Topic: LM317 Help (Read 11672 times) previous topic - next topic
Rogy
@Grumpy_Mike
Thanks! :D
I hope I'm not too annoying with all these questions :P, maybe something like this? http://www.nteinc.com/specs/2900to2999/pdf/nte2987.pdf
Could you also tell me what exactly am I look for? N-Channel MOSFETS?
Ordinary people pursue order, Ingenuous people rule chaos.
Grumpy_Mike
Yes very meaty, that would do.
Rogy
Alright! :)
Now, if only I could find that in Eagle :P
retrolefty
@Grumpy_Mike
Thanks! :D
Mouser shows that at $7 a pop: http://www.mouser.com/ProductDetail/NTE/NTE2987/?qs=sGAEpiMZZMutXGli8Ay4kFfMPLZ9xW8yKOlRS6m%252bwN0%3D
Sparkfun sells a logic level N-channel power mosfet for a buck: http://www.sparkfun.com/products/10213
Lefty
Grumpy_Mike
I said it was meaty.  :)
Rogy
I found something a bit cheaper than the previous I linked and am not sure if it will work...
http://eu.mouser.com/ProductDetail/Fairchild-Semiconductor/FDP6030BL/?qs=sGAEpiMZZMutXGli8Ay4kBEMMAKgSkd8MdwkNnQ%2fGU8%3d
Terry King
Speaking Of FETS... I would like to decide best 2 or 4 power NFET and PFET to stock for use with Arduino...
I would appreciate your suggestions...
Two that have been suggested are:
RFP30N06LE "N-Channel Logic Level Gate Power FET"
FQP27P06 "P-Channel Power FET"
Also maybe a good TO92 or similar small Logic-Gate NFET for cheap routine replacement of small NPNs like 2N2222 ??
What has been working well for you???
I'll make these available at a decent price in my online store...
Thanks!
Regards, Terry King  ..On the Red Sea at KAUST.edu.sa
terry@yourduino.com  LEARN! DO! (Arduino Boards, Sensors, Parts @ http://yourduino.com
Rogy
Can anyone tell me what I must pay attention to when choosing a FET for using it to regulate voltage with Arduino?
Grumpy_Mike
Turn on voltage, it should be rated at 5V and have a low Ron at this value. At most 0.01R.
It should be in a package that allows good power dissipation because as I said it will burn off the excess power.
Rogy
@Grumpy_Mike
So: N-Channel FET, TO-220, 5V Turn on voltage, low on resistance, low resistance drain-to-source, and of course, drain source voltage high enough and same for current ?
Grumpy_Mike
Yes.
You will struggle to find one that is not high enough.
Rogy
I think I found something that will fit my needs: http://eu.mouser.com/ProductDetail/Fairchild-Semiconductor/FDP7030BL/?qs=sGAEpiMZZMvECErq9cesgOhjwE8m5zTM4sOaJqrLpIU%3d
Now for the (hopefully) last question: How do I connect everything? :P
Something like this?
        12V
        |Source pin
|Digital Pin 9|----|Resistor|----|Capacitor|--Gate--|MOSFET|
        |Drain pin
        Load(Fan)
        GND
justjed
Nothing against the LM317T. I once bought a barrel of 14,000 of them for $55 from a junkyard near IBM  :) I'll send 5 to anyone who'll send a SASE... I still have about 500 left.
Cool! Would 2 "forever" stamps be sufficient postage? Maybe 3 to be sure, eh?
Thanks, Terry.
... it is poor civic hygiene to install technologies that could someday
facilitate a police state. -- Bruce Schneier
Grumpy_Mike
No like this
        12V
        Load(Fan)
        |Drain pin
|Digital Pin 9|----|Resistor|-------------Gate--|MOSFET|
                                         |Capacitor|            |Source pin
                                              GND                GND
The way you had it:-
1) the capacitor would block the DC signal and nothing would get too the gate
2) you would not get any more than 5V across your fan
Rogy
