Topic: Temperature Sensing on a Farm (Read 3909 times) previous topic - next topic
HooctAwnFonix
Hello!
I'm on a farm and we have a few greenhouses that would be nice to have sensors on. I found out about xbee's on here and I'd like to play around with them but I'm having trouble finding out what I need to order exactly. All together, I would want to sense and log data from 3 different greenhouses and two areas outdoors, all within a mile.
I was going to use this
http://www.sparkfun.com/products/8767
but I think that I need something to hook it up too for power at least, because this looks like just a chip.
I found this, which might be what I'm looking for
http://www.digi.com/products/wireless-modems-peripherals/wireless-range-extenders-peripherals/xbee-sensors.jsp#overview
but the range is no good.
Any suggestions? Also, since all of this is radio, wouldn't I need some kind of receiver near my computer?
Any help would be appreciated so I kind at least order the right stuff right now (I'll probably start with one sensor and see how I do, adding more later). I have some programming background and have messed around with arduinos so I'm hoping that I'll be able to figure this project out as I go along.
Jack Christensen
The spec on the XBee-Pro is 2 miles outdoors, line-of-sight, so depending on the layout, it certainly could work, perhaps with external antennas. I'd probably just get a couple and experiment first. My experience has just been with the low-power modules, though. These are easily powered by an Arduino's power supply, but I might want to provide a separate supply for the Pro modules.
As for a receiver, another XBee is required. From there, the details depend on how the data is to be logged and to where.
Here is a blog post I did describing a simple two-node network consisting of two XBees and two Arduinos, and logging data to the Pachube web site. HTH.
TerryKing
Jack has good stuff on the communications part.  Might be able to do this also with higher-power nRF2401+ type units. But Xbee has more mature code for Arduino.
For the temperature measurement stuff, look at: http://arduino-info.wikispaces.com/TemperatureHumidity
Also this: http://arduino-info.wikispaces.com/Brick-Temperature-DS18B20   (Look at the end for some nice waterproof sensors).
People are also making soil moisture sensors.
If you want to control valves and motors, see: http://arduino-info.wikispaces.com/ArduinoPower
Bobnova
I don't know what kind of range you need, but the RFM12B modules have 100m or so of range in line of sight conditions, and cost a whopping $8 or so.  I've enjoyed playing with mine.
draythomp
I'm not sure if this is what you need, but I made a really simple temperature sensor hooked to an XBee for measuring outdoor temperature.  I plug it into an outdoor outlet and just let it run.  Took two 10K resistors, a wall wart, and an XBee and of course, a wall plug.  Since the XBees can forward for each other, you could easily get by without buying the expensive pro models.  Last time I looked the pro modules cost 3x the lower powered ones and outside, you can get pretty good range.  The problems with transmission distance come when there are walls involved, especially outside walls that have some kind of metal lathe.  If you want to see my little device, go to my web site at draythomp.blogspot.com and look behind the tab "world of XBee"  a picture of it is at the bottom of the page.
HooctAwnFonix
Thanks for all the info!
I think draythomp's setup is more what I'm looking for - maybe find a way to waterproof it. Will definitely look into that soil moisture sensing once I have air temp set up.
Also, just a general question - I'm sure I could figure this out if I did a little bit more reading but I'm busy outside - Series 1 vs Series 2?
Can I still relay information with Series 1 because that's the main feature I'm probably looking for. What's the big benefit of "mesh networks"?
draythomp
If one of them breaks, the others route around the broken one.  It's a way of the network taking care of itself.  Really nice in a situation where you need to keep things working, just add a couple of strategic devices and keep a spare on hand that you can bring online when you need it.  This way a temperature sensor also works as a router to carry the data from some more remote sensor that in turn acts as a router.
Jack Christensen
For my money, I'd just as soon have the current stuff (S2). Mesh networking is pretty cool, self-forming and self-repairing, makes for a robust network. But in my mind, as cool as that is, there's always more risk in buying older technology, i.e. availability, support, etc. So that may in fact be the bigger reason. Admittedly you're getting a biased viewpoint here because I've only used S2, but quite frankly, I don't see a downside to it.
Here's one link with just a little info. Browse around the site and you'll find more. http://www.digi.com/technology/rf-articles/wireless-zigbee.jsp
HooctAwnFonix
draythomp - i think you're setup is very close to what i'm looking for!
TerryKing - i'll be interested in messing around with some soil sensors later on... but I'm gonna try this simple thing first.
I'd also like to get a solar or battery powered water proof sensor for the orchards later on. And if I get crazy later on, I might bring an arduino into the grow tunnel so I can see what I can automate (water, fan, side flaps).
But first things first! One sensor inside the greenhouse sending me the temperature so I can log the data and observe from my computer.
so i have my parts list ready, i think:
Receiver:
XBee 1mW Chip Antenna (http://www.sparkfun.com/products/8664)
FTDI Cable 5V VCC-3.3V I/O(http://www.sparkfun.com/products/9717)
Sensor in the greenhouse:
XBee Pro 60mW Wire Antenna (http://www.sparkfun.com/products/8742)
Wall Adapter Power Supply - 5VDC 1A (http://www.sparkfun.com/products/8269)
Will this be enough to get me started? I might also buy the book since I don't really know what I'm doing!
HooctAwnFonix
Actually, how is it that I'll be able to connect the wall wart to the xbee?  :smiley-red:
draythomp
I drilled a small hole in the side, ran two wires through and then stuck it to the side with two sided tape.  I was in a hurry to try out the idea.
HooctAwnFonix
Cool - so maybe to make things nice I'd need a soldering iron? Will probably use tape like you for my first shot though...
zoomkat
You are probably going to need a multimeter if you don't already have one.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
HooctAwnFonix
Haha yea, thanks for that... I actually don't have any tools like that yet!
PaulS
Quote
Receiver:
The XBees talk to each other, to confirm receipt of packets and other things. They need to be matched. A low power receiver and a high powered transmitter won't play well together when the range exceeds the capabilities of the lower powered device, regardless of how high powered the other device is.
