Topic: Way to connect & disconnect a speaker w/ out using a relay? (Read 949 times) previous topic - next topic
TECH GEEK
Is there a way to connect & disconnect a speaker w/ out using a relay? If you know of a way please explain how it should be set up...
thanks
also is there an audio file type that that can go on an micro-SD card and when read has the same signal as a mic would with the same audio input?
Basically what I'm trying to do is send an audio file from a micro-SD card to the mic's connection on a 20-second record-and-playback module while it is recording, then trigger the recorded audio file then record a new and differant file from the SD card... THIS is the module I have
As always... Thanks for posting!!!
Magician
This what I think will work as a relay, it's chip, but word relay still present in it's name.
http://www.vishay.com/solid-state-relays/
2A, 0.25 Ohm in ON - looks promising.
To adjust signal down mic level try resistive divider.
elandd2011
you can use a  n MOSFET to switch on/off the speaker,connect it in series w the ground  cable of the speaker and the gate trough a resistor to the control circuit, if you have high level on the MOSFET gate he speaker is on and reverse
got IT???
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
