Loading...
Pages: [1]   Go Down
Author Topic: [Solved] Arduino Uno on OpenSuse 11.4, anyone managed ?  (Read 1376 times)
Offline Offline
Newbie
View Profile
I just got my Arduino kit from Frtzing, looking a bit on how to install, here is what I did : (can of course also be done w/Yast
Based on infos from : http://arduino.cc/playground/Linux/OpenSUSE
#Add repo for Arduini
sudo zypper ar http://download.opensuse.org/repositories/home:/kwk:/arduino/openSUSE_11.4 Arduino
#Add repo for Ar
sudo zypper ar http://download.opensuse.org/repositories/CrossToolchain:/avr/openSUSE_11.4 Crosscompiling
#Install Arduino
sudo zypper in arduino
added myself (user) in groups uucp, lock and dialout
dmesg gave me :
[ 5716.933696] usb 1-1.2: new full speed USB device using ehci_hcd and address 6
[ 5717.020604] usb 1-1.2: New USB device found, idVendor=2341, idProduct=0001
[ 5717.020610] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=220
[ 5717.020615] usb 1-1.2: Product: Arduino Uno
[ 5717.020618] usb 1-1.2: Manufacturer: Arduino (www.arduino.cc)
[ 5717.020621] usb 1-1.2: SerialNumber: 64935343233351118110
[ 5717.021112] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
lsusb gave me :
Bus 001 Device 007: ID 2341:0001
launched arduino, it didn't see ttyACM0, so based on an info from http://www.arduino.cc/en/Guide/Troubleshooting#toc1
I symlinked
ln -s /dev/ttyACM0 /dev/ttyUSB0
Then Arduino saw it, but I tried to upload a test file and got the message :
Binary sketch size: 1978 bytes (of a 32256 byte maximum)
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
Got an info from http://www.arduino.cc/en/Guide/Troubleshooting#toc23  that I may be using a wrong version of avrdude !?
I used the avrdude from the same repo as Arduino :-/
What should I do ? Anyone got it working on OpenSuse 11.4 ? Any help would be appreciated :-)
« Last Edit: May 31, 2011, 01:20:11 pm by atuor » Logged
"The old Europe"
Offline Offline
Edison Member
Bootloaders suck!
View Profile
WWW
Well, what version of avrdude is it? 5.10 should be ok.
What device signature do you get?
Code:
Expected signature for ATMEGA328P is 1E 95 0F
Code:
avrdude -p atmega328p -P /dev/ttyUSB0 -v -c arduino 2>&1 | grep "signature"
Logged
• Upload doesn't work? Do a loop-back test.
• There's absolutely NO excuse for not having an ISP!
• Your AVR needs a brain surgery? Use the online FUSE calculator.
My projects: RGB LED matrix, RGB LED ring, various ATtiny gadgets...
• Microsoft is not the answer. It is the question, and the answer is NO!
Offline Offline
Newbie
View Profile
I do get this
avrdude: Device signature = 0x1e950f
I tried to reproduce it in a VM since I crashed my test environment  partition, but on a VM I get a 'programmer not responding' although , probably an issue w/ the Virtual USB.
Anyway I installed it on phisical env. and still get the 'Invalid device signature.' :-/
Logged
"The old Europe"
Offline Offline
Edison Member
Bootloaders suck!
View Profile
WWW
Please download the arduino software .tgz-file from THIS site and test again. It is only a few MB.
Corrected the .zip vs .tgz issue ;-)
« Last Edit: May 21, 2011, 11:40:39 am by madworm » Logged
Offline Offline
Newbie
View Profile
ooops sorry, what do you mean by by THIS,site ? there is this one http://arduino.googlecode.com/files/arduino-0022.tgz , or do you mean another ? the zip file is for Windows, if you could confirm the right link would be perfect :-)
Logged
"The old Europe"
Offline Offline
Edison Member
Bootloaders suck!
View Profile
WWW
Well, on arduino.cc there is a download link for linux 32bit ;-)
And yes, it links to google code.
Logged
Offline Offline
Newbie
View Profile
Hi, Thans for that, I got it from the site :-) but as I can see, this is not enough, it needs other packages to work, it tells me 'cannot find avr-g++' so I suppose bin-utils and some others., but which packages below are necessary ? Don't know what is provided in the download. I got this repois it OK ? I found it on this site (wiki) , or any other better ?  Thanks :-)
   avr-example                    | package    | 1.2-1.1             | noarch | Crosscompiling
  | avr-example                    | srcpackage | 1.2-1.1             | noarch | Crosscompiling
  | avr-libc                       | package    | 1.7.1-1.1           | noarch | Crosscompiling
  | avr-libc                       | srcpackage | 1.7.1-1.1           | noarch | Crosscompiling
  | avrdude                        | package    | 5.10-42.1           | i586   | Crosscompiling
  | avrdude                        | package    | 5.10-2.3            | i586   | openSUSE-11.4-Oss
  | avrdude                        | srcpackage | 5.10-42.1           | noarch | Crosscompiling
  | avrdude-debuginfo              | package    | 5.10-42.1           | i586   | Crosscompiling
  | avrdude-debugsource            | package    | 5.10-42.1           | i586   | Crosscompiling
  | cross-avr-binutils             | package    | 2.19.1-32.1         | i586   | Crosscompiling
  | cross-avr-binutils             | srcpackage | 2.19.1-32.1         | noarch | Crosscompiling
  | cross-avr-binutils-debuginfo   | package    | 2.19.1-32.1         | i586   | Crosscompiling
  | cross-avr-binutils-debugsource | package    | 2.19.1-32.1         | i586   | Crosscompiling
  | cross-avr-gcc                  | package    | 4.3.3_20100125-27.1 | i586   | Crosscompiling
  | cross-avr-gcc                  | srcpackage | 4.3.3_20100125-27.1 | noarch | Crosscompiling
  | cross-avr-gcc-debuginfo        | package    | 4.3.3_20100125-27.1 | i586   | Crosscompiling
  | cross-avr-gcc-debugsource      | package    | 4.3.3_20100125-27.1 | i586   | Crosscompiling
  | cross-avr-insight              | package    | 6.8.1-34.1          | i586   | Crosscompiling
  | cross-avr-insight              | srcpackage | 6.8.1-34.1          | noarch | Crosscompiling
  | cross-avr-insight-debuginfo    | package    | 6.8.1-34.1          | i586   | Crosscompiling
  | cross-avr-insight-debugsource  | package    | 6.8.1-34.1          | i586   | Crosscompiling
  | cross-avr-insight-lang         | package    | 6.8.1-34.1          | noarch | Crosscompiling
  | simulavr                       | package    | 0.1.2.6-4.3         | i586   | Crosscompiling
  | simulavr                       | srcpackage | 0.1.2.6-4.3         | noarch | Crosscompiling
  | simulavr-debuginfo             | package    | 0.1.2.6-4.3         | i586   | Crosscompiling
  | simulavr-debugsource           | package    | 0.1.2.6-4.3         | i586   | Crosscompiling
  | uisp             | package    | 20050207suse-151.1 | i586   | Crosscompiling
  | uisp             | package    | 20050207suse-147.1 | i586   | openSUSE-11.4-Oss
  | uisp             | srcpackage | 20050207suse-151.1 | noarch | Crosscompiling
  | uisp-debuginfo   | package    | 20050207suse-151.1 | i586   | Crosscompiling
  | uisp-debugsource | package    | 20050207suse-151.1 | i586   | Crosscompiling
Logged
"The old Europe"
Offline Offline
Edison Member
Bootloaders suck!
View Profile
WWW
The minimum you need is:
avr-libc
cross-avr-gcc
cross-avr-binutils
avrdude
Logged
Offline Offline
Newbie
View Profile
Great, seems to work :-) at least it said Done uploading.
I'll do some tests and make sure it works, then do a script &/or process with exact sequential steps to install it on OpenSuse 11.4 and post it here and/or a blog ;-)
I'll also try it on a Virtual Box, see if it works too.
Again many thanks for your help 'madworm' ;-)
Logged
Offline Offline
Newbie
View Profile
Just tried that same procedur with a Virtual Box image of OpenSuse 11.4, still need to find out why it says the board is not responding when trying to upload
Logged
Offline Offline
Newbie
View Profile
Tested it now and it works.
So basically, one could make a script or copy/paste the following commands
# Go to Home directory
cd
#Download the Linux package
wget http://arduino.googlecode.com/files/arduino-0022.tgz
#Extract
tar -zxvf arduino-0022.tgz
# Add Repo for crosscompiler
sudo zypper ar http://download.opensuse.org/repositories/CrossToolchain:/avr/openSUSE_11.4/CrossToolchain:avr.repo
#Install (confirm repo import and accept installation when asked)
sudo zypper in avr-libc cross-avr-gcc cross-avr-binutils avrdude
# Add to Groups lock and dialout
sudo /usr/sbin/usermod -A lock `whoami`
sudo /usr/sbin/usermod -A dialout `whoami`
Logout and login again, that's it, it worked fine for me  smiley
Logged
"The old Europe"
Offline Offline
Edison Member
Bootloaders suck!
View Profile
WWW
Basic computer literacy is such a nice thing.
Happy coding.
Logged
Pages: [1]   Go Up
Print
Jump to:
