Topic: Multiple XBee 802.15.4 Communication. (Read 2051 times) previous topic - next topic
Aadeesh
Hello,
I am trying to send two potentiometer values connected to two arduinos to a laptop.
So i am using Xbee 802.15.4 (Series 1) modules for the purpose.
My setup is as follows:
Transmitter:
ArduinoTx (Pin3 NewSoftSerial) ===> XbeeDin     //Using NewSoftSerial to avoid conflicts with USB as i am not using the Xbee Shield
Arduino3V3 ===> XbeeVDD
ArduinoGND ===> XbeeGND
Arduino Powered using Laptop's USB port
Laptop:
Xbee connected to FT232 Xbee Adapter Board
My Xbee Configurations:
Quote
ArduinoXBEE
(XB24, 802.15.4, 10E8)
ID = 9898
DH = 0
DL = 1
MY = 2
BD = 5 (38400)
LaptopXBEE
ID = 9898
DH = 0
DL = 0
MY = 1
CE = 1 (Cordinator Enable)
BD = 5 (38400)
It worked for the first time. But when i powered off both arduino and laptop's xbee, it does not work.
I tested the same setup with my other Series 2 modules and it works.
Is my above Xbee configuration correct ?
Any help will be appreciated.
PaulS
The MY address on one XBee must match the DL address on the other XBee. So, no, your configuration is not correct.
Change the laptop's XBee's DL value to 2.
Aadeesh
Thanks Paul. I have re-configured the laptop's XBee by changing the DL value to 2.
But unluckily it does not work.
I Google-d about this issue and found the following project:
http://www.kobakant.at/DIY/?p=270
The configuration is pretty same as of mine, unlike i am using XBee's in transparent mode.
Any more suggestions ?
Regards,
Aadeesh
markbee
i haven't used any series 1 xbees but why is on the one module low address (DL) =1 and on the other 0?
markbee
XBee blog: http://lookmanowire.blogspot.com/
Aadeesh
@markbee
It is because Xbee with DL=0 (Coordinator) should listen to multiple End Devices in range.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
