« on: May 24, 2011, 11:51:15 am » |
Hello again  I will be making an Arduino fan controller which will regulate the voltage on the fan with the help of the LM317 Voltage Regulator, now I have made a schematic and I have a question: The input voltage will be 12V from a PC PSU, will the LM317 be able to give 12V output?
Ordinary people pursue order, Ingenuous people rule chaos.
Manchester (England England)
Solder is electric glue
« Reply #1 on: May 24, 2011, 11:58:38 am » |
The input voltage will be 12V from a PC PSU, will the LM317 be able to give 12V output? No. You need a voltage greater than 12V say 14V to get 12V out. Also you have no input or output capacitors and have you allowed for the Vssat voltage between collector and emitter when the transistor is on? You also need resistors in the base of the transistors to limit current flow.
Left Coast, CA (USA)
Online
Measurement changes behavior
« Reply #2 on: May 24, 2011, 12:00:55 pm » |
The input voltage will be 12V from a PC PSU, will the LM317 be able to give 12V output? No, the chip has a regulator drop out voltage specification. It's dependent on how much current is being drawn from the regulator and is about 2 volts at 1 amp drop, so plan on around a 10vdc max output for the regulator if being supplied with +12vdc. Also be sure to add series current limiting resistors going to the base of those switching transistors. Lefty
« Reply #3 on: May 24, 2011, 12:05:35 pm » |
Thanks for the replies guys  Any idea on how I would get more than 12V with a PC PSU?
« Reply #4 on: May 24, 2011, 12:09:20 pm » |
I will be making an Arduino fan controller which will regulate the voltage on the fan I am assuming the fan is 12V, the simple answer is not to use a regulator circuit like this but to use a FET driver in the continuous (non switched) mode.
UK
« Reply #5 on: May 24, 2011, 12:14:00 pm » |
Any idea on how I would get more than 12V with a PC PSU? I assume PC supplies still have -12V outputs. -12 to +12 is 24 volts.
Online
« Reply #6 on: May 24, 2011, 12:23:26 pm » |
Any idea on how I would get more than 12V with a PC PSU? I assume PC supplies still have -12V outputs. -12 to +12 is 24 volts. Not really usable that way in a common grounded system. Lefty
UK
« Reply #7 on: May 24, 2011, 12:26:35 pm » |
Depends what you declare "ground" to be.
Online
« Reply #8 on: May 24, 2011, 12:29:29 pm » |
Correct, we would need to know if he is using the PC supply for any other loads, or desires to. Lefty
« Reply #9 on: May 24, 2011, 12:48:34 pm » |
I'll be using the same PSU for: Pumps (Water Cooling), Micro Controllers, Fans
Red Sea, Saudi Arabia
..On The Red Sea
« Reply #10 on: May 24, 2011, 02:25:51 pm » |
Mike has the best solution; use a single power FET and control it with a PWM output from Arduino. And it (could) handle a lot more current than an LM317T. Nothing against the LM317T. I once bought a barrel of 14,000 of them for $55 from a junkyard near IBM  I'll send 5 to anyone who'll send a SASE... I still have about 500 left. --------------------------------------------------------------------- UPDATE: Sorry! I'm always criticizing Acronyms... Self-Addressed-Stamped-Envelope (sent to me, will return 5 LM317t's..) Terry King 152 Colby Road West Topsham, VT 05086 But: 3 weeks till I get there from the Middle East...
« Last Edit: May 25, 2011, 08:13:47 am by Terry King »
« Reply #11 on: May 25, 2011, 08:10:31 am » |
Can you give me more info on using FET's with Arduino? Schematic(s), Maybe even some example code
« Reply #12 on: May 25, 2011, 08:48:05 am » |
Maybe even some example code analogWrite(pin, value); Schematic(s) use the PWM output filtered and into the gate http://www.thebox.myzen.co.uk/Tutorial/PWM.html
« Reply #13 on: May 25, 2011, 09:21:13 am » |
So I use Frequency dependent potential divider with low pass filter connected to a FET, and the divider is hooked up to Arduino PWM output pin? And if so, which FET should I use?
« Reply #14 on: May 25, 2011, 11:43:53 am » |
Frequency dependent potential divider with low pass filter close:- Frequency dependent potential divider AS low pass filter. which FET should I use? Any one that will take at least 200mA (most will) and is a logic level FET. The FET will get hot because you are burning the excess voltage off inside it when it is not full on. The power dissipated will be with half the voltage dropped across it at what ever current the motor runs with only half the voltage across it. You might need a heat sink.
