Topic: RGB Led and processing (Read 2002 times) previous topic - next topic
hitekos
Hi, i followed everything in this blog to make an rgb led but i have a problem with processing
blog : http://blog.bsoares.com.br/processing/controlling-rgb-led-with-arduino-and-processing
error :
Code: [Select]
WARNING:  RXTX Version mismatch
Jar version = RXTX-2.2pre1
native lib Version = RXTX-2.2pre2
[0] "COM3"
Exception in thread "Animation Thread" java.lang.ArrayIndexOutOfBoundsException: 1
at sketch_may22a.setup(sketch_may22a.java:48)
at processing.core.PApplet.handleDraw(Unknown Source)
at processing.core.PApplet.run(Unknown Source)
at java.lang.Thread.run(Thread.java:662)
[0] "COM3"
at sketch_may22b.setup(sketch_may22b.java:48)
johnwasser
I think the problem is this:
Code: [Select]
println(Serial.list());
  port = new Serial(this, Serial.list()[1], 9600);
Your output shows that there is only one element in the list of serial ports.  Element 0.  Then the code tries to use element 1.  That's going to fail.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
hitekos
so what should i do?
do you have another tutorial to make an rgb led work with arduino?
johnwasser
I would change it to:
Code: [Select]
  port = new Serial(this, Serial.list()[0], 9600);
hitekos
It's working thank you :)
do you know any better procceing code for rgb led control?
