Topic: Binary Thermostat - First Project (Read 1 time) previous topic - next topic
superTallDan
This is my first arduino project.  I am not much of a programmer or an electronics guy so I am looking for some feedback.  Be as kind or cruel as you like.
FYI, I combined CIRC-02 and CIRC-10 from ladyada's experimentation kit.
Code: [Select]
int ledPins[] = {2,3,4,5,6,7,8,9,10}; // Initialize array of led pins
int temperaturePin = 0;  //Initialize temperature pin
 for(int i = 0; i < 9; i++){  //set led pins as outputs
 pinMode(ledPins[i],OUTPUT);
 float tempC = getVoltage(temperaturePin);  //getting the voltage reading from the temperature sensor
 tempC = (tempC - .5) * 100;          //converting from 10 mv per degree wit 500 mV offset
 float tempF = tempC*1.8+32;         //convert C to F
 int abstempF = fabs(tempF);         // take abs value of temp in F
 if(tempF <0)                        //light red pin if temp in F is negative
   digitalWrite(ledPins[8],HIGH);
   digitalWrite(ledPins[8],LOW);    //do not light red pin if temp in F is positive
 for(int i = 7; i >= 0; i--){
 if (pow(2,i) <= abstempF) {        //converts decimal to binary one digit at a time (assumes temp in F cannot be above 127)
   digitalWrite(ledPins[i], HIGH);
   abstempF=abstempF-pow(2,i);
   digitalWrite(ledPins[i], LOW);
float getVoltage(int pin){
return (analogRead(pin) * .004882814); //converting from a 0 to 1024 digital range
                                       // to 0 to 5 volts (each 1 reading equals ~ 5 millivolts
johnwasser
Looks pretty good.  I have a few suggestions:
Code: [Select]
//// Since these values don't change I'd recommend using the 'const' storage type.  This will allow
//// the compiler to warn you if you accidentally try to change them at run time.  It also allows for
//// better optimization because the compiler knows the values won't change.
const int ledPins[] = {2,3,4,5,6,7,8,9,10}; // Initialize array of led pins
const int temperaturePin = 0;  //Initialize temperature pin
//// Since you treat the red LED (#8) separately it might be clearer to have it in a separate declaration:
const int redLED = 10;
const int ledPins[] = {2,3,4,5,6,7,8,9}; // Initialize array of led pins
//// Rather than use a magic constant here you can use a formula that will always match the size of the
//// array of pins:
 for(int i = 0; i < (sizeof ledPins/sizeof ledPins[0]); i++)
////  Note that the 'sizeof' operator gives an answer in bytes.
//// We have to divide by the size of a single element to get the array size in elements
////  And if we treat the red LED as separate:
    pinMode(redLED, OUTPUT);
   digitalWrite(redLED,HIGH);
   digitalWrite(redLED,LOW);    //do not light red pin if temp in F is positive
////  Since HIGH and LOW are synonyms for 'true' and 'false' this can simplify to:
    digitalWrite(redLED, tempF < 0);  // Light the red LED if the temperature is below 0
//// WARNING: the pow() function works on float values and the conversions can cause round-off errors
//// For integer powers of 2 it is best to use the left shift operator <<
 if ((1<<i) <= abstempF) {        //converts decimal to binary one digit at a time (assumes temp in F cannot be above 127)
////  When you have something that looks like "variable = variable op value" you can use the C shorthand assignment operators;
////   X = X + Y;  can be written X += Y;
////   X = X - Y;  can be written X -= Y;
////   X = X * Y;  can be written X *= Y;
   abstempF -= (i<<i);
[/quote]
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
superTallDan
bsautner
Hi Dan looks good,
I was just passing by and noticed your post. If you want to have some fun with this, I have an open source project going where you could add a few lines of code to this and post your values onto the nimbits data logger system (www.nimbits.com) and your temps can be relayed onto twitter, facebook, email alerts etc.
Anyway I just noticed that your arduino code is similar enough to what I posted under the arduino example on nimbits.com and since it's connected to an ethernet shield it should be pretty easy. Just thought i'd mention it.
- Ben
