Loading...
Pages: [1]   Go Down
Author Topic: Remote control light show!  (Read 920 times)
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
I used an IR remote control I bought to create a light show, totally customizable via the remote.
Code:
Arduino infrared remote control light show
Programmed by Dr. John Liu
Revision: 05/20/2011
Free software for educational and personal uses.
No warrantee!
Commercial use without authorization is prohibited.
Find details of my libraries and hardware or contact Dr. Liu at
http://liudr.wordpress.com/
All rights reserved.
Dependent library:
Ken Shirriff's IRremote library
#include <IRremote.h>
#define myClockPin 10  // The clock pin for the shift registers
#define myLatchPin 11  // The latch pin for the shift registers
#define myDataPin 12  // The data pin for the shift registers
int RECV_PIN = 9;
IRrecv irrecv(RECV_PIN);
decode_results results;
  pinMode(myDataPin,OUTPUT);
  pinMode(myClockPin,OUTPUT);
  pinMode(myLatchPin,OUTPUT);
  irrecv.enableIRIn(); // Start the receiver
  static byte last; // Stores last decoded result in case the remote control sends repeat code.
  static byte current; // Stores a number to be displayed on the leds. This has nothing to do with IR remotes.
  static boolean forward_dir=true, run=false, mirror=false;
  if (irrecv.decode(&results))
    byte ret=find_key(results.value);
    if (ret==254) last=254; // flush last key with invalid if invalid input is detected in case invalid remote sends out 0xffffffff that triggers repeat.
    else // For valid for this remote
      if ((ret==255)&&(last!=254)) ret=last; // Make sure last key was not invalid before doing repeat.
      else last=ret;
      switch (ret)
        case '0':
        current=0;
        case '1':
        current=1;
        case '2':
        current=B11;
        case '3':
        current=B111;
        case '4':
        current=B1111;
        case '5':
        current=B11111;
        case '6':
        current=B111111;
        case '7':
        current=B1111111;
        case '8':
        current=B11111111;
        case 'C':
        current++;
        case 'c':
        current--;
        case 'R':
        current=~current;
        case 'P':
        if (current==0) current=255;
        else current=0;
        run=false;
        mirror=false;
        case 'v':
        current=(current>>1)|(B10000000*(bitRead(current,0)));
        case 'V':
        current=(current<<1)|(bitRead(current,7));
        case 'L':
        forward_dir=!forward_dir;
        case 'T':
        run=!run;
        case 'A':
        mirror=!mirror;
      updateLed(current);
    irrecv.resume(); // Receive the next value
  if (run)
    if (forward_dir)
      updateLed(current);
  if (mirror)
    current=~current;
    updateLed(current);
  delay(100);
char find_key(unsigned long code)
  const char codes[]="ML1470ST258-Iv369APVUCcR";
  byte col, row, temp;
  if (code==0xffffffff) return (255); // Repeat
  else if ((code&0xffff0000)==0x40bf0000)
    temp=lowByte((code-0x40BF00FF)/0x7f8)<<3;
    for (byte i=0;i<8;i++)
      bitWrite(col,i,bitRead(temp,7-i));
    row=col>>2;
    col=col&B11;
    return (codes[col*6+row]);
  else return 254; // Invalid code. Not from this remote control.
void updateLed(unsigned char first8)  // Updates LED status using shift registers.
  digitalWrite(myLatchPin, LOW);  // Disable update to the output buffers.
  shiftOut(myDataPin, myClockPin, LSBFIRST, first8);//MSBFIRST when flat LSBFIRST when standing.
  digitalWrite(myLatchPin, HIGH);  // Enable update to the output buffers.
« Last Edit: May 21, 2011, 10:56:02 pm by liudr » Logged
Pages: [1]   Go Up
Print
Jump to:
