Loading...
Poll
Question: Which 1 do u want me to make?
"Arduino Tutorial" on how to make $60 11-Kube - 5 (38.5%)
"Instructable" on how to make $60 11-Kube - 2 (15.4%)
Both Option #1 & Option #2 - 5 (38.5%)
Other (Please post what) - 1 (7.7%)
Total Voters: 13
Pages: 1 [2]   Go Down
Author Topic: Would anyone be interested in how to make a <$100 11*11*11 Bi-color LedCUBE?  (Read 1061 times)
Toronto, Canada
Offline Offline
Edison Member
"Keep it R.E.I.L. - "Research, Experiment, Investigate and Learn"
View Profile
@CrossRoads
In that case, it is possible
@retrolefty
I check your old post, I copy you code into the IDE, save it.  I will study the code to see how you do it. I assuming you use shift register to display the cube. Right ?
It a cool project to make.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
Correct. However different from the PIC schematic, I wired the 25 led columns to the most significant 25 bit of the 32 bit shift register ( 2 16 bit registers wired in series) rather then the least significant 25 bits of the register, so I shift out a complete 32 bit long variable for each 'level' update. I had did that in case in the future I wanted to take advantage of those extra 7 output bits, perhaps to drive a 5 digit seven segment display.
PS: whatever leds you decide on be sure to use the diffused varity, as the brighter clear leds have a narrower 'field of view' and won't look nearly as good in a cube application. You can sand leds to diffuse them but that's a lot of sandpaper and elbow grease, better to just buy the right ones to begin. E-bay Asian sellers have killer good prices on bulk leds.
Lefty
« Last Edit: September 17, 2011, 11:46:17 pm by retrolefty » Logged
Toronto, Canada
Offline Offline
Edison Member
View Profile
I  am more interrest to build RGB  3 X 3 X 3 ( a possiblility ) .  A bit easier to solder than  a 11 X 11 X 11.  and cheaper. The cube will look cool , specially display/show the cube in the living room as a decorative show piece, just like my 1/25 scale model kits <-- one of my hobbies.
Thank retrolefty for your tips. About your program, I will study it and use some of the programing techniques in my projects. ( you own version of shiftOut().
Logged
Offline Offline
Sr. Member
Arduino rocks!
View Profile
Check this out >link<
Logged
As always... Thanks for posting!!!
Toronto, Canada
Offline Offline
Edison Member
View Profile
Yes, I did.  It is expensive, close to $70     smiley-eek    , I will built it a bit cheaper smiley-wink
Logged
Offline Offline
Sr. Member
Arduino rocks!
View Profile
I think ebay has 125x rgb led's for less than $30 I bought 200 for $40 there once
then u could make a rgb 5*5*5 cube
« Last Edit: September 20, 2011, 11:22:57 pm by TECH GEEK » Logged
Pages: 1 [2]   Go Up
Print
Jump to:
