Loading...
Pages: [1]   Go Down
Author Topic: Finally, actually got something done. Yay Me!  (Read 440 times)
CO, USA
Offline Offline
God Member
View Profile
Took me long enough to get to this, but now I'm ready to start working on code. Might even do that tonight, unless I meet the woman of dreams at the grocery store.  smiley Yeah, coding.
That's the proto-screwshield from Adafruit. I relocated the reset button, and made cutouts for the USB port and power jack. And a TI dual inverter on the breadboard.
Logged
... it is poor civic hygiene to install technologies that could someday
facilitate a police state. -- Bruce Schneier
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
What's the plate its mounted on?
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
CO, USA
Offline Offline
God Member
View Profile
Just a piece of aluminum I had laying around.
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
You mean,  a big heat sink for your offboard regulator smiley-cool
Logged
CO, USA
Offline Offline
God Member
View Profile
Heh. Well, it would certainly do that. I don't, at the moment, have anything in mind that would be dissipating a lot of heat. I'm open to suggestions, particularly if they involve laser beams.  smiley-twist
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
Laser beams, yeah, they need decent power supplies ...
Logged
CO, USA
Offline Offline
God Member
View Profile
Well, I wired it up sort of like your circuit here. Except I have a 220Ω R for the green, and a 330Ω for the red, to try to balance the intensity a bit. Kinda makes me go meh as a quickie visual indicator of over/under temp, which is where I was hoping to use this -- right now, I'm using a pot as a proxy for a temp. sensor. The shading is somewhat poorly mixed, so the yellow midpoint doesn't really look yellow.
Might be I'll need to go for a RGB LED, so I can ramp the color more clearly away from the OK state.
But I didn't let any smoke out.  smiley-razz
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
So it was a decent learning event anyway.
Logged
CO, USA
Offline Offline
God Member
View Profile
Oh yeah. I learned how much easier it is to solder SMD components when you pre-flux them. And how to load a new bootloader. And how not to hang your board by saturating the TX on the USB.  smiley-grin
Next up, one-wire.
Logged
Pages: [1]   Go Up
Print
Jump to:
