Author Topic: 4 relay homemade pcb  (Read 964 times)
Greece
Your Desire For Success Must Be Greater Than Your Fear Of Failure
hellow,
i want to create a 4 realy pcd with 3 pins screw terminals. i want to have a separate power supply from arduino, and maybe i will also put some leds on it. Even thow i have done this in my breadboard, i dont know how to start to make a pcb with this and how is the best way to put them in a pcb. Are any already done desings for this thing?
thanks in advance
Western New York, USA
Try searching Google for 'Arduino relay shield'.  I found this one and there are probably a lot more. http://www.robotshop.com/seeedstudio-arduino-relay-shield.html?utm_source=google&utm_medium=base&utm_campaign=jos
Don
Boston area, metrowest
Online Online
If you can't find one that does what you want, then you can create a schematic and breadboard using software such as www.expresspcb.com or eagle from www.cadsoft.de/info.htm
Greece
thanks.
I just want to try make it myself...
Red Sea, Saudi Arabia
..On The Red Sea
I think you will learn some new stuff by doing it yourself. Look at the examples given above ..
Take a look at this one, which also has the schematic diagram:  http://arduino-direct.com/sunshop/index.php?l=product_detail&p=155
You might decide to use optical isolation like in this one: http://arduino-direct.com/sunshop/index.php?l=product_detail&p=156
Get some prototype / perforated board and built the first one that way. Later design a PCB if you want.  Get your design working first..
More about relays and power here: http://arduino-info.wikispaces.com/ArduinoPower
PM me if you want just the relays themselves, pretty cheap... I am thinking of stocking some..
Regards, Terry King  ..On the Red Sea at KAUST.edu.sa
terry@yourduino.com  LEARN! DO! (Arduino Boards, Sensors, Parts @ http://yourduino.com)
Craiova - Romania
hi,
You managed to accomplish diagram, wiring and installation practice?
I redesigned schematic from http://arduino-direct.com/sunshop/index.php?l=product_detail&p=155 using EAGLE software:
- schematic: http://i47.tinypic.com/9jowhx.png
- board: http://i49.tinypic.com/152i0du.png
- board with components: http://i50.tinypic.com/30krb69.gif
- a 3D view: http://i47.tinypic.com/2copz7n.jpg
best regard,
niq_ro
« Last Edit: November 15, 2012, 04:17:41 am by niq_ro » Logged
is not better to reinvent the wheel, but to improve it's less work and better results
Topsham, Vermont USA
... in The Woods In Vermont
Hi, Nice example of the process of designing a board...
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
