Loading...
Pages: [1]   Go Down
Author Topic: Mixing epoxy  (Read 564 times)
0
Offline Offline
Full Member
Arduino rocks
View Profile
Hi
I am getting sick of mixing epoxy by hand, so I thought I would try to make a mixing device with arduino.
My idea is to use a scale and two pumps and a mixer.
Does anyone know suitable items for this task?
http://www.webac.com/pictures/JM2BLACKSIDE400.jpg
Kim
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
Damn, that's a lot of epoxy! What are you making?
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Pretty specialized application. Different epoxy formulas have different setup times so you really need to know what you are doing or you could end up with a mess quickly. Anyway I suspect that trying to pump epoxy ingredients would be pretty difficult because of the viscosity of the material. A better method might be to use pressure to force material through the mixing orifice maybe?  This sounds like a very difficult project with lots of experimentation required to get it correct, unless you are working from a proven design that gives enough details to duplicate.
Good luck
Lefty
Logged
0
Offline Offline
Full Member
ArduiYES!
View Profile
consider using peristaltic pumps.
these avoid having the epoxy mess in contact with the pump.
I know you can measure volume quite good with these but they might be too slow.
i.e. not enough throughput.
check google (and consider that they can be 3D printed for a prototype, check thingiverse)
http://www.thingiverse.com/image:56137
« Last Edit: June 05, 2011, 02:04:50 pm by raalst » Logged
0
Offline Offline
Full Member
Arduino rocks
View Profile
I have this epoxy here: http://www.vperseus.com/web/dgweixing/images/Infusion_brochure_09.pdf
How do you suggest to do it without pumps?
Kim
Logged
Dubuque, Iowa, USA
Offline Offline
Edison Member
View Profile
Look into peristaltic pumps as raalst suggested. They're pretty straightforward to construct from scratch and you should be able to get a pretty precise flow.
If you're using metering pumps you could create a crank mechanism (like how a steam engine converts linear to rotational motion) to push the pumps for you. Not sure how practical it would be but it'd certainly be entertaining to watch.
In both cases it would probably be best to use a single drive motor and a chain and sprocket to drive both pumps at the same time. By selecting the appropriate ratio of teeth for each sprocket you would then get the proper mix ratio for your epoxy. Changing the mix ratio would then just require a change of a sprocket.
Logged
Ontario
Offline Offline
God Member
View Profile
worth the trouble to disassemble and clean it when you are done for the day.
West (and likely other epoxy systems) use plunger pumps than are primed up and left full of resin or hardener for as long as it takes to use the material -- months even.  There is no need to clean them between sessions.
It might be possible to rig up a linear actuator to the plunger style pumps.
But if it were me, I think I too would go with peristaltic.  If you are sufficiently handy, you could probably fabricate a peristaltic pump with a highly geared motor, a plywood frame and some tygon fuel tubing.  I remember a thread in the old BBS that included a link to some reasonably priced peristaltic pumps.
Logged
Boston Suburbs
Offline Offline
God Member
I am above your silly so-called "Laws", Mister Ohm.
View Profile
WWW
I first laughed at this, but it's a cute idea.  Not practical likely, but cute.
What occurs to me is the syringe-type two part epoxy sold on a card in hardware stores is pretty much what you want, at least dispensing.  You push the plunger, it dispenses the proper amounts of resin and hardener in proportion.  You just pop the cap on when done, it keeps once opened for months.
So, a stepper motor turning a screw with a static nut on the other end is all that you would need.  Total hack, but it would work, and cheap...  Scaling up really is just a matter of making it bigger.  The mixing point is the point where trouble could get bad fast.. but there's epoxies available with setting times from less than a minute to hours.  Your "syringe" can be made from PVC piping, using the proper diameter proportion to determine mixing ratio, just like the plastic-carded ones.  An epoxy with a ratio of 2:1 would use one pipe "piston" full, with a 2" inside diameter, the other with a 1" inside diameter (as an example.  It's the ratio of the pistons sizes to eachother that's important).  If a "plunger" is run equal distance down both, it will dispense out at a 2:1 ratio.  Changing mixing ratios then becomes changing in the right "piston", no calculation necessary.  Your motor/pump doesn't control the mixing ratio, it just controls how much of the properly-ratio'ed epoxy you pump out.  Typically, epoxies have only one ratio to be mixed at.. it's not like you vary amounts of resin and hardener to produce different types of epoxy, and their chemistries are probably unrelated enough that trying to have a Universal "A" to fit every "B" would just be silly.  Only when you entirely change epoxies would you change the mixing ratios.
It may just be easy enough to use a really cheap mixing nozzle that you expect to clog, and just take off and throw away just the mixing nozzle at the end of the day.  It could be made from cardboard or other relatively trash-friendly stuff I suppose...
« Last Edit: June 06, 2011, 11:09:54 pm by focalist » Logged
When the testing is complete there will be... cake.
0
Offline Offline
Full Member
Arduino rocks
View Profile
Quote
well its volume, and A = pi*D^2/4 ...
How do you suggest getting the epoxy in to the syringe? I have 1 barrel with hardener and one with resin. Why always focus on volume mixing rate and not use a scale and just stop at the required amount?
For the mixing part, what about a mix master or a magnetic stirrer or sth like that? How can u get a nozzle to mix it well?
Kim
Logged
Boston Suburbs
Offline Offline
God Member
View Profile
WWW
How about the nozzle assembly includes a paddle at the mixing point, a shaft that extends back, which sockets into a motor?  The shaft extends back through a gasket (there's minimal pressure, ideally) and the paddle is rotated as the epoxy components are dispensed from their respective tanks, no matter how it's done.
                            Expoxy A
Motor and gasket    ----]------{} =------ >>> mixed epoxy
                               Epoxy B
The nozzle and paddle simply are removed and tossed.
Logged
Pages: [1]   Go Up
Print
Jump to:
