Topic: Electronics formula's (Read 3291 times) previous topic - next topic
bubulindo
Can't think of any more formulas for small electronics, since all the other more complicated deride from these. :\
I think you mean "derive," (he said derisively...) :-)
As you probably noticed, I'm not a native speaker. Thanks for the heads up. :)
This... is a hobby.
raron
Quote
1/ (2pi FC) - is the capacitive reactance (equivalent resistance) of a capacitor at a frequency F. Replace C with L for inductive reactance.
Small typo there, so just for completness sake: For inductive reactance the formula is the reciprocal (with regards to capacative reactance); XL = 2pi FL.
Since nobody have mentioned it, calculating resistance of resistors in parallel is also handy:
R = R1*R2/(R1+R2)
Personally I never use the above form, I like the reciprocals variant as it is simpler with more than 2 resistors:
1/R = 1/R1 + 1/R2 ... + 1/Rn
Same goes for capacitors in series btw:
1/C = 1/C1 + 1/C2 ... + 1/Cn
While capacitors in parallel just adds up (like resistors in series, so they are kind of opposite)
C = C1 + C2 ... +Cn
floresta
Quote
If you have a calculator that uses RPN (Reverse Polish Notation) these versions are especially easy to implement.
Don
raron
Quote
Ok. I never had one of those. But I do
(R1-1+R2-1)-1
which is similar I think, and pretty quick also, since there is a "^-1" button.
floresta
Quote
(R1-1+R2-1)-1
As I see it this requires at least 6 keystrokes over and above whatever it takes to enter the resistor values.
With RPN you enter: R1, 1/x, R2, 1/x, +, 1/x  Since there is a 1/x key this gives you 4 keystrokes over and above whatever it takes to enter the resistor values.  In my experience RPN always does the job with fewer keystrokes.
Don
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
