Topic: Powering a Servo Motor (Read 924 times) previous topic - next topic
sk8er
Hey guys,
   Just wondering if i powered the arduino with a 9V Lithium Battery (input)
   then from the arduino's 5V and ground, connect a 1.5V AA Battery
   then from 1.5V AA connect a Servo Motor, would that mean the Servo would be given 6.5V?
I made a image representation to show what i mean better-
http://img261.imagevenue.com/img.php?image=804004504_Servo_122_170lo.bmp
Also did i connect the positive and negative wires to the AA battery properly?
Thanks a bunch guys
johnwasser
You connected the 1.5V battery ACROSS the 5V.  Not good.
Connect +5 to the - side of the battery and the + side of the battery to the power pin of the servo.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
MarkT
Use a separate power supply for servos and other motors - don't share with the Arduino's logic supply.
A servo is basically a motor.  Motors generate current spikes at turn-on of several amps (overloads the onboard regulator and crow-bars the supply rail reseting the Arduino), and can produce inductive voltage spikes capable of trashing semiconductors if you are unlucky (perhaps this is less a problem with a servo than a bare motor).
