Topic: Arduino Mega 2560 + Firmata on Pure Data (Read 2655 times) previous topic - next topic
cPolymorphic
Hi there guys, I have a trouble with arduino mega 2560 and firmata 2.2 (interfacing it with pure data and pduino 0.5beta8)... I need all digital pin (in input, using them with pushbutton sensors), without analog pin... using examples included in arduino 0022 (firmata 2.2), I try SimpleDigitalFirmata to try if it work with Pure Data, but only first 13 pin works well (putting the other on GND, so they doesn't give me random values)... if I put pushbutton sensors to others digital pins, they give me only random values (or nothing)...
I think (maybe it's my error) that the error is in the sketch (I'm now trying AllInputsFirmata), or in PD, maybe I have to change some values, but I don't know what values...
And I have another question: can I use 5 arduino mega on a single patch? I tried with HID object (using it with keyboards), but I can use one HID object for each patch... is there possible using more arduinos on a single patch? Or I have to create a patch for each arduino?
Thank you so much, I am in trouble just now with a project for university ehehehehhe
PS: Sorry for my bad english language XD
PaulS
So you're just now discovering the firmata is not compatible with the Mega, huh? Too bad you didn't research this BEFORE you started trying to use it.
cPolymorphic
Uhm, isn't it possible to add other pins in the sketch?
Wow I am in great trouble now O_O
PaulS
In which sketch? The firmata sketch? The whole firmata concept needs to be reworked to deal with boards with more than 13 digital pins and 6 analog pins. This will affect Arduinos and Processing and everything else that has built a dependency on firmata. One issue that needs to be addressed is for firmata to be able to return some information about the board it is running on, so Processing or PureData or ??? doesn't ask for the value of digital pin 36 when the Arduino that is connected is a UNO.
cPolymorphic
I am trying to configure pins on board by adding some bytes (byte reportPINS), but I don't know if it is correct XD
Do someone knows what to change or add in the sketch maybe? XD
I see that even in the pduino patch there are some pind to add in the arduino object... i think... uhm its a great trouble and I have only 2 days left XD
ferx
Hi guy, i have a similar problem. The question is, if i can not use all pins of arduino mega, what could be a good solucion? can i use 3 or more arduino uno conected to a diferents pd patches?
thanks
