Loading...
Pages: [1]   Go Down
Author Topic: 4 dc motors and 2 servos  (Read 627 times)
scotland
Offline Offline
Newbie
View Profile
hi all
i have a project running at the moment building a 4wd rover using arduino duemilanove,dfrobot i/o board v5 and a dagu 4 motor controller board.
my problem is i dont seem to be able to work out how to run 4 dc motors and 2 servos(pan and tilt) on one board i believe i will run into timer issues.
any help and guidence would be very gratefully recieved
thanks
paul
Logged
only happy when tinkering
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
A link to your controller board would be useful.
Logged
scotland
Offline Offline
Newbie
View Profile
hi thanks for the reply
here is the link to my motor controller http://robosavvy.com/store/product_info.php/products_id/1573
hope this helps
thanks
paul
Logged
Offline Offline
Brattain Member
View Profile
WWW
I don't see why you should not be able to run four motors with this board they are just H-bridges. It will not help with the servos though.
As to timing issues what makes you think this? The board will allow you to control the direction of the motor and if you apply a PWM signal to one of the two line into the H-bridge will also allow you to control the speed.
Can you be more specific about what your problem is.
Logged
scotland
Offline Offline
Newbie
View Profile
hi mike
my issue is the servos.
the motor side works perfectly any speed any direction no issue but the servos wont work they centre on startup then stay locked in place i thought it might be a timer issue but being a novice not to sure?? here is my sketch if that helps
Code:
#include <Servo.h>
int minPulse1     =  0;      // minimum servo position
int maxPulse1     =  170;  // maximum servo position
int turnRate1     =  10;    // servo turn rate increment (larger value, faster rate)
int minPulse2     =  0;     // minimum servo position
int maxPulse2     =  180; // maximum servo position
int turnRate2     =  10;   // servo turn rate increment (larger value, faster rate)
int buttonPin     = 26;    // pin that the trigger will be connected to
int centerServo1;
int centerServo2;
int pulseWidth1;     // servo pulse width
int pulseWidth2;     // servo pulse width
//motor control
int EN1 = 9;     //speed control
int EN2 = 11;   //speed control
int EN3 = 6;    //speed control
int EN4 = 10;  //speed control
int IN1 = 3;    //direction
int IN2 = 5;   //direction
int IN3 = 7;   //direction
int IN4 = 2;   //direction
void Motor1(int pwm, boolean reverse)
          analogWrite(EN1,pwm); //set pwm control, 0 for stop, and 255 for maximum speed
         if(reverse)
          digitalWrite(IN1,HIGH);
          digitalWrite(IN1,LOW);
void Motor2(int pwm, boolean reverse)
          analogWrite(EN2,pwm);
         if(reverse)
          digitalWrite(IN2,HIGH);
          digitalWrite(IN2,LOW);
void Motor3(int pwm, boolean reverse)
          analogWrite(EN3,pwm); //set pwm control, 0 for stop, and 255 for maximum speed
         if(reverse)
          digitalWrite(IN3,HIGH);
          digitalWrite(IN3,LOW);
void Motor4(int pwm, boolean reverse)
          analogWrite(EN4,pwm); //set pwm control, 0 for stop, and 255 for maximum speed
         if(reverse)
          digitalWrite(IN4,HIGH);
          digitalWrite(IN4,LOW);
Servo servo1;
Servo servo2;
  pinMode(buttonPin, OUTPUT);
  servo1.attach(22);
  servo2.attach(24);
  centerServo1 = maxPulse1 - ((maxPulse1 - minPulse1)/2);
  centerServo2 = maxPulse2 - ((maxPulse2 - minPulse2)/2);
  pulseWidth1 =  centerServo1;
  pulseWidth2 =  centerServo2;
  Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
  Serial.println(" Arduino Serial Servo Control");
  Serial.println("Press j, l, i, or k to move, spacebar to center, and f to fire");
  int i;
    for(i=2;i<=11;i++)       //Motor Shield pin settings
    pinMode(i, OUTPUT);  //set pin 2,3,5,6,7,9,10,11 to output mode
    //Serial.begin(9600);
  // check for serial input
  if (Serial.available() > 0) {
    int data = Serial.read();          // read the incoming byte:
    digitalWrite(buttonPin, LOW);  // turn the pin off on any incoming data
    switch(data)
    case 'j' :
      pulseWidth1 = pulseWidth1 - turnRate1;
    case 'l' :
      pulseWidth1 = pulseWidth1 + turnRate1;
      break ;
    case ' ' :
      pulseWidth1 = pulseWidth2 = centerServo1;
    case 'i' :
      pulseWidth2 = pulseWidth2 - turnRate1;
    case 'k' :
      pulseWidth2 = pulseWidth2 + turnRate1;
      break ;
    case 'f' :
      digitalWrite(buttonPin, HIGH);
      delay (1000);
    // stop servo pulse at min and max
    if (pulseWidth1 > maxPulse1) {
      pulseWidth1 = maxPulse1;
    if (pulseWidth1 < minPulse1) {
      pulseWidth1 = minPulse1;
    if (pulseWidth2 > maxPulse2) {
      pulseWidth2 = maxPulse2;
    if (pulseWidth2 < minPulse2) {
      pulseWidth2 = minPulse2;
    servo1.write(pulseWidth1);
    servo2.write(pulseWidth2);
    // print pulseWidth back to the Serial Monitor (uncomment to debug)
    Serial.print("Servo 1: ");
    Serial.print(pulseWidth1);
    Serial.print(" Servo 2: ");
    Serial.print(pulseWidth2);
    Serial.println("degrees");
    int x,delay_en;
  char val;
  while(1)
    val = Serial.read();
    if(val!=-1)
          switch(val)
             case 'w'://Move ahead
                        Motor1(100,true);  //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
                        Motor2(100,false);  //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
                        Motor3(100,true); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
                        Motor4(100,false); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
             case 'x'://move back
                        Motor1(100,false); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
                        Motor2(100,true); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
                        Motor3(100,false);  //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
                        Motor4(100,true);  //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
             case 'a'://turn left
             case 'd'://turn right
               case 's'://stop
                        Motor1(0,false);
                        Motor2(0,false);
                        Motor3(0,false);
                        Motor4(0,false);
Logged
Offline Offline
Brattain Member
View Profile
WWW
Try replacing:-
with
char data = Serial.read();
Logged
scotland
Offline Offline
Newbie
View Profile
hi mike
thanks for the advice but sadly no go although pressing j or k etc it did move once and showed on the console as having moved but locks up and only a reset will unlock it  smiley-cry
Logged
Dubuque, Iowa, USA
Offline Offline
Edison Member
View Profile
If you're powering the servos from the Arduino's 5V output then you're most likely causing the Arduino to reset due to the power drain. Most of the Arduino boards are only designed to supply around 800ma of current and a single "standard" servo will use ~1000ma at stall or ~250ma under no load.
Logged
scotland
Offline Offline
Newbie
View Profile
hi mate
yes i do have a dedicated 6v power supply to the servos, the board itself has never reset though i have to push the reset button to free the servos after they lock up.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Try replacing:-
with
How does that change anything?
Logged
New Jersey
Offline Offline
Edison Member
View Profile
Here is your problem:
Code:
while(1)
The first char you read from serial may allow you to act on the servos, after that you're looping forever looking for motor commands.
Logged
scotland
Offline Offline
Newbie
View Profile
thank you so much wildbill you are a start (paul sends wildbill a crate of beer)
ok once you pointed out the error of my ways i rewrote the sketch doing away with the wait command it all works well appart from intermitent servo jitter any ideas how i might minimise this
thanks again mike and wildbill for taking the time out to help a novice like me
paul
ps my new sketch below:-
Code:
#include <Servo.h>
  //int buttonPin     =  26;    // pin that the trigger will be connected to
     /** The Arduino will calculate these values for you **/
                // connect apc220 after sketch upload to control wirelessly through serial monitor
  int EN1 = 3;  //speed control
  int EN2 = 5;  //speed control
  int EN4 = 9;  //speed control
  int IN1 = 2;  //direction
  int IN2 = 4;  //direction
  int IN4 = 8;  //direction
 if(reverse)
  if(reverse)
  if(reverse)
  if(reverse)
  Servo servo1;
  Servo servo2;
  int centerServo1;
  int centerServo2;
  int pulseWidth1;
  //pinMode(buttonPin, OUTPUT);
  servo1.attach(10);
  servo2.attach(11);
  Serial.println("Arduino Serial DC Motor Control");
  Serial.println("Press a, d, w, or x to move, s to stop");
  Serial.println("Arduino Serial Servo Control");
  int i;
  for(i=2;i<=9;i++)   //Motor Shield pin settings
    pinMode(i, OUTPUT);  //set pin 3,4,5,6,7,8,9, to output mode
    char data = Serial.read(); // read the incoming byte:
    //digitalWrite(buttonPin, LOW);  // turn the pin off on any incoming data
    switch(data)
    case 'w':  //Move ahead
          Motor1(150,false);  //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
          Motor2(150,true);   //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
          Motor3(150,false);  //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
          Motor4(150,true);   //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
        case 'x':  //move back
          Motor1(150,true);  //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
          Motor2(150,false); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
          Motor3(150,true);  //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
          Motor4(150,false); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
        case 'a':  //turn left
          Motor1(250,true);   //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
          Motor2(250,false);  //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
          Motor3(250,false);  //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
          Motor4(250,true);   //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
       case 'd':  //turn right
          Motor1(250,false); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
          Motor2(250,true);  //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
          Motor3(250,true);  //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
          Motor4(250,false); //adjust speed here 0 to 255 /adjust direction true=fowards false=reverse
       case 's':  //stop
          Motor1(0,false);
          Motor2(0,false);
          Motor3(0,false);
          Motor4(0,false);
    case 'j' :
    case 'l' :
      break ;
    case ' ' :
    case 'i' :
    case 'k' :
      break ;
    case 'f' :
      //digitalWrite(buttonPin, HIGH);
      delay (1000);
Logged
scotland
Offline Offline
Newbie
View Profile
all sorted and working great thanks all for the help
very much appreciated
thanks
paul
Logged
Pages: [1]   Go Up
Print
Jump to:
