Topic: Electronics formula's (Read 4918 times) previous topic - next topic
Morrolan
I'm interested in finding out what common formula's people use on a regular basis, eiether electronic or electrical.
The common ones are Ohms Law(v=IR), Watts Law (P=IV - don't know if it is actually called Watts law), potential dividers (Vout = R2/(R1+R2) xVin) etc.
Are there any other formulas that people use on a regular basis?
Many thanks in advance.
TerryKing
I used R-C time constant  T=R*C  twice today...  But mostly ohm's/watt's
Morrolan
Many thanks for that Terry.
Anyone else?
bubulindo
P = UI
T = RC
U = RI
And I think it's about it.
Knowing the voltage drops in LEDs to calculate the current going through a LED is also good to know, but I mostly don't care and go for a 1k resistor with 5V.
Can't think of any more formulas for small electronics, since all the other more complicated deride from these. :\
This... is a hobby.
Morrolan
Bubilindo, I know the T=RC formula - please could you explain the others as they are new to me?
Regards,
Morrolan
tastewar
I think you mean "derive," (he said derisively...) :-)
floresta
Quote
Substitute an 'E' or a 'V' for his 'U' and they should look familiar.
Don
Morrolan
Haha, I hadn't even clicked that there were just different versions of V=IR and P=IV!
Any others?
Grumpy_Mike
1/ (2pi Sqrt(LC)) - is the resonant frequency of an LC circuit
1/ (2pi FC) - is the capacitive reactance (equivalent resistance) of a capacitor at a frequency F. Replace C with L for inductive reactance.
See filter discussions in:-
http://www.thebox.myzen.co.uk/Tutorial/PWM.html
johnwasser
De Morgan's laws are helpful in designing digital logic:
NOT (A AND B) == NOT A OR NOT B
NOT (A OR B) == NOT A AND NOT B
That means that even if all you have is a big pile of NAND gates (or NOR gates) you can build anything.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Grumpy_Mike
Not so much a law as a theorem.  :)
johnwasser
You'll have to edit the Wikipedia article:
http://en.wikipedia.org/wiki/De_Morgan's_laws
Grumpy_Mike
Ok looks like I will have to. A law is reserved for physical phonemna you don't talk about Pythagrous' law do you. Or perhaps you do?
keeper63@cox.net
When I went to tech school here in Phoenix, one of the things we were given as a part of our toolkit was (IIRC) a small folding "booklet" of equations for electronics, from - once again going from memory here - Graymark. I'll have to dig it up when I get home tonight...
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
Grumpy_Mike
Then there is:-
Q = VC
Where Q is charge in coulombs, V is voltage and C is capacitance (in Farads)
One coulomb is the amount of charge that flows past a point in 1 second when the current is 1 Amp.
