  for (greenIntensity = 0; greenIntensity <= 255; greenIntensity+=5) {
        redIntensity = 255-greenIntensity;
        analogWrite(GREEN_LED_PIN, greenIntensity);
        analogWrite(RED_LED_PIN, redIntensity);
        delay(DISPLAY_TIME);
  // Cycle color from green through to blue
  // (In this loop we move from 100% green, 0% blue to 0% green, 100% blue)
  for (blueIntensity = 0; blueIntensity <= 255; blueIntensity+=5) {
        greenIntensity = 255-blueIntensity;
        analogWrite(BLUE_LED_PIN, blueIntensity);
  // Cycle cycle from blue through to red
  // (In this loop we move from 100% blue, 0% red to 0% blue, 100% red)
  for (redIntensity = 0; redIntensity <= 255; redIntensity+=5) {
        blueIntensity = 255-redIntensity;
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
