Topic: LED trouble (Read 2044 times) previous topic - next topic
vishalapr
But a few days ago I connected the LEDs without a resistor and without a transistor(I connected the set LEDs), and everything worked fine, so do you still advice me to use a transistor and a resistor.
AWOL
Quote
What you should say is "there was no immediate, visible damage to my AV microcontroller".
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
vishalapr
Ok then I will use resistors, but I cannot use any transistors because I do not have any right now
CrossRoads
Ok, wire up your sets of resistors in parallel then with a resistor each, being sure the total current draw stays under 20ma.
vishalapr
This is what I did, I used four transistors, for the 4 sets of LEDs and I added a resistor from the middle pin of each trasistor to the arduino.
And this works absolutely fine, no problems, and the current is about 18 on my ammeter.
CrossRoads
Sounds like you're on the path to success!
