Minnesota!
Offline
Sr. Member
I'm on YouTube! Search AKSoapy29
« on: May 20, 2011, 09:53:56 pm » |
Hello! I just got my first proximity card reader today, and I have absolutely no clue how to hook it up. It's a HID ProxPoint 6005. Here are the pins:
Red- 5-16 Volts dc Black- ground Green- data0/data White- data1/clock Drain- shield ground Orange- green led Brown- red led Yellow- beep control Blue- hold Violet- card present
If someone could please help me set this up with my Arduino, that would be great! I don't have a card because I lost it. I'll try to find it soon.
Thanks, -Soapy29
Logged
Massachusetts, USA
Offline
Tesla Member
« Reply #1 on: May 20, 2011, 10:09:12 pm » |
The data pins are either data0 and data1 for Weigand output or a data an clock pin which will work like an SPI bus master.
Weigand pulses the data0 pin for a 0 bit and the data1 pin for a 1 bit.
The other format you are probably supposed to sample the data line on the falling or rising edge of the clock line pulses. The easiest way to read it is to hook the clock line to an interrupt pin and sample the data line in the ISR.
Logged
Minnesota!
Offline
Sr. Member
« Reply #2 on: May 21, 2011, 08:48:02 am » |
I'm a noob. I barely got what you said.
Logged
Minnesota!
Offline
Sr. Member
« Reply #3 on: May 21, 2011, 09:55:32 am » |
Oh. I've seen people plug a wire strait into the tx port before. So would I tie the data0 and data1 together?
Logged
Massachusetts, USA
Offline
Tesla Member
« Reply #4 on: May 21, 2011, 05:48:02 pm » |
No. That will not work.
Logged
Minnesota!
Offline
Sr. Member
« Reply #5 on: May 21, 2011, 06:00:35 pm » |
So I take data0, plug that into dig3, and take data1, and plug that into dig4, right? Then what. Oh and if I apply power to it, and I scn a card, the light turns green and beeps.
Logged
Massachusetts, USA
Offline
Tesla Member
« Reply #6 on: May 21, 2011, 06:07:27 pm » |
Not sure what you mean by 'dig3' and 'dig4'. Read up on interrupts: http://www.arduino.cc/en/Reference/AttachInterruptFigure out which model you got (Weigand or data&clock). If you make a guess and get it wrong, nothing will work. Google found me a manual for the "HID ProxPoint Plus 6005" and it indicated that the model number was slightly different for the two protocols.
Logged
Minnesota!
Offline
Sr. Member
« Reply #7 on: May 21, 2011, 06:11:21 pm » |
I think it's a weigand because on the green wire it says data0/data, and on the white wire it says data1/clock. What are the difference? And dig3 it digital 3 on the Arduino. Oh, thanks for the replies.
Logged
Massachusetts, USA
Offline
Tesla Member
« Reply #8 on: May 21, 2011, 06:35:47 pm » |
Does you unit have any model number information on it?
Logged
Minnesota!
Offline
Sr. Member
« Reply #9 on: May 21, 2011, 06:47:11 pm » |
Logged
Massachusetts, USA
Offline
Tesla Member
« Reply #10 on: May 21, 2011, 07:34:59 pm » |
OK. The 6006B2B00 makes me think that you do have the Weigand model. Connect 'data0' to pin 2 (interrupt 0) and 'data1' to pin 3 (interrupt 1). volatile unsigned long tagID = 0; volatile int bitCount = 0;
void ISRone(void) { bitCount++; tagID <<= 1; tagID |= 1; }
void ISRzero(void) { bitCount++; tagID <<= 1; }
void setup() { Serial.begin(57600);
pinMode(2, INPUT); digitalWrite(2, HIGH); // Enable pull-up resistor attachInterrupt(0, ISRzero, FALLING);
pinMode(3, INPUT); digitalWrite(3, HIGH); // Enable pull-up resistor attachInterrupt(1, ISRone, FALLING);
tagID = 0; bitCount = 0; }
void loop() { if(bitCount >= 26) { Serial.println(tagID, HEX); tagID = 0; bitCount = 0; } }
Logged
Minnesota!
Offline
Sr. Member
« Reply #11 on: May 21, 2011, 07:44:00 pm » |
Alright. The serial port is all random. No two codes are alike. But it reads them. Now what?
Logged
Minnesota!
Offline
Sr. Member
« Reply #12 on: May 21, 2011, 07:45:23 pm » |
But if you scan the card and hit reset, it has the same code every time.
Logged
Massachusetts, USA
Offline
Tesla Member
« Reply #13 on: May 21, 2011, 08:16:03 pm » |
Could be the code is not 26 bits. Try this version: volatile unsigned long tagID = 0; volatile unsigned long lastBitArrivalTime; volatile int bitCount = 0;
void ISRone(void) { lastBitArrivalTime = millis(); bitCount++; tagID <<= 1; tagID |= 1; }
void ISRzero(void) { lastBitArrivalTime = millis(); bitCount++; tagID <<= 1; }
void loop() { // See if it has been more than 1/4 second since the last bit arrived if(bitCount > 0 && millis() - lastBitArrivalTime > 250) { Serial.print(bitCount, DEC); Serial.print(" bits: "); Serial.println(tagID, HEX); tagID = 0; bitCount = 0; } }
Logged
Minnesota!
Offline
Sr. Member
« Reply #14 on: May 21, 2011, 08:54:04 pm » |
It also be me using power via USB. I'll try an altronix 12v power supply. My dad who works for VTI security suggested that.
Logged
