Loading...
Pages: [1]   Go Down
Author Topic: questions about Arduino 0022  (Read 259 times)
North Central Massachusetts
Offline Offline
Newbie
STEM for middle schools. "How things work."
View Profile
Two questions:
1.  How do I get it to display line numbers?  The error routine references line numbers, but the window has none.
2.  How do I get it to print?  I hit print setup and it looks correct.  I hit print and I mark  ALL.  It keeps 'printing' all blank pages until I cancel the job.   My printer has been working fine.
I have Windows XP Professional SP3.
Logged
0
Offline Offline
Sr. Member
Arduino rocks
View Profile
1. You can't in the Arduino IDE - use an external editor for the file instead, it's just C++.
2. See above.  Printing appears to be broken in the current IDE.
You can use your preferred C++ code editor for Arduino - just edit the .pde file, and set 'use external editor' in the IDE to have it refresh the file before compiling and/or uploading.
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Left Far-Bottom corner does have a line counter, so you can at least move your cursor around until you find the line being referenced.
Personally, I have never found C compliers to give good line-based clues anyway.  It is generally the line with something that finally irritated them, not the line with the problem.
Logged
www.cmiyc.com - A guide to being an Enginerd
Pages: [1]   Go Up
Print
Jump to:
