Loading...
Pages: [1]   Go Down
Author Topic: How to use DS2431 i-wire 1K EEPROM (refer to old forum)  (Read 2182 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I'd like to write data to the Maxim DS2431 EEPROM. The search forwarded me to following posts:
http://arduino.cc/forum/index.php/topic,18198.msg132458.html#msg132458
The code that FredPlais posted works perfect for reading the EEPROM but I don't know how to write data to it. I think the command WriteReadScratchPad(...) followed by CopyScratchPad(...) stores data to the DS2431 but I don't really know how to use it. Here again the code:
Code:
#include <OneWire.h>
OneWire  ds(2);    // 1-wire on pin 2
byte     addr[8];  // Contains the eeprom unique ID
void setup(void)
void loop(void)
  byte i;
  byte dat[13];
  SearchAddress(addr);
  dat[0] = 0x01;
  dat[1] = 0x02;
  dat[2] = 0x03;
  dat[3] = 0x04;
  dat[4] = 0x05;
  dat[5] = 0x06;
  dat[6] = 0x07;
  dat[7] = 0x08;
  WriteRow(0,dat);
  ReadAllMem();    //print all mem content
  while(1);
void SearchAddress(byte* address) //Search for address and confirm it
  int i;
  if ( !ds.search(address))
    Serial.print("No device found.\n");
    ds.reset_search();
    delay(250);
    return;
  Serial.print("ADDR= ");
  for( i = 0; i < 8; i++)
    Serial.print(address[i], HEX);
    Serial.print(" ");
  if ( OneWire::crc8( address, 7) != address[7])
      Serial.print("CRC is not valid, address is corrupted\n");
      return;
  if ( address[0] != 0x2D)
      Serial.print("Device is not a 1-wire Eeprom.\n");
      return;
void WriteReadScratchPad(byte TA1, byte TA2, byte* data)
  int i;
  ds.reset();
  ds.select(addr);
  ds.write(0x0F,1);  // Write ScratchPad
  ds.write(TA1,1);
  ds.write(TA2,1);
  for ( i = 0; i < 8; i++)
    ds.write(data[i],1);
  ds.reset();
  ds.select(addr);
  ds.write(0xAA);         // Read Scratchpad
  for ( i = 0; i < 13; i++)
    data[i] = ds.read();
void CopyScratchPad(byte* data)
  ds.reset();
  ds.select(addr);
  ds.write(0x55,1);  // Copy ScratchPad
  ds.write(data[0],1);
  ds.write(data[1],1);  // Send TA1 TA2 and ES for copy authorization
  ds.write(data[2],1);
  delay(25); // Waiting for copy completion
  //Serial.print("Copy done!\n");
void ReadAllMem()
  int i;
  ds.reset();
  ds.select(addr);
  ds.write(0xF0,1);  // Read Memory
  ds.write(0x00,1);  //Read Offset 0000h
  ds.write(0x00,1);
  for ( i = 0; i < 128; i++) //whole mem is 144
    Serial.print(ds.read(), HEX);
    //Serial.print(" ");
void WriteRow(byte row, byte* buffer)
  int i;
  if (row < 0 || row > 15) //There are 16 row of 8 bytes in the main memory
    return;                //The remaining are for the 64 bits register page
  WriteReadScratchPad(row*8, 0x00, buffer);
  /*  Print result of the ReadScratchPad
    Serial.print(buffer[i], HEX);
    Serial.print(" ");
  CopyScratchPad(buffer);
I hope you can help me solving this probblem.
Thanks in advance.
Tiesl
Logged
Pages: [1]   Go Up
Print
Jump to:
